| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
Drives: Lexus GS350 F-sport
I don't doubt subaru will offer race oriented components at a nice profit margin for the company to people who want it. I am less sure that Subaru would do a "stripped down" version at this point. I think STI version may happen if there is a market. Anyhow its all speculation at this point. Other than a bunch of journalists gushing over the handling we have very little real performance info to go on. |
#16 |
Drives: 2003 WRX
I'm familiar with the stripped down "body in white", but that is not what I was looking for.
I do mean something in the vein of the S2000 CR or 911 RS America. A production car that is street legal, but that you could take to the track or autocross course and be very competitive right out of the box. This comes out of the fact that the original weight released for the car was around 2600 lbs, and now it looks like it will actually be almost 2800 lbs when it lands here in the US. If they were to get rid of a lot of those frilly things that don't help with going fast, and put that money towards things that do, then I think that the BRZ/FR-S would be much more appealing to those of us that want to compete in the car. IMO, I doubt that Subaru especially would do something like this because they really do not support weekend racers at all, and that is what I would like to see change most of all. |
#17 | |
Registered you sir
Drives: 99 impreza coupe
#18 | |
http://www.ft86club.com/forums/showthread.php?t=3104 Most of us think it's Ej swapped.. |
#19 |
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
I'd certainly hope it isn't EJ swapped, considering we already know they have FA turbo engines in the works. However being if it's just a drift team without engineering support, it may very well be just a shell with an EJ dropped in. It would be simple enough to do.
#20 | |
Registered you sir
Subaru's.They mean it when they call these cars Legos, most of the stuff you mentioned should be able to fit. This isnt about being cheap, its about building your own car. If its done with patience and know-how it can be much cheaper than you assume, but you do have to pay to play in the end. |
#21 | |
Site Moderator
Drives: Stuff
All you need from the 04 STI is rotors. Any 04-11 STI front calipers bolt up (although won't be proper as discussed in some brakes threads) and 04-07 rear calipers... and the parking brake stuff if you want the parking brake to function.. and pads of course. A BIW BRZ will be at least 5k if they ever sold it. Add in all of the parts to build it as a race car and there is no way you'll be under 15k IMO.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#22 | ||
MODERATOR-SAMA
Drives: Swagtron Scooter
#23 | |
Site Moderator
Drives: Stuff
However, fitting doesn't mean working correctly due to the caliper design and mounting location, UNLESS the STi/STI calipers have a second spot for a bleeder on the opposite end of the caliper. The reasoning for that is that the calipers are differential-bored so they are directional. If you keep the left on the left but move it from the rearward side of the rotor (like the STI is) to the frontward side of the rotor (like the BRZ) the pistons will be correct but the bleeder will be on the bottom, which isn't good. If you swap sides, the bleeder is fine, but the piston bores are backwards, which also isn't good. So literally the *ONLY* 2004 STI dependant part are the rotors. Nothing else. A much cheaper upgrade will hopefully be newer LGT front rotors and caliper brackets (and maybe calipers if the BRZ calipers have smaller pistons and/or don't fit on the LGT brackets). And that's assuming a brake upgrade will be needed. It absolutely WILL NOT be needed for the street, and even on track cars will only be needed if the OEM brakes can't keep up with the repeated high speed stops, assuming the car has enough power to even experience repeated high speed stops without cooldown (assuming track pads and good fluid). If you are doing it for looks none of this would probably concern anyone though. Price difference for the same model and size wheels just because of the bolt pattern btw? Example? I've never seen that.
-Dave
#24 | |
#25 | |
Site Moderator
Drives: Stuff
You need new rotors for any year STI calipers as they are spaced off the knuckle to accept the larger 12.8" STI rotors. If you skip that part you won't have much brakes at all. This has already been done on a BRZ without changing knuckles/hubs by Greddy, just using 2004 STI rotors. I've seen two stories for the rear.. first is: The rear STI calipers from an 04-07 also bolt right onto the BRZ, but you won't have a parking brake (due to the drum parking brake used on the STI vs the BRZ using the sliding caliper). Second is: You need 08+ STI calipers and redrilled 08+ STI rotors. Greddy already did both ends of the car, without changing the knuckles or using any special adapters/parts. Oh and here: http://www.motoiq.com/magazine_artic...cion-fr-s.aspx Personally the expense of the parts outweigh the need/benefit for me, especially considering the potential caliper issues (differential-bored piston/bleeder issue). The newer LGT fronts are almost as large (12.4"x30) but can use a simple sliding caliper. Yeah, not good for looks, but they work fine. Even the stock brakes are made for cars weighing in at 3200-3400lbs or so, they will be awesome in this car on track IMO.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles Last edited by Dave-ROR; 01-03-2012 at 11:35 PM. Reason: clarified some stuff |
#26 | |||||
Rocket Surgeon
Drives: PSM GGA OMG
#27 |
Drives: Slowly
Dave-ROR is 100% correct. I'm not sure what the other poster is on about.
#28 |
Drives: Slowly
Subaru have for a long time sold bare bones race cars. They are for real race teams, not people who want to build street cars. As pointed out, they don't have RIN plates and cannot be registered. Generally they only suit those who are building to GroupN specs as even those cars are full of stuff that a dedicated track car would throw in the bin.
Thought I'd check back on this forum to see if the level of discussion had improved. It hasn't. |
| North America to get Subaru version but not Toyota version? | Ground N Pound | BRZ First-Gen (2012+) General Topics | 42 | 05-29-2014 01:23 AM |
| Production Subaru BRZ Revealed! (Press Release + Photos) | Zaku | BRZ First-Gen (2012+) General Topics | 231 | 12-13-2011 10:28 AM |
| Subaru BOXER Sports Car Architecture Press Release | Deslock | Engine, Exhaust, Transmission | 13 | 04-06-2011 07:09 PM |
| The ABT R8 GTR - A Motorsport Champion For The Road | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 03-03-2010 01:26 AM |
| No Subaru FT-86 for Australia! And currently no Subaru AWD version production plans. | Edi | BRZ First-Gen (2012+) General Topics | 103 | 10-27-2009 03:27 PM |
