Old 02-22-2013, 08:13 PM   #15
whataboutbob
AutoX-10/10ths every run
Just stopped by the local Scion dealer to get a quote on an AT fluid change. $250. and about 5/6 hours in shop.
Build thread:Here
Old 02-25-2013, 06:21 AM   #16
benster
Drives: none yet
you could do it on your own, it just won't replace all the fluid. What I usually do with my autos is I change the fluid twice and then get a garage flush using their machine. Idk if the fr-s has a drain plug and filter in it but it could be something to save some money and still get about half fresh fluid in. The fluid is recommended for 100k, same as Dextron 6 and whatever mercedes uses in their no dipstick transmission.
benster is offline   Reply With Quote
Old 02-25-2013, 09:44 AM   #17
victorb
Drives: Black 86
Use oem fluid. Just Change more often, every 15,000miles if you drive it hard
victorb is offline   Reply With Quote
Old 03-08-2013, 08:04 AM   #18
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
We suggest and change out our clients ATF at the 30k major service interval. Over the years we've had very very good luck running Redline High Temp Synthetic fluid in our cars. This includes an Automatic full-fledge Road Race car that saw 20-30k of track miles in a year with several 8 hour enduros.
Also anyone who is running an Automatic should be installing an external ATF cooler. Heat is the number 1 killer of automatic transmissions. We like the B&M ATF Coolers you can find from Summit Racing for <$75. Couple that with an ATF Temp Gauge and you will be doing yourself a very very important service.
For fluids either Redline High Temp ATF or the OEM ATF is what we suggest and definitely do a drain/fill every 30k miles. While that will not get all the fluid out due to the fluid stuck in the torque converter, if you do it with your 30k interval changes you will cycle through most of it in 2 or 3 changes.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 03-08-2013, 08:05 AM   #19
AZP Installs
Side note, flush machines have been known to bend the fins in the torque converter due to over pressurization. We never suggest using the flush machines.
-Mike Paisan
Old 03-08-2013, 08:57 AM   #20
whataboutbob
-Mike Paisan
Mike,
Have you done this to one of the twins yet? If so, where did you mount the cooler?
Build thread:Here
Old 03-08-2013, 08:59 AM   #21
OrbitalEllipses
Drives: Attitude
Same place you would add an oil cooler...in front of the radiator.
Old 03-08-2013, 09:19 AM   #22
AZP Installs
Originally Posted by whataboutbob View Post
Mike,
We have not done it yet but like an oil cooler we would put it in front of the radiator. The B&M Kit includes the mounting setup to mount it against the radiator.
-Mike Paisan
Old 03-08-2013, 02:59 PM   #23
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I was thinking of doing some research on the 8-speed Lexus IS-F AT since its the pretty much the same gear box minus the 2 gears but then i'd figure the service done on those AT would create quite a difference with the extra 2 gears.
Old 03-08-2013, 03:04 PM   #24
AZP Installs
Um. You may want to look at the is250 instead. That is the driveline used in the brz.
-Mike Paisan
Old 03-08-2013, 03:09 PM   #25
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
The AT fluid, along with the diff fluid, has been nagging on my mind lately. There was a forum member who changed out both and stated that there was an excessive amount of metal and crap in both of the fluids. Now I know it's probably paranoia taking over, as I don't plan on keeping this car anywhere near 100k miles, but I do not like the idea of me unneccessarily punishing my cars when I can avoid it.
So if the cost isn't prohibitive, I think I'll think about changing them both out at or near the 30k miles mark.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 03-09-2013, 01:26 AM   #26
whataboutbob
http://www.ft86club.com/forums/showp...0&postcount=15 - @zoomzoomers the Toyota (e.r. Scion) dealer quoted me $250 FYI.
Build thread:Here
Old 03-09-2013, 07:51 AM   #27
AZP Installs
Go see mike over at Infamous Tuning & Performance and you will likely get a significantly lower price!
-Mike Paisan
Old 03-09-2013, 10:47 PM   #28
whataboutbob
-Mike Paisan
I actually talked to Mike about this and he was hesitant to work on the AT at this point. I definitely recommend going there for other service. I've had them do several things to my car and they do good work, are knowledgeable, and friendly.
Build thread:Here
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 02:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
