#15 |
Add lightness!
Drives: 17' WRX
Just to update, the car runs perfect. No issues at all to report. I'll report back as the temps drop. Probably going to buy the P-tuning tray to fix my ghetto install so I can pass tech for next year when I track my car. I have a lightweight flywheel, crank and ac pulleys too although I'm not sure that makes a difference.
| The Following 4 Users Say Thank You to industrial For This Useful Post: |
#16 |
I use a shorai in my s2k... big thumbs up.
#17 |
Drives: Toyota 86
Hello,
I've succeccfully installed Shorai battery using re-cycled Al bracket and the stock battery tie. Cranking after 3 days was not a problem. I think that 1 week could be possible. |
#18 |
Anyone has any experience flashing the car with lightweight batteries?
#19 |
Drives: They have four wheels
I wouldn't risk a week if I could help it. Not worth the cost of being wrong. Don't know about the 86 yet, but many modern cars have ridiculous parasitic draw.
#20 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I ran the Shorai LFX14L2-BS12 in my Miata last year for autocrossing, only weighed a pound and a half. Not a lot of parasitic draw in the Miata, but if I had the (aftermarket) stereo in the car it would barely start if left sit for a week without running. When I did a stereo delete it would fire right up after sitting a week or two. I have heard of a couple of people running the same battery in the BRZ/FRS
On a newer car like the twins if not driven for more than a day or three and one of the smaller Shorai batteries is used, I'd highly recommend hooking up a battery tender to it to avoid having parasitic draw drain the battery too far. That will kill these batteries pretty quickly.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
| The Following User Says Thank You to Miniata For This Useful Post: | Anthony (10-05-2013) |
#21 |
Add lightness!
Drives: 17' WRX
#22 |
Drives: 2013 Scion FR-S Firestorm
| The Following 3 Users Say Thank You to neurokinetik For This Useful Post: |
#23 |
If you get a tender, make sure it plays nice w/ Lithium. Don't just hook up any tender.
#24 |
Battery Tender Jr, no issues with using it with my Shorai battery. Shorai states on their website "standard lead-acid chargers can be used with Shorai LFX when needed....."
#25 | |
"Yes. HOWEVER, you may NOT use a charger/tender if it has an automatic "desulfation mode", which cannot be turned off. We have confirmed with Deltran, makers of the "Battery Tender" brand, that their products do NOT have a desulfation mode, and are therefore OK for use with Shorai LFX, for example. But the best possible charger/tender for Shorai LFX is the SHO-BMS01, which will be released on about March 15th 2011, we expect. It uses the 5-pin BMS port in the LFX batteries, in order to monitor, diagnose, and balance the individual cells during charge. And it also has an optimized storage mode that will give the longest possible service life to your LFX. " All my Pulsetechs have auto desulfation. So consider yourself more lucky than good. I'm sure Shorai would be happy to sell you as many batteries as you can burn through.Battery Tender LiFePO charger: http://batterytender.com/battery-ten...s-lithium.html Last edited by Anaxilus; 10-04-2013 at 11:00 PM. |
| The Following User Says Thank You to Anaxilus For This Useful Post: | gkubed (01-09-2020) |
#26 |
No, not lucky, good. I did my due diligence and researched the issue before I put the Battery Tender Jr on my Shorai battery for the first time. I would have sprung for the Shorai proprietary battery charger/tender if necessary. I don't trust a $150 battery to "luck"
#27 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I was wondering if it would be possible to go smaller. Hmmm... the Super B isn't looking so attractive all of a sudden.
#28 |
Weight Nazi
You got a 21 for your FR-S? Did it work? Is it still working?
| Bad battery | 5hairpins | Issues | Warranty | Recalls / TSB | 3 | 02-25-2013 11:01 AM |
| Help with Car Battery | Synack | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 01-13-2013 11:05 PM |
| Winter: Electric car & battery warmer install | JSUB | BRZ First-Gen (2012+) — General Topics | 2 | 12-26-2012 11:55 AM |
| Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? | ScionFR-S | Engine, Exhaust, Transmission | 8 | 12-17-2012 06:39 AM |
| TR-B1500 battery and billet battery tray install. | mines13 | DIY (Do-It-Yourself) Guides | 8 | 12-07-2012 04:59 PM |
