#15 |
Drives: asphalt FR-S
I just installed the H&R TC112 bolts - the threads did not need to be ground down. The threads rested entirely outside the bolt hole and did not interfere with the cam adjustment. Strange. H&R also makes a shorter 12 mm bolt called TC212; maybe those are what you had, not the 112. Or maybe there are two different LCA that were produced? Beats me.
Anyway, it looks like I got some decent camber out of it. Original bolt on top - actually the nut would be tightened in about 3 more threads when installed.
#16 |
update - just got a wheel alignment done. Rear camber maxed out at -1.3°.
Not a lot of camber with this method, but certainly better than stock. I'll probably upgrade to adjustable lower control arms next year. |
#17 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Isn't stock camber -1 degree?
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#18 |
It varies. I got about half a degree out of the camber bolts. Not too impressive.
#19 |
Drives: 86 GTS
If I could add a half degree one side and remove half a degree from the other I'd be happy. This is a much simpler solution for most people as we really need some basic adjustment.
I reckon it's a conspiracy that companies aren't releasing a bolt! -> Forces people to buy arms! Many other cars have this bolt for adjustment. Why is this car different? |
#20 |
Drives: 86 GTS
My Pajero has these;
#21 | |
Drives: '13 BRZ in WRB--let's mod!!!
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. |
#22 |
Drives: '13 DGM BRZ Limited
Those won't work on the stock arms since the stock arms aren't slotted and don't have the right tabs on either side for them to work correctly. Camber bolts like the ones shown further up will work because they have an oblong section. The one shown above won't because it works by having a slot for the bolt to move in/out and it uses the large disc to press against either a recess or tabs.
#23 |
resurrecting an old thread.. its better than making a new thread for the same thing so don't bitch! haha
Anyone install the tc112 bolts lately, how are they going? any install tips? they go in the outer most lca slot correct? thanks
#24 | |
#25 |
Drives: 2013 FR-S Argento
Working just fine! Installed mine at the innermost points as well, I think that's where you want to do it. Went in very easy as well, not a huge amount of adjustment but enough to even my rear camber out.
#26 | |
#27 |
Alexandrino_Auto
Drives: series.Blue
Fantastic. These are perfect for people like myself that only need to dial out 1/2* of camber after lowering on springs. There are a ton of threads saying these don't exist for out cars. Oh happy day.
Thanks!
The Shadetree Project: I turn wrenches
#28 |
Drives: 2014 BRZ
Are these the same thing, the "triple C". they look different. [ame="http://www.amazon.com/TC112-Triple-Camber-Adjustment-Bolt/dp/B00CBQ6M4O"]Amazon.com: H&R TC112 'Triple C' Camber Adjustment Bolt - Pair: Automotive[/ame]
| H&R Camber Bolts | deedz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 09-08-2013 09:00 PM |
| Where to buy Whiteline Camber Bolts | whitefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 07-26-2013 02:05 PM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
| SPC/Whiteline front camber bolts in GTA? | f0rge | CANADA | 2 | 03-20-2013 10:56 PM |
