#15 |
Toyota Soul
Drives: 96 taco
so why the question? that was rediculous. If you can/want to put 93 in your car, then why not just do it? This motor was made to use 93 and thats why its rated at 200 crank. That was a foolish question... Just put what it asks for and your all set. No need to wonder about something you don't/won't do.
No replacement for Displacement??? Tell that to the people with a 2JZ.
#16 | |
Drives: Argento 6spd FR-S
You must have some really shady dealers around you.... The Mustang also isnt running the same compression ratio nor the same type of fuel injection set up. |
#17 | |
Drives: 2013 FRS, Raven, Auto
All car dealerships says the put in premium, but they always put in the cheapest gas they can get. |
#18 |
Why 93 octane?
Because race car.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#19 |
Reap the BReeZe
Drives: 04 LandShark STi
Short answer: Yes it will work, and you will lose power.
I know a guy who had his WRX tuned for 87. Thing is, he didn't tell the tuner before the session, just filled it up. Tuner was disappointed with the power he got, and probably spent longer than normal tuning. He was noticeably upset once the guy told him why it was so low. It was a good 87 map, but I recommend informing the tuner of your fuel choice before attempting. |
#20 | |
If thats what you want to believe thats fine. Most dealers arent like that tho. I saw mine filled up with prem, as have others. I was out walking around looking at used cars and one of the techs were over filling it up. Also, if they are caught going against correct servicing specs it should be brought up to their supervisors. |
#21 |
Drives: waiting on a 2021...
Never mind guys, sorry for having a curious mind. Please go back to arguing over which air filter makes 1 more HP than another. I appreciate all the thoughtful replies.
#22 |
Make love
Drives: H8R.. Not really
@zooki.. Not too long ago, I was being absent minded and told the gas station attendant to fill up with $15 regular (87 octane and here in Oregon you cannot pump your own gas). I didn't realize what I said until he gave me the receipt. Guess what happened to the motor? Nothing. It was fine. I just didn't go WOT until it all burned away. I'm nearly certain that Toyota/Subaru have already accounted for the fact that people might do this occasionally. I'm sure the motor can be tuned to run on a lower octane of gas, but (as you prob already know) you will make less power. The motor is high compression. If we were talking about a 8.5:1 motor, different story of course. I have also researched differences in behavior in this regard with iron vs aluminum heads.
Good thought experiment. Just not sure that any tuners would be willing to put much effort into an 87 tune on 12.5:1. |
#23 |
You can put 87 octane in the stock motor, but you shouldn't make a habit of it. A dealership that I used to work for would put regular gas in the engine for it's first fill-up. I can't say I agreed with it, but I'm sure it wouldn't do too much harm.
#24 | |
It isn't an issue on boosted cars because they're adding a lot more power already, so pulling timing back to avoid detonation isn't an issue. On an N/A engine you would have to pull timing to prevent detonation, but without the boost there's no way to get that power back. If you were to run an N/A engine on the timing tables from a boosted tune you would be losing quite a lot of power across the board. The stock ECU will pull timing back if it detects any knock, so it's "safe" to run it on 87 octane, but you'll get worse mileage and less power since the ECU isn't running on the optimal maps.
#25 |
It's absolutely cylinder pressures which require higher octane...
Spark advance can cause detonation, but the reason you have to pull back timing is based on cylinder pressure, whether it's a NA or FI application. 87 octane fuel doesn't burn correctly with higher cylinder pressures and spark, it explodes, which causes detonation. To say you could tune a car for 87 octane and get the same amount of power as a car tuned on 93 is completely incorrect. |
#26 |
Make love
I always thought that the relationship of spark advance to cylinder pressure was inverse.
#27 | |
#28 | |
I don't have the answer but I thought I'd help clear up some confusion. I too don't quite understand all the intricacies of engineering and tuning a modern DI internal combustion engine, but I get what the OP is saying. Most of you boneheads need to read the question and stop staring at your own colons. If a high compression engine requires 93 octane at stock power levels @ 12.5:1 CR, but 93 octane is also stable enough for bolt on FI at 12.5:1 CR, why isn't the inverse true? IF an OEM engine were designed at 12.5:1 CR boosted and required 93oct, wouldn't we expect to be able to run lower octanes if it were changed to NA and produced less power? It's an exercise in engineering thought, the question is not "hai guyz will it go OK on 87? derp? And the answer is not "OMG RTFM NOOB". Anyways, it's obvious that high compression and high heat require more stable octane ratings, but the (perfectly legitimate) question still stands: How much has DI changed this train if thought? Could DI allow us enough finite control of what's happening in the cylinder to improve efficiencies and net the same power from lower octanes? |
| Naturally Aspirated - Backpressure | phenom86 | Engine, Exhaust, Transmission | 16 | 03-19-2014 12:07 AM |
| 93 Octane | Smokinbuffalo | Northwest | 20 | 09-02-2012 05:24 PM |
| 110 octane | EZWood | Engine, Exhaust, Transmission | 19 | 06-29-2012 08:12 PM |
| Who is happy the engine will be Naturally Aspirated? | Ryephile | Engine, Exhaust, Transmission | 491 | 05-02-2012 10:10 PM |
| 93 Octane? | ashtray | BRZ First-Gen (2012+) — General Topics | 175 | 04-04-2012 12:22 PM |
