Old 01-07-2012, 01:31 AM   #15
Slide
Drives: Toyota Aristo
Originally Posted by chulooz View Post
I dont like the stock placement, I dont like the above idea either. I am up for wiring it into the bottom triangle. Two brake lights have been sufficient in the past, Im sure it wont cause an issue with the third down low.
In Australia they require the third break light to be higher then the two main ones :'(... or I would full wire that light up as the break.
Slide is offline   Reply With Quote
Old 01-07-2012, 02:29 AM   #16
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I think the cleanest option will be a light where the Toyota emblem currently is, along the same lines as concept #3.
Does the Australian car inspection organization thing require DOT/ECE etc approved brake lights?
old greg is offline   Reply With Quote
Old 01-07-2012, 03:37 AM   #17
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Levi View Post
No, the reflectors are in the middle of the taillights, in the center of the LED circle. The low triangle light is the fog light for EU and JDM spec, in US spec it is just empty. Actually there you could put the brake light and that is what I am going to do when race conversion will be done.
You're half correct. Center part of brake lights are reflector...
It also states that, rear triangle part is rear fog lights & also a reflector.
Old 01-07-2012, 05:32 AM   #18
Slide
Nice work!!
Old 02-17-2012, 12:08 PM   #19
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
nvm
azian_advanced is offline   Reply With Quote
Old 02-17-2012, 01:07 PM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
OP, I agree 100%, that light is FUGLY. Normally I don't really care that much about aesthetics, but there's limits. I don't know about the LED's, I'm certainly open to the idea and if you can put something together that works and looks decent I just might buy. I've spent some time thinking about this as well and I haven't come up with any better ideas. I'm just worried about what will be left behind after original is removed. I was going to wait until I got my hands on the car to get a good look at it, I might just cut the stocker to make it sit flush. If it's possible.
Old 06-27-2012, 12:50 AM   #21
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
Its weird that every time I glance in the rearview I think a car is following me but its just that third brake light. I've got 1000 miles on my car and it still surprises me. I'd like to remove or move it too.
Roadstercycle is offline   Reply With Quote
Old 06-27-2012, 04:35 AM   #22
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
It blocks the rear mirror too much for my taste - even though rear view doesn't show much ..
I really don't like it and wish it wasn't there at all.
Old 06-27-2012, 09:39 AM   #23
I'm approaching 3000 miles and honestly, I don't even see it any more when I look in the mirror. Of course, it never really bothered me when I did see it. I guess I'm used to limited rear visibility.
2pt5RS (06-27-2012)
Old 06-27-2012, 11:47 AM   #24
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
It's going to be difficult to impossible to remove that light cleanly.
Subaru essentially welded the plastic housing to a plastic bracket under the package tray which is then hot-glued onto the tray.
Essentially the third brakelight housing had plastic pins that go through the black T you see in the picture. Those pins are then melted to fuse the two parts together, sandwiching the tray between.
To remove the light, the pins will have to be drilled out, and hopefully the housing will separate cleanly.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
Dadhawk (06-27-2012), Hanakuso (06-27-2012)
Old 06-27-2012, 01:36 PM   #25
ichitaka05
Site Moderator
ichitaka05's Avatar
Damn! Subaru knows how to make it hard to custom make anything
Old 06-27-2012, 02:27 PM   #26
Draco-REX
Corner Junkie
Draco-REX's Avatar
It almost makes me wonder if Toyota had a hand in this. In all my previous Subarus the third brake light was easy to remove.
Old 06-27-2012, 03:04 PM   #27
ichitaka05
Site Moderator
ichitaka05's Avatar
Maybe... Only thing I know is, it's pretty annoying
Old 06-27-2012, 03:49 PM   #28
roguetadhg
White Paper Connoisseur
Drives: 2008 VW Jetta
My experience of third-party LEDs for Auto use makes me wonder if it's worth the time.
Maybe creating a red-led light bar instead of relying on each LED to not burn out. 3 SMDs on each side.
2003 Toyota Corolla
2003 Toyota Corolla
2009 Mazda RX-8 R3
2008 VW Jetta Wolfsburg
roguetadhg is offline   Reply With Quote
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 04:48 PM
Subaru FT86 still not have the green light! ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2011 05:57 AM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 04:53 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 12:33 PM
