Old 04-16-2013, 05:17 PM   #15
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Originally Posted by wootwoot View Post
No one else?
Yeah me too, probably have to do the shifting in an another rpm range and he did'nt adjust to it.
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 04-16-2013, 07:18 PM   #16
wootwoot
Drives: FRS
Could be. I was hoping someone that has this upgrade in their FRS would chime in. From all accounts it gives power throughout the RPM band and through each gear. Which makes the most sense to me. Maybe racecomp or robi could give us a few words on their experience with this product?
wootwoot is offline   Reply With Quote
Old 04-25-2013, 02:47 PM   #17
evilconcarne999
My LFA
evilconcarne999's Avatar
Drives: No Boost
No one else?
I dont get it either? If your in a higher rpm band against the same or similarly powered car with similar or less modifications in a lower rpm band, your going to pull on it just for the sure fact that you would be able to accelerate faster due to being in that higher rpm range and having more usuable power. I know even with all the lightweight modifications i have if im cruising at 35 in 6th and a similar car whether it be stock or not is sitting at 35 in 2nd or third it will pull on me just like I said above because its in a higher rpm band thus more usuable power. So I dont understand how with a final drive modification which would have you cruising in a higher rpm range and thats supposed to increase torque throughout the gears, and a noticeable torque increase, a stock car would pull on it? Especially considering you wouldnt have to downshift since you would already be at a higher rpm than the similar car. Maby im missing something...?
Im planning on getting the mfactory 4.67 final drive down the road.
WSIR 1:46.023 (Need Better Tires)
My Car Build: 171.9WHP/137WTQ (Mustang Dyno)
http://www.ft86club.com/forums/showthread.php?t=21824
My For Sale Aftermarket and OEM parts
http://www.ft86club.com/forums/showt...484#post998484
evilconcarne999 is offline   Reply With Quote
Old 04-25-2013, 02:52 PM   #18
Sonolin
All I know is @robispec is using 4.7 final drive in his track car. It posted a very good time at Willow Springs (1:35), which is a high speed track. Lots of 3rd & 4th gear turns, with a large bank to a straight at the end of the track.
Based on that and that 4.7 final drive is going to give more torque, I'd say highway pulls would be faster with 4.7 final drive. Again this is all speculation.
Sonolin is offline   Reply With Quote
Old 04-25-2013, 03:55 PM   #19
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We have the Mfactory 4.7 in our silver car now, and our red car is stock. We have some good comparisons and videos coming soon on this very subject.
FT-86 SpeedFactory is offline   Reply With Quote
The Following 4 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
lbroskee (11-10-2013), mrk1 (04-25-2013), R2RO (02-03-2015), WatchmaN (04-25-2013)
Old 04-25-2013, 03:59 PM   #20
evilconcarne999
My LFA
Drives: No Boost
Sweet looking forward to viewing the different comparisons between the 2
Old 04-25-2013, 04:27 PM   #21
arghx7
Drives: car
Every application is different, but remember that there's a reason why drag racers with muscle cars carefully spec out their final drive ratio and transmission.
Also, here's formulas to consider...
(Engine torque in newton-meters) * transmission ratio * final drive) / (tire radius in meters) = driving force in newtons . You can calculate that easy enough if you have the engine torque curve.
Driving force - running resistance = acceleration power . You can't easily calculate that in a useable way at home. If you change the final drive, your final drive multiplier increases. However, at a given vehicle speed you are now at a different engine rpm so torque might change. It's not that straightforward to predict which would be faster.
arghx7 is offline   Reply With Quote
Old 04-25-2013, 04:29 PM   #22
mrk1
Drives: Sterling BRZ Ltd
I have changed many a BMW diff to a higher ratio. I know its a bit apples to oranges but it was often a hard sell to customers but everyone came back smiling.
For me its a debate between 4.55 or 4.44, I drive highway more then I'd like to admit so I need to keep that mileage in check.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-25-2013, 04:53 PM   #23
WatchmaN
WatchmaN's Avatar
I've got my mfactory 4.67 sitting on shelf, waiting for my friend silverdub to install it, i'll surely make video and virtual dyno pull to show the differance. Simply can't wait to try that.
Old 04-25-2013, 04:56 PM   #24
OrbitalEllipses
Drives: Attitude
Samesies. Don't want to be turning 4-4.5K at 80mph, nahmean?
Old 04-25-2013, 04:58 PM   #25
evilconcarne999
My LFA
Drives: No Boost
That would be awesome to see considering im planning on getting the same exact final drive looking forward to the videos after the install.
Old 04-25-2013, 05:02 PM   #26
evilconcarne999
My LFA
Drives: No Boost
Luckly I dont do as much highway driving as I use to but I know that I will be again soon, ill just have to adjust to it. Its a modification I dont mind altering some driving mannerisms in order to figure out how to be efficient with it.
Old 04-25-2013, 05:06 PM   #27
mrk1
Is there a service manual for this car yet? I need to get ahold of the torque specs and what not for installing a new final drive.
The Build Thread
Old 04-25-2013, 05:20 PM   #28
OrbitalEllipses
Drives: Attitude
There was a service manual many moons ago, grasshopper. It might have even posted on this website. Maybe.
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 489 06-17-2018 01:14 AM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 03:21 AM
Final Fantasy jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 66 08-25-2013 11:31 PM
Suspension Calculations mla163 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-19-2012 12:30 AM
