Old 12-26-2011, 06:50 PM   #15
Chupacabra
'it's the yeti of Texas'
Chupacabra's Avatar
Drives: 2013 Whiteout 6MT FR-S
Originally Posted by Ribface View Post
I don't think the 86 would be competitive against the S2000.
I'd say it all depends on the course layout. Larger gates with elongated straights will allow the S2000 to breathe, but a more technical course could allow the lack of low-end torque to be present.
We will all be able to really see what this baby can do in a few short months
Chupacabra is offline   Reply With Quote
Old 12-26-2011, 07:09 PM   #16
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
yes. should be good fun.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 12-26-2011, 07:14 PM   #17
NA_T
NA_T's Avatar
Drives: E36
If there only were autocross events in Belgium.. I wouldn't hesitate
NA_T is offline   Reply With Quote
Old 12-26-2011, 07:22 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I am hoping for STX, I don't think the 86 would be competitive against the S2000.
Except for one street tire car and a few r comps my ITR beats the local S2000s so I sure as heck expect to with the ft too.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-26-2011, 07:58 PM   #19
Thrashy
Drives: 1991 Honda CRX
Could be. Right now in STR, the S2000 dominates on more open courses, but loses to the lighter NC Miata on tighter ones. On paper, the FR-S slots in between those two cars, but there are a lot of unknowns. Without roll center adjusters (not legal in Street Touring) the front end will be have dynamic camber issues when lowered versus the competition in STR (though with the low cg it may not need to be lowered much, anyway!). The car has what looks to be an integrated cat on the header, which could throw a wrench in the works for adding power under the STR rules. It also remains to be seen how much weight can be shed.
In STX, it's basically a RWD, 80% scale WRX, which could be a major threat to the class right out of the box. Who knows?
Last edited by Thrashy; 12-26-2011 at 11:13 PM. Reason: edited to correct dumb terminology error >.<
Thrashy is offline   Reply With Quote
Old 12-26-2011, 08:18 PM   #20
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I plan too
Should be fun with a tossable car like this and who knows maybe we will run against each other in Vancouver
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 12-26-2011, 08:22 PM   #21
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Will you Autocross your 86?
Yes
Deslock is offline   Reply With Quote
Old 12-26-2011, 08:33 PM   #22
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Hells to the yeah!
Originally Posted by Thrashy View Post
Without camber adjusters (not legal in Street Touring)
That"s weird...so eccentric bolts are not legal in Street Touring but they're legal in Stock class?
RiskyTrousers is offline   Reply With Quote
Old 12-26-2011, 09:04 PM   #23
Ribface
Drives: 2014 FR-S Hot Lava
Without camber adjusters (not legal in Street Touring) the front end will be camber-challenged versus the competition in STR
Not sure where you got that notion, camber plates are perfectly legal in Street Touring.
14. STREET TOURING CATEGORY
14.8 SUSPENSION
C. The following allowances apply to strut-type suspensions: Adjustable
camber plates may be installed at the top of the strut and the original
upper mounting holes may be slotted. The drilling of holes in order to
perform the installation is permitted. The center clearance hole may
not be modified. Any type of bearing or bushing may be used in the
adjustable camber plate attachment to the strut. The installation may
incorporate an alternate upper spring perch/seat and/or mounting
block (bearing mount). Any ride height change resulting from installation of camber plates is allowed. Caster changes resulting from the
use of camber plates are permitted.
http://scca.cdn.racersites.com/prod/...lo%20Rules.pdf
Ribface is offline   Reply With Quote
Old 12-26-2011, 09:07 PM   #24
Thrashy
I meant roll center adjusters, but I was thinking about camber curves. Derp. But yes, camber adjustment via camber plates or crash bolts is completely legal, so dialing in plenty of static camber should be a piece of cake. I'm more concerned about how low the car can go without the front roll couple becoming an issue.
Old 12-26-2011, 09:23 PM   #25
Ribface
Very likely I attend nearly all VCMC and UBCSCC events
Old 12-26-2011, 09:37 PM   #26
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
It will have a hard time in STX especially against my MINI S JCW. LOL
Anyways the popular classes the car should be in is:
CStock
STX (STR if it was only a 2 seater.. luckily it isn't)
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline   Reply With Quote
Old 12-26-2011, 09:52 PM   #27
NastyNate
Drives: 05 MazdaSpeed Miata
Classing will be interesting. Stock my miata is c class amd the wifes cooper s is d stock. But I get to play with the big boys in bsp. Cant wait to get some 15x9's so I can at least feel competetive.
Fast in the straights is for everyone else. Fast in the corners is for me.
NastyNate is offline   Reply With Quote
Old 12-26-2011, 10:00 PM   #28
rmagic
Drives: evo x
Yes, I will race it in autocross, and I have been doing autocross for a while. It is hard to say how it will handle against the s2000 but for sure gt86 needs better tires to be able to run with s2000 and miata. Based on experience, I would say this car will run better in a medium to larger layout and the reason is that gt86 will have stiffer chassis and longer wheelbase, which will be used better in faster corners, and will be able to carry more speed. I would see this car be more competitive when you start to change the coilover, tires, and wheels. The way they set up this car out of factory is not for grip, based on the video and reviews that I saw so far (maybe I'm wrong). It's just because the car has lots of potential and if you start to use that you will get full benefit out of it. When you modify s2000 or miata, both of which I have owned, they have limits to their performance based on the modifications, but I think gt86 will have less limitations because of its setup. I just hope everything I said above will come true as it's only based on the information available on the internet. Don't hold me accountable.
rmagic is offline   Reply With Quote
