Old 04-04-2013, 10:35 PM   #15
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Originally Posted by Touge Factory View Post
There are lots of great choices out there.
The ones you listed are more on the high dollar tier nonetheless great lug nuts.
There are pros and cons of lug nuts.
We typically use the Muteki SR48's - affordable, available in various colors, and extremely durable.
They are made out of 50BV30 steel, which is heavier then aluminum but can take a beating for years to come, and threads will hold up.
Kics R40 is another great choice for lug nuts, which is also steel construction.
Um, I see there are 2 kinds of project kics r40
So the first one is aluminum and 2nd one is steel?
shu5892001 is offline   Reply With Quote
Old 04-04-2013, 10:53 PM   #16
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I like the SR48 also, i prefer steel to aluminum as well its not like you are saving that much weight.
JoeBoxer is offline   Reply With Quote
Old 04-04-2013, 11:39 PM   #17
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I am in the same boat looking for lugs. The main thing I have read is steel over aluminum to help avoid stripping threads (not a huge issue if careful, but still a pain to worry about IMO). McGards are generally considered very good from various forums I have found in my search. But I didn't know the Muteki sr48s were steel. I was looking at those but drifted off since I thought they were aluminum, so if you want color I would think that's your best bet.
Aiden (01-11-2016)
Old 04-04-2013, 11:51 PM   #18
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
I'm using Muteki sr48s on ARP studs and I'm very happy with them. They look nice, thread and seat well and cover the entire extended ARP stud. I haven't put too much use on them yet, but I'll report back if my experience changes. The only issue with them is the very tight clearance between the lugs and my aftermarket wheels, but they do barely fit.
Sent from my Nexus S using Tapatalk 2
Old 04-04-2013, 11:57 PM   #19
OrbitalEllipses
Drives: Attitude
http://ultimatetoolco.com/kokenimpact
Old 04-05-2013, 12:43 AM   #20
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
I have been thinking about Work RS-R Lug Nuts - Red any one running them?
20valvewynn83 is offline   Reply With Quote
Old 04-05-2013, 01:10 AM   #21
Osiris
Osiris's Avatar
Drives: Asphalt FR-S
Anyone know if Muteki lugs will work with the stock wheels? I need to spend some extra money on a purchase on FT86speedfactory and can't seem to find anything that I'd need. Lugs are about the only thing I can think of that I'd want.
Osiris is offline   Reply With Quote
Old 04-05-2013, 10:20 AM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yes they will work with the stock wheels.
Old 04-05-2013, 10:51 AM   #23
shu5892001
Ontario's FT86
What have you got on your car? Maybe we can help you think of something to buy instead of lug nuts for stock rims
Old 04-05-2013, 11:16 AM   #24
JoeBoxer
JoeBoxer's Avatar
I'd probably get some engine oil, filters, or a drop in filter if he doesn't have one.
The Following User Says Thank You to JoeBoxer For This Useful Post:
Anthonytpt (04-05-2013)
Old 04-05-2013, 11:23 AM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I'd probably get a turbo kit or a supercharger kit if he doesn't have one.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
20valvewynn83 (04-05-2013), Osiris (04-05-2013)
Old 04-05-2013, 11:36 AM   #26
shu5892001
Ontario's FT86
Not exactly the type of money that he would spend on a set of lug nuts....
Old 04-05-2013, 11:45 AM   #27
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Every little bit helps.
Old 04-05-2013, 02:47 PM   #28
Osiris
Osiris's Avatar
My car is stock other than an Invidia N1. I am buying a drop-in filter on the same order. My total comes to $240 and I need to spend $250 for free shippingxD suggestions?
