Old 03-28-2013, 07:46 PM   #15
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
I'm thinking of doing this on jackstands as well. Is it recommended to do it with the car level, or is it fine to install with only the front raised?
JDKane527 is offline   Reply With Quote
Old 03-28-2013, 08:59 PM   #16
swift996
swift996's Avatar
I should be getting my FA20Club header in next week/weekend. I plan to just jack the front up since I'm using the OEM overpipe. Not sure why you'd need the rear up. I'm guessing it's probably a good idea to have something under the OEM header unit so it doesn't slam down when it's unbolted. Either another set of hands, jack, or get creative.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-28-2013, 09:30 PM   #17
sinigang_guy
sinigang_guy's Avatar
Drives: argento frs; 90 mustang gt
from the f1point4 and the instructions, the overpipe and front pipe need to removed, or at least moved out of the way to take down the manifold. need to look it up again.
also, picked up gaskets from subaru today.
head to manifold gasket: 4411ac030
manifold to overpipe: 44011ag000
sinigang_guy is offline   Reply With Quote
Old 03-28-2013, 11:02 PM   #18
jwjknorr
Drives: FRS 2013
I installed my self aswell. I am 400 miles no codes so far. I wanted to add that if you just remove the mount that holds the front pipe up, its just a couple of bolts, the whole exhaust will be able to move forward, and makes removing the orginal header easy as pie. I reused the factory gaskets with no issues, but i only have 7000 miles on my car. I also left the 02 sensors on and changed them out side the car. Look foward to you diy. I thought about it but im to A-D-D to stop and take pictures.
jwjknorr is offline   Reply With Quote
The Following User Says Thank You to jwjknorr For This Useful Post:
Pete (04-13-2013)
Old 03-28-2013, 11:11 PM   #19
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
It's taking a little longer than usual for me to get to the DIY. I'm about to downgrade my car back to NA. Sending the vortech blower back for the free upgrade.
Saw a few questions and I'd like to give some input on those;
1) It is very possible to do this on jack stands.
2) I think having the whole car level gives you more room, which makes it easier
3) I didn't think to remove some stuff under the overpipe. Good idea.
4) The header won't fall when you unbolt it simply because two welded studs at the header/overpipe joint will keep it together.
How did people torque down the middle nut on the drivers side header flange? The pipes got in my way so I couldn't get a torque wrench in there.
F1point4 is offline   Reply With Quote
Old 03-28-2013, 11:25 PM   #20
jwjknorr
Drives: FRS 2013
I used a regular 1/2 inch socket wrench , and hand wrench one on each end, and some elbow greece. In order to make sure it was torqued enough and not come loose, i recheck it a couple days later. It might to be the exact way , but i had no issues.
Old 03-28-2013, 11:34 PM   #21
swift996
swift996's Avatar
I planned to unbolt the header from the overpipe before unbolting from the head. Is that alright or should I unbolt from the head first?
Old 03-29-2013, 02:30 AM   #22
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
I may have missed it, but what is the benefit (if any) to having an unequal length header?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 03-29-2013, 11:09 AM   #23
swift996
swift996's Avatar
It changes the exhaust note considerably. There isn't any real performance benefit relative to the same equal length header. Harley Davidson does the same thing.
Old 03-29-2013, 11:16 AM   #24
swift996
swift996's Avatar
Do you just remove the front pipe from the bracket?
Old 03-29-2013, 01:24 PM   #25
jwjknorr
Drives: FRS 2013
I removed the whole bracket the front pipe needs some force to come off it, but the bracket comes right down.
Old 03-29-2013, 01:42 PM   #26
swift996
swift996's Avatar
So the two bolts above the pipe that hold the bracket? (Sorry just want to confirm and I don't have time to lift the car up this weekend):
Old 03-29-2013, 02:59 PM   #27
sweeney208
sweeney208's Avatar
Drives: red subaru brz limited
yeah, i just changed mine and that bolt is all you need to take off, it will give wiggle room to get the header off easily. also did anybody have problems with the header? I ordered mine and the flange on both sides warped badly from the welds. I tried to double gasket and still had an awful leak. I called borla and it was covered completely and they're sending me a brand new one but nobody else had this problem? I probably could have heated it and fixed it but really didn't want to bother if they will send a new one.
sweeney208 is offline   Reply With Quote
Old 03-29-2013, 03:02 PM   #28
jwjknorr
Drives: FRS 2013
the two bolts that hold the bracket yet. not the lower bolt on the exhaust pipe
swift996 (03-29-2013)
borla, header, unequal length
Borla UEL Header - Pics / Videos / Dynos - FT-86 SpeedFactory Review FT-86 SpeedFactory Engine, Exhaust, Transmission 533 04-01-2015 01:10 AM
>>>>Rev Works UEL (Unequal Length) Header - Specs, information, & Customer Review<<<< Rev Works Engine, Exhaust, Bolt-Ons 917 08-05-2014 12:52 AM
BORLA UNEQUAL LENGTH HEADER NOW IN STOCK @ NINJA AUTOSPORTS!!! NJA Announcements, Contests, Giveaways 6 04-03-2013 06:47 PM
unequal length headers 001BRZ Engine, Exhaust, Transmission 10 07-21-2012 02:20 AM
