Old 02-05-2013, 01:59 AM   #15
robispec
Drives: Black frs project
saved for driver?
just for you!
robispec is offline   Reply With Quote
Old 02-05-2013, 02:01 AM   #16
robispec
How did you get those vents in the bonnet? It looks a little neater than what could be obtained just using tin snips.
it is a die that stamps them out one at a time major PITA
I have a guy close that does these for the rock crawer Jeeps so I hit him up!
Old 02-05-2013, 02:03 AM   #17
coyote
coyote's Avatar
Drives: Slowly
Yep, I thought as much. I'm really interested in the pressure and temp differential as I'm also looking at some venting.
Whoever did yours has done a really neat job.
coyote is offline   Reply With Quote
Old 02-05-2013, 10:37 AM   #18
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
Looks good...
I heard you guys deleted both front and rear bumper beams and was wondering if any bracing was used in their place or not.
Also, do you happen to know the weight of those stock bumper beams?
Looking forward to your radiator/oil cooler group buy...
Thanks!
Anorexic 86 is offline   Reply With Quote
Old 02-05-2013, 10:38 AM   #19
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Makes me want to get one of these cars even more now. Nice work! Can't wait to see what else you do with it.
GTM_Challenge is offline   Reply With Quote
Old 02-05-2013, 12:19 PM   #20
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
Originally Posted by robispec View Post
SO here are some picts and info on our SUPER HEAVY DUTY COOLING UPGRADE
we are ready to go to market with these this week.
At Robispec we are fans of extra credit work and so we went to an "overkill cooling solution" stock radiator is 15mm core we replace this with 2 25mm tube core add a liquid to liquid oil cooler in the "cold side tank" and have less than 2 feet of total lines to complete the whole "kit".
The best thing about this is that you dont need to thermostaticly control the oil temp (a big potential problem with the Air to liquid cooler solutions) as the water thermostat does this for you and actually heats the oil faster during warm up then stabilizes it to run about 20-30 degrees hotter than the water temp. this is better in many ways than the current kits on the market.
1. lighter overall
2. short hose runs,minimal resistance to flow = no extra strain on the stock oil pump
3. "fixes" the Water cooling issues sure to develop with the stock radiator.
4. Uses existing cooling airflow and leaves fender locations for brake ducting
5. With low profile fans ADDS space in front of the engine for turbo/SC piping
Picts in the car
here are the cores for comparison. BIG PROBLEM and no oil cooler included with the car either.
Even the A/C condensed is thicker than the Stock radiator!(3/4" vs 5/8 ")
here is the BEST solution...to the above problem
system out of the car
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 47KB. This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 47KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 52KB. This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 52KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 83KB. This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 83KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 44KB. This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 44KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 75KB. This image has been resized. Click this bar to view the full image. The original image is sized 1024x575 and weights 75KB.
can use stock A/C with this.
NO cutting plastec to mount
Cold air over the top as needed
STOCK mounting points used
OVER TRIPLE THE COOLING CAPACITY and an extra Qt of engine oil.
takes 2 hours to install
total system cost Radiator oilcooler takeoff plates hoses, an fittings, fans
EVERYTHING INCLUDED for John Q Public to install $1,195.00
Look for the group buy to save money on the first ten of these.
Robi
Lovin' the radiator/oil cooler setup!
Mark Slide Squad is offline   Reply With Quote
Old 02-05-2013, 07:57 PM   #21
xwd
Nice are you going to be selling the front and rear brake setup?
Old 02-05-2013, 08:51 PM   #22
zkubidu
Drives: SWP BRZ
Sub'd for the radiator setup alone....
zkubidu is offline   Reply With Quote
Old 02-05-2013, 09:55 PM   #23
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i think you guys need to get a protector plate for that rear diff, holy smokes is it low to the ground.
Old 02-05-2013, 10:14 PM   #24
aced86
aced86's Avatar
Drives: 2013 frs asphalt m/t
Got to Ride in this with robi . Awesome work car is amazing on the track and robi is probably border line crazy behind the wheel on track. After a track run with him it's truley a testament to our cars and his great design and suspension work , I highly recommend robi
aced86 is offline   Reply With Quote
Old 02-05-2013, 11:22 PM   #25
robispec
Originally Posted by Anorexic 86 View Post
Looks good...
Thanks!
No bracing needed (you need to PROVE to me a bolted on brace is needed before I give back any of my hard won weight reductions!!!)both end beams held on with 4-6 6mm bolts these just hang them in place lol cant add any meaningful torsional strength. I mean we had a viper with a 10 point engine cage 6 on the firewall with 5/8ths bolts holding it to the fire wall and it STILL MOVED on a 7 post rig! we had to make interferance cones and press the hat on to the cone with the bolt before we lost the flex!
think I have them somewhere and can weigh them
Robi
Old 02-06-2013, 03:40 AM   #26
robispec
agreed already have drag marks! but the iron case has a thikend area designed to take the hit while protecting the aluminum rear cover..But we ARE testing their design criteria!
RObi
Old 02-06-2013, 11:21 AM   #27
Racecomp Engineering
Nicely done! Always lots of respect for robispec!
- Andrew
Old 02-06-2013, 09:59 PM   #28
TRev
Glad to see you here and doing things for the BRZ!
TRev is offline   Reply With Quote
Canu_50's FR-S Time Attack, drift car!! canu_50 Member's Car Journals 28 12-05-2013 02:04 AM
My FR-S In Time Attack Mode!! track_warrior FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 09-25-2012 02:13 AM
Ontario Time Attack - TMP July 7th 7thgear CANADA 8 07-07-2012 06:14 PM
Vancouver auto-cross, time attack.. ? EsoBOFH CANADA 4 06-20-2012 03:23 PM
Tsukuba time attack review in the Car Top magazine yajin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 05-18-2012 05:12 PM
