Old 12-29-2012, 12:47 AM   #15
Burrcold
Drives: Subaru BRZ Limited
I would LOVE to do this, but definitely don't have the balls lol.
Old 12-29-2012, 02:33 AM   #16
techsmitty
Drives: 2013 BRZ Tech
Success...finally. Ran the update a second time and did the RenewalIFLib.dll step before that.
Thanks a ton!
techsmitty is offline   Reply With Quote
Old 12-29-2012, 02:45 AM   #17
8987846
Drives: BRZ MT SWP
Originally Posted by Walla Walla View Post
it worked, no problemo.... except for the dvd, i can't play a video while driving... but the rest is unlucked, and finally, maps are updated... (a 2013 car with maps from 2011... wtf...)
congrats!
sorry, i didn't check the video function after the soft bypass. ummm...hope someone would figure it out and share it to us.
8987846 is offline   Reply With Quote
Old 12-29-2012, 02:51 AM   #18
8987846
Drives: BRZ MT SWP
don't forget to pay pioneer $120....lol
Old 12-29-2012, 03:14 AM   #19
8987846
Drives: BRZ MT SWP
Smile
you have it under warranty, do you?
Old 12-29-2012, 06:56 AM   #20
Burrcold
Yes
Old 12-29-2012, 10:54 AM   #21
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
i assume that the car should have been delivered with that update
(last time i went to levis, he wasn't able to track major roads!)
Walla Walla is offline   Reply With Quote
Old 12-29-2012, 12:59 PM   #22
djdnz
1337
Drives: 2013 BRZ WRB S/C
I'm just downloading the torrent now - thanks to the great seeds it's actually going really quickly
Thanks again for this tutorial I'm pretty excited to try this.
djdnz is offline   Reply With Quote
Old 12-29-2012, 01:18 PM   #23
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
With how easy it is to pull this radio out and switch the pins, Id much rather do the hardwired method than mess with the software. Just my opinion though, Thanks OP for sharing. (even though I have US spec, I sell Pioneer at my store)
Flat Black VW is offline   Reply With Quote
Old 12-29-2012, 01:41 PM   #24
8987846
Drives: BRZ MT SWP
i was going to switch the pins. but i found cable connection on OEM unit is different from those retail ones. that means i need to buy a extra harness($60).
Old 12-29-2012, 01:57 PM   #25
Flat Black VW
Do you have a picture of what it looks like? The Pin you are moving is in a plug that goes into the back of the Pioneer unit, they couldn't have really changed that plug without changing the entire radio cage and basically redesigning the radio. If they are already using the mute wire you could always just add a wire to the empty slot and ground it out.
Old 12-29-2012, 02:32 PM   #26
8987846
Drives: BRZ MT SWP
OEM doesn't use the white connector at right upper conner. So it is harder to identify the cable.
Old 12-29-2012, 02:37 PM   #27
Flat Black VW
Gotcha. Didnt realize they entirely left that harness out.
Old 12-29-2012, 05:14 PM   #28
Ben_G
Drives: Blue BRZ
I wasn't able to find the hex string under PRG0, but found it under PRG1.... was anyone else able to find the correct hex string under the PRG0 Navi.exe, or only in the PRG1 Navi.exe?
EDIT - on the third AVIC411 link provided, it says that the Navi file used is under the PRG1 folder if there is a USER folder that contains a PRG.FLG file. I edited the Navi.exe file from the PRG1 folder and it all works great now.
Ben_G is offline   Reply With Quote
The Following 4 Users Say Thank You to Ben_G For This Useful Post:
diddy (02-11-2013), Myv (05-05-2013), RoryTate (04-21-2013), sevenmgte (04-30-2013)
BRZ Navi in the FRS? nocurfew Electronics | Audio | NAV | Infotainment 15 11-19-2012 05:37 PM
Canadian BRZ Navi EQ settings? Burrcold CANADA 10 11-13-2012 10:49 PM
BRZ Canadian Navi (Pioneer) Ipod Issue zex Electronics | Audio | NAV | Infotainment 0 08-15-2012 09:04 PM
Adding navi to FRS Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 9 06-04-2012 10:14 AM
Adding Navi to the FRS? Pake1 Electronics | Audio | NAV | Infotainment 3 06-01-2012 01:26 PM
