Old 02-20-2013, 08:26 PM   #15
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Originally Posted by fatoni View Post
how many times have you driven off the road as a fairly skilled driver? on a more serious note, bracing yourself is bad for accidents. that emt was either lying to you or he is an idiot. the additional strain of your body against the forces (that are beyond combatable from the strongest of human beings) would only cause additional damage. its they reason why its always the drunk driver who survives and the innocent party who is injured.
either way, errr, congrats? sorry? i hope your new frs treats you right.
Gokarts racing since I was 7 and spirited drives through local mountain roads over the past decade. Very little experience in rain. Here in San Diego, we see maybe 10" of rain sporadically in a year. Because of that, whenever it does rain, it's just enough to slicken up all the oils and other fluids on the road, but not enough to wash them away. As far as bracing, the speeds were slow and the impact was relatively gentle. The local paramedic said most injuries like whiplash come from flailing rather than direct contact. A good friend of mine who drives a box as an EMT said that sounded about right, but who knows. In the proper stance, I can rest 400 lbs on my back without flinching, squat 295, and dead lift 355, so it was more of an instinct reaction over anything else. The lack of injury is most likely do to the small severity of the crash. It just LOOKS like it was a lot worse than it was.
cfusionpm is offline   Reply With Quote
Old 02-20-2013, 08:29 PM   #16
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Bummer man, Glad your okay. And welcome to the frs family
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 02-20-2013, 08:30 PM   #17
cfusionpm
Originally Posted by BlaineWasHere View Post
This is true. Watch racecar drivers right before they hit a concrete wall at 180 MPH. They usually close their eyes, exhale, and relax. Tightening your body will only make a FAR worse.
Good to know for the future. Though I hope to not be in that situation to begin with!
The Following User Says Thank You to cfusionpm For This Useful Post:
BlaineWasHere (02-20-2013)
Old 02-20-2013, 08:31 PM   #18
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Being stronger just means you can hurt yourself even MORE if you tense up in a crash. It just wasn't a hard crash at all.
I'll back up the OP on rain not being the same out here. I used to live in Michigan and I've driven on slipperier wet roads out here than snowy roads back in Michigan. When it doesn't rain for 10 months a ton of oil and other shit accumulates, then it rains and all the oil sits on the surface of the water and the roads are like ice.
Old 02-20-2013, 08:33 PM   #19
cfusionpm
Originally Posted by carbonBLUE View Post
yeah and the frs is about 100x more tail happy in the wet especially on stock tires than a Tc
lol
Rears were practically bald. Had been meaning to replace them but was putting it off. They still had life in them.... as long as it was dry out! I've never been good on wet ground in the first place. All the stereotypes about California drivers and rain are absolutely true. That day, there were about 330 other accidents around the county.
Old 02-20-2013, 08:34 PM   #20
bdub85
bdub85's Avatar
Drives: 2013 Raven FR-S
It's actually better to flip your car then say coming to an abrupt stop by hitting a wall or something. The instant stops are what kills people. Think Dale Earnhardt in the Daytona 500 when he hit the wall. The flip(s) allow the energy to bleed off and come to a slower stop.
bdub85 is offline   Reply With Quote
Old 02-20-2013, 08:37 PM   #21
BlaineWasHere
Grip>Drift
Drives: FRS
Your physics theory is correct but your reference isn't relevant. Dale died due to a harness failure that caused his neck to snap. The impact in that crash was relatively low compared to most stock car crashes.
Old 02-20-2013, 08:41 PM   #22
Lonewolf
Lonewolf's Avatar
Drives: Moped
Regardless, glad you're okay!
Old 02-20-2013, 08:41 PM   #23
fatoni
yeah im from orange county so im plenty aware of our "seasons." i was just messing with you because i am a little bit of a **** on the internet.
as far as the medical stuff, ive been a medical professional for quite a while and can assure you that relaxing is a better bet than stressing. there is also actual data to imply that im correct. my favorite is that from drops under 30 ft, cats will injure themselves due to the tension in their extremities. after the first few seconds they relax and basically can fall forever (since the terminal velocity of a cat is relatively low). more professionally, i think there was a test where they put professional rugby player in a crash and even at 20-25mph, he was not able to hold on to a rugby ball. if a professional athlete is unable to hold on to a ball weighing in at .5 lbs, i dont think you can keep your body stabilized at 200 lbs or whatever it may be at double the speed since the forces would be roughly quadrupled. either way, glad youre fine
The Following User Says Thank You to fatoni For This Useful Post:
cfusionpm (02-20-2013)
Old 02-20-2013, 08:41 PM   #24
bdub85
bdub85's Avatar
Yeah that's true. They did come out with the HANS device after that I believe which helps protect the neck/head. But essentially that's how people die from accidents by hitting something and decelerating at a rapid rate.
Old 02-20-2013, 08:45 PM   #25
cfusionpm
Allan McNish's crash from the 2012 Le Mans is probably a great example of energy distribution/rolling reducing a crash's intensity on driver:
[ame="http://www.youtube.com/watch?v=JW3NDGk6YQE"]AUSmotive: Allan McNish crash Le Mans 2011 (HD) - YouTube[/ame]
Old 02-20-2013, 09:14 PM   #26
Giccin
Giccin's Avatar
Glad your ok bro!
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 02-20-2013, 09:23 PM   #27
pkny
Drives: Firestorm FR-S 6MT
Long time Scion owner, but first time joining here thanks to my new FR-S purchase. I've had my tC RS1 for nearly 8 years and had the misfortune of an accident about two weeks ago now. Going around a freeway transition ramp in the rain, I hit a pocket of water that kicked the back end loose. I tried to correct and steer into it, but the tires slid onto the grass. I don't know if anyone has driven on wet grass before, but as soon as you touch it, you're off. It's not the first time I slid on wet grass before, but this was a perfect storm for disaster. Rather than flat ground, the grass embankment was about angled down about 20-30º. When the car started to slow, the wheels dug into the mud and flipped it 180º onto the roof where it slid maybe another 10ft and stopped. The whole process was relatively slow and the speeds were around 40-45mph.
I was mostly calm through the whole endeavor. All I was thinking was I'd have to have a tow truck pull me out of the mud and I'd be late to work. On flat ground, the worst thing that could happen would be hitting a pole, curb, post, guard rail, or just getting stuck in mud. It wasn't until I was about 90º sideways that I realized it was rolling and braced myself. I've been weight lifting on a strict regiment for over two years and instinctively put my body in the most stiff and secure posture, tight core, neck, shoulders, etc. The EMT said that alone could have saved me from a lot of injury. I walked away from this without a scratch on me. I had a small bruise on my right leg and a small scrape on my left hand, but I think the bruise was from climbing out, and the scratch was from sifting through the wreck to get personal items out of the car.
Been driving for more than 12 years and I consider myself a fairly skilled driver, but accidents can happen to anyone. I am really sad that I lost my RS1 though; like I said, I've had that car 8 years and had no intention of giving it up any time soon. I am truly thankful to have come out of that unharmed though, and seeing the condition of the car really solidified my view on Scion and the safety standards of their cars (at least the tC).
I've been a big fan of the FR-S since I first heard about it nearly two years ago. Was on the waiting list to get one since March of 2012, but bought a condo in the middle of last year and a new car wasn't in my finances. I've been in contact with my particular salesman at the local dealer ever since though, and we both knew it was just a matter of time for getting one.
Well this event had made the choice for me! Lucky enough, I got a good claim check from insurance, and combined with my tax return put nearly half the value down for a new FR-S. It's being processed at the docks in Long Beach today, and should be down in San Diego for pickup by tomorrow or Friday. I can't wait!
Same here. My '05 tC was crashed, and then I got the Firestorm FR-S.
Ironically enough, I probably got more from insurance than I could have selling it private party!
The insurance paid me very good. With all the compensation, my FR-S was almost free.
2013 Scion Firestorm FR-S MT
pkny is offline   Reply With Quote
Old 02-21-2013, 02:20 AM   #28
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
That's why I don't mess around with tires. I don't even like summer tires because of their lack of tread/grooving/sipes for hydroplaning resistance. If you slip on something, you can still control it but if you hydroplane in a turn, you're pretty much screwed. Also, it's always better to put the tires with less tread up front for that reason.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Second Scion FR-S crashed in California Skywgn1 Scion FR-S / Toyota 86 GT86 General Forum 61 03-02-2013 09:48 PM
Picked up my new Firestorm FR-S last Friday! dale.m Scion FR-S / Toyota 86 GT86 General Forum 11 10-07-2012 10:14 PM
Picking her up at 5! remorse87 Scion FR-S / Toyota 86 GT86 General Forum 14 10-07-2012 10:51 AM
FRS crashed in Miami? Sportsguy83 Southeast 9 09-14-2012 10:05 PM
who crashed Toyobaru808 Hawaii 3 08-24-2012 08:15 PM
