Old 12-22-2011, 01:45 PM   #15
oneday
Opinionated
oneday's Avatar
Drives: Something Red
Originally Posted by oneday View Post
OEM STI 4-pot front calipers/rotors/pads can be gotten for under $800. Rears would be a little less. I'd say $1500 for all four corners, if you buy new parts...find some used ones from some baller that opted for a StopTech BBK and you might score a set up for under a grand.
Correction: I was looking at the WRX 4-pots...but then found a plethora of STI Brembos on Ebay for $1050...so I wasn't too far off. I am working on getting new OEM pricing from my supplier.
Most of the cars I drive have nets for windows.
oneday is offline   Reply With Quote
Old 12-22-2011, 01:47 PM   #16
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
Yeah I saw all the ones on ebay as well, and I am sure there are NAISOC and other Subaru based message boards w/ guys that have swapped to aftermarket kits
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-22-2011, 01:48 PM   #17
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
I assume that $1050 is for a used setup?
Once you hear pricing from your supplier, I would be interested in knowing what they say.
tranzformer is offline   Reply With Quote
Old 12-22-2011, 02:23 PM   #18
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Hmm.. I really hope that the front roll center is only that low because of the low front c.o.g. Large roll couples make me a sad panda.
old greg is offline   Reply With Quote
Old 12-22-2011, 03:11 PM   #19
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Agreed. In the article they did plead to Whiteline to hurry up and get an extended outer ball joint in their catalog. ...or, these already work, however the delta means ride height lowering is still limited to "not much".
Also, updated my post to reflect potentially more accurate brake fitment information. Looks like it may not be straightforward '04 STI brakes afterall.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 12-22-2011, 03:34 PM   #20
JDLM
JDLM's Avatar
What do you believe would be needed for it to become a direct fit?
Old 12-22-2011, 03:49 PM   #21
Longhorn248
Hook 'em
Longhorn248's Avatar
+1 I would be interested in the Brembo Sti upgrade simply because I think they look better than what we've seen on release cars so far.
Longhorn248 is offline   Reply With Quote
Old 12-22-2011, 03:50 PM   #22
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
I was wondering how long it would take for this to pop up here. I saw Mike post it on facebook this morning, as he does with ALL motoIQ articles lol
I suspect the rears will need adapters to mount and then assuming GD style rotors fit, adapter brake shoes for the parking brake. If GR (most likely) then it'll be adapter, shoes and drilling rotors for 5x100 lug pattern.
I need to go back through the pics and look more closely as when I read it this morning, I was in my suspension dork mode
Homemade WRX is offline   Reply With Quote
Old 12-22-2011, 04:04 PM   #23
BeachNative
Drives: 04 G35/6MT
I'm thinking an upgrade to the Brembos (w/steel lines) is going to be a must...
BeachNative is offline   Reply With Quote
Old 12-22-2011, 04:07 PM   #24
Silverpike
popular among the JDM
Silverpike's Avatar
Drives: 2014 BRZ Limited
Good to read them confirm that '04-'12 STI front brakes and '08+ rear brakes are a direct bolt-on along with '04 STI front rotors and redrilled '08+ rear rotors. This makes brake swaps quasi-compatible. Next someone needs to find if the newer Subaru hubs bolt on w/ 5x114.3 pattern.
This is already an investigated issue in the Subaru world. The hubs are very different between 5x100 and 5x114, and they are not interchangable. There are companies such as 6gun Racing which used to sell machined 5x100 knuckles adapted to fit 5x114 hubs, but they were >$1k. I think 6gun is even out of business now, so you can't get them anymore.
What worries me about the BRZ is if they are using the WRX 5x100 hubs. If so this is bad news. These hubs have problems with premature bearing death, especially when autocrossed. They are a huge PITA to replace, and new bearings are $$$ from Subaru. The 5x114 hubs have larger bearings, and are known to be much more robust when tracked. There's a huge subset of Subaru guys who converted their entire car to 5x114 not for wheel choice, but to switch to the larger bearings which don't fail so easily.
My 02 Bugeye has bearings on the way out. It's almost 10 years old now, and went through about 3 auto-x seasons. If I were planning on keeping the car, I would have to do the bearings.
Silverpike is offline   Reply With Quote
Old 12-22-2011, 04:14 PM   #25
JDLM
JDLM's Avatar
If mine gets back to me I'll post up info as well
Trying to do "suspension packages" so it will be a 1 stop bundle (obviously a GB would lower prices/cost for everyone)
Old 12-22-2011, 04:15 PM   #26
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
I'm right with you on the bearing death in my bugeye, but it is due to heat transfer from the brakes which shouldn't be as much of a problem on this car. Plus I think in the 10 years that have passed they might have improved them somewhat. It sounds like my 4 pot brakes will swap right over which is awesome.
Spaceywilly is offline   Reply With Quote
Old 12-22-2011, 06:39 PM   #27
Silverhks
Drives: 07 STi STU #17
I agree spacewilly.
I think that with the 10 yr development in materials, AND that they are not driven meaning less force transfer, AND that the car weights ~200 lbs less, AND that it handles better so you shouldn't need to scrub as much speed...
All SHOULD add up to better bearing life
Silverhks is offline   Reply With Quote
Old 12-22-2011, 06:58 PM   #28
Racecomp Engineering
Yeah the wheel choice thing is the smaller problem IMO with 5x100 hubs, the main problem is the bearings. But I'm cautiously optimistic it won't be a problem for most people.
I look forward to plotting the roll center and looking at in relation to the COG. Might be fine but it looks like slamming the car isn't going to be a good idea if you care about handling and don't do anything about the roll center. And who knows how much travel it has.
Brembos will look nice on the car.
- drew
fr-s brakes, fr-s differential, fr-s forums, frs brakes, frs differential, frs forum, frs forums, scion fr-s brakes, scion fr-s chassis, scion fr-s diff, scion fr-s forum, scion fr-s forums, scion fr-s suspension, scion frs brakes, scion frs chassis, scion frs differential, scion frs forum, scion frs forums, scion frs suspension
MOTOIQ A Tech Look Under The Scion FR-S poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 0 12-23-2011 03:45 AM
Confirmed Torsen Differential Andy Engine, Exhaust, Transmission 50 12-12-2011 11:01 PM
Stretched FT-86 chassis to spawn next generation Lexus IS Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 17 12-02-2010 02:27 PM
Brakes, track set up? CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-29-2010 08:16 PM
