Old 01-25-2013, 10:33 PM   #15
_F-R-S_
Drives: 13 whiteout scion frs
Originally Posted by NemeGuero View Post
I doubt its linked to the cruise control. I've had my wheel installed for a month at least with the WB hub and resistors and I know for a fact my traction control is operational. Pics of your resistors? Did you get both connectors?
You say all this bit you never display pics
_F-R-S_ is offline   Reply With Quote
Old 01-25-2013, 10:33 PM   #16
03Z33
drift
03Z33's Avatar
Originally Posted by _F-R-S_ View Post
Yea i had same problem then a week later i wrecked the car do me a favor and change it back shit be dangerous wothout abs.. No way of tirning it off either
Sorry to hear about your accident. Hope everyone is OK.
Yes, both srs connectors have resistors. WB supplied two.
I know the resistors are working because airbag light goes through the start up sequence fine, then turns off. Horn is good also.
03Z33 is offline   Reply With Quote
Old 01-25-2013, 10:35 PM   #17
NemeGuero
NemeGuero is offline   Reply With Quote
Old 01-25-2013, 10:36 PM   #18
_F-R-S_
Of connectors and abs light off?
Old 01-25-2013, 10:49 PM   #19
NemeGuero
The Following User Says Thank You to NemeGuero For This Useful Post:
_F-R-S_ (01-25-2013)
Old 01-25-2013, 10:54 PM   #20
03Z33
drift
03Z33's Avatar
My setup is same as yours, only difference is I have a quick release which shouldn't change anything. I'll double check everything again tomorrow.
Old 01-25-2013, 11:46 PM   #21
_F-R-S_
Lika boss
Old 01-26-2013, 05:25 PM   #22
03Z33
drift
03Z33's Avatar
All fixed Thanks for the assistance Nemeguero and F-R-S
The ABS and slip light were coming on because the clockspring wasn't centered. If you look at the stock steering wheel the clock spring sits at 12 O'clock when the steering wheel is straight. When I installed the WB hub with the arrow that normally indicates top/center at 12 O'clock it spun the clock spring around to 2:00 O'clock which the car doesn't like. Make sure to rotate the hub CCW until the clockspring is back at 12 O'clock to avoid this happening.
For those running the NRG hub, you will need to modify your hub to allow the stock clockspring to be retained, if you remove the clockspring the ABS and Slip lights will be on and may not function properly, this vehicle seems to use the clockspring for steering position/angle.
The Following 5 Users Say Thank You to 03Z33 For This Useful Post:
AreteAuto (11-20-2015), BRZ NA (01-14-2014), hippari (02-04-2013), juliog (02-04-2016), _F-R-S_ (01-26-2013)
Old 01-26-2013, 06:10 PM   #23
_F-R-S_
Yea thats what i figured! Dam i ripped mine out lmao
Old 01-26-2013, 06:40 PM   #24
NemeGuero
How did your hub even fit with the clock spring out of place?
Old 01-26-2013, 07:53 PM   #25
03Z33
drift
03Z33's Avatar
Clockspring can rotate any which way, but if you have it off-center when driving straight down the road the car freaks out. The hub will fit with the clockspring in any orientation.
The Following User Says Thank You to 03Z33 For This Useful Post:
_F-R-S_ (02-07-2013)
Old 01-26-2013, 11:02 PM   #26
_F-R-S_
I ripped it out so i had no way of getting abs ever it happens
Old 01-26-2013, 11:20 PM   #27
NemeGuero
yah but the WB hub has a guide for the clock spring top
Old 02-07-2013, 02:19 PM   #28
_F-R-S_
linnk me to your wb hub you purchased from
steering wheel controls inimitable BRZ First-Gen (2012+) — General Topics 79 09-05-2016 01:56 AM
do you want steering wheel buttons? Spaceywilly BRZ First-Gen (2012+) — General Topics 125 04-09-2012 09:46 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 01:16 AM
Anybody not liking the steering wheel? Levi BRZ First-Gen (2012+) — General Topics 40 12-03-2011 11:43 AM
FT-86 concept's steering wheel Dark Scion FR-S / Toyota 86 GT86 General Forum 35 08-07-2010 07:17 AM
