Old 02-19-2013, 08:46 AM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Orthow View Post
Why would you install an oil cooler in the winter as there would be no way to test any improvements?
Oil coolers are hugely OVER HYPED on this forum.
If the 2014 FRS/BRZ comes factory with an oil cooler then you will have evidence to the fact of needing an oil cooler. News flash.. there will be no such cooler.
Some of us track our cars in the winter. I'm tracking mine two days this weekend.
Oil coolers are great for track cars. Not so much for a street car. I also run an endurance car without a cooler so while I wouldn't say its required its not a bad idea either.
Honda put a l2l oil cooler on 94-95 GS-Rs but then removed them (added back for all ITRs though). Does that mean they weren't ideal or just a cost cutting measure? OEMs focus on cost not what is ideal for the minority of buyers that track their cars.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 08:49 AM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by brillo View Post
What is the magic number in terms of oil temps you don't want to exceed? 212f? I'm monitoring my oil temps now.
212 is nothing. I'd like to stay around 250-270 on track. Based on experience with other cars these likely see 300 or more on track. On the street an oil cooler is basically pointless IMO. So far with my cooler I haven't gotten past 180 on the street.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 09:55 AM   #17
Racecomp Engineering
Several things. No I didnt install it myself. I had one of my techs install it. I spend my time doing other things BUT did want to relay to the community what my initial impressions were with regards to how easy the install can be.
I also make mention of the kit being very "complete" and good for someone without much time on their hands.
I also said that I haven't tracked it and WOULD report back once I did. It is very well documented that these cars loose power once oil temp rises in normal driving let alone track driving. I also do make note that its winter here.
We will have some data/info once its tracked.
Lots of people have noted the small differences in power that they "feel" or dare I say " think they feel" from hard driving this car. I for sure do coming from a car with much more power.
We installed the cooler NOW because our track season starts early next month. I already tracked it last year to know that once it gets hot you're for sure loosing power.
For those who found it useful (pictures and me telling you that its a complete easy to install kit) glad you liked it.
For those who didnt, sorry I wasted your time for a review without data or data logging.
Myles
Old 02-19-2013, 10:12 AM   #18
Just edited this.
Peace.
Myles
Old 02-19-2013, 10:15 AM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
There wasn't a need for the edit. Don't sweat it Myles. And I always like pictures
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 10:21 AM   #20
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Not sure why people are so hostile about certain things, for a track car you obviously want to be able to keep your oil temps lower and for a forced induction street or track car i think its a no-brainer. If you can spend $5-6k for a turbo/supercharger you have $700 to spend on an oil cooler. If you don't then you shouldn't be adding FI anyways because how are you going to afford to fix it if it breaks?
JoeBoxer is offline   Reply With Quote
Old 02-19-2013, 10:38 AM   #21
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Didn't mean anything negative. I'm honestly wondering if there is something wrong with our cars if you can feel a difference on the street from an oil cooler. I'm still mulling over robispecs total solution personally.
industrial is offline   Reply With Quote
Old 02-19-2013, 10:46 AM   #22
2forme
Doesn't look like it's compatible on cars that have intercoolers....
Old 02-19-2013, 10:50 AM   #23
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
It sure is: http://s1359.beta.photobucket.com/us...y1989/library/
Old 02-19-2013, 10:51 AM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I bet you can mount it further back. My cooler is mounted further back since it's a larger cooler and won't even fit under the bumper support without the lines attached, let alone with the lines attached.
Hard to tell for sure if RCE mounted the cooler completely behind the support or not. Anyways, I have room with my setup to mount an IC under the bumper support without touching the cooler.
Now I'm not sure I'd run this type of cooler with an IC, I think I'd just go L2L with a solution like Robispec's then, but I do think you could make it fit just fine especially with the smaller 13 row cooler used here.
Edit: Or mount the cooler up front like the example ATL posted.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 10:53 AM   #25
RYU
RYU's Avatar
Drives: really slow...
I'm not sure if this oil cooler has a thermostat. If it does you don't need to worry about running too cold. Remember.. even with today's multi-weight oil cold oil is not particularly great for your engine.
Empower yourself with a Scangauge of some sort. The OBDII system in our cars can track oil temps (unfortunately not oil pressure). Buy a Scangauge. Monitor your temps. If they go above 230F+ for the driving you do for the conditions you're in.. then it's time to look into an oil cooler.
This isn't necessarily one of those *bling* items you want to install to look cool at the local car meet...especially if it doesn't have a thermostat.
RYU is offline   Reply With Quote
Old 02-19-2013, 10:54 AM   #26
Turbowned
Turbowned's Avatar
Looks like a nice piece. I ought to add it to my mods list.
Old 02-19-2013, 11:01 AM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I believe that they use a thermostat but I also believe it's a Mocal so it's partial bypass when cold.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-19-2013, 09:29 PM   #28
ATL BRZ
ATL BRZ's Avatar
@Racecomp Engineering, did you monitor oil pressure before or after the install of the Perrin OC?
@Dave-ROR, are your pressures okay with the Mocal currently? I haven't checked your related thread recently.
real world mpg frs/brz muffinman Scion FR-S / Toyota 86 GT86 General Forum 131 07-13-2017 02:26 AM
You want it, you got it: PERRIN Oil Cooler GB JoeBoxer Groupbuys 96 06-16-2013 03:10 PM
Perrin oil cooler group buy? white devil Engine, Exhaust, Transmission 6 02-10-2013 03:17 AM
Real-World Data importing into GT5 SnapOv3st3r Other Vehicles & General Automotive Discussions 0 09-07-2012 06:25 PM
Actual experienced real world fuel mileage MPG? R8 Scion FR-S / Toyota 86 GT86 General Forum 88 07-24-2012 07:50 AM
