Old 12-06-2012, 12:55 AM   #15
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I haven't had to use a double-duty pad in many many years so my experience is with race-only pads.
Either way I documented much of it in this 4 page thread:
http://honda-tech.com/showthread.php?t=3050206
If you're looking for hardcore and track-only pads there's some good info in there.
Old 12-06-2012, 05:28 PM   #16
CSG David
CSG David's Avatar
Pretty good info for your ITA CRX. That's kind of scary knowing how your DTC-60 pad basically decided to fall apart. Pretty good info for the track junkie looking to find out more about Raybestos and Cobalts too.
Hope to see more posts on drivers using different brake pads for the platform! Keep them coming!
Old 12-10-2012, 04:37 AM   #17
PMok
Codename: Stitch
PMok's Avatar
What's the recommended bedding procedure for the carbotech xp8s on the BRZ? Seeing as I just bought a set...
The Following User Says Thank You to PMok For This Useful Post:
atledreier (12-10-2012)
Old 12-10-2012, 09:50 AM   #18
Best way? At the track. Repeatedly stop until you feel just a hint of fade, and then let them cool down (rolling around the pits without touching the brakes is perfect) for about 10 minutes. After this, most, if not all, of the noise should be gone, and never return.
The Following 8 Users Say Thank You to CSG Mike For This Useful Post:
amram (03-27-2014), Anthonytpt (01-30-2013), Creole (07-22-2016), gmookher (12-10-2012), heeltoe86 (04-11-2013), normancw (03-24-2013), OjiGeorge (04-24-2014), PMok (12-10-2012)
Old 12-10-2012, 10:33 AM   #19
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
I'll quote my post from the other thread to save some effort for myself:
Originally Posted by Texas FR-S View Post
Wanted to add / correct on my previous post.
Just completed my 6th event with this specific car, and the new stock pads lasted me one full two-day event (also 2-3k daily driving miles), and then went out completely after two additional 25 minute sessions during the next event. Was in a semi-advanced run level with basically a stock FR-S and was keeping pace very well... But I would no longer recommend the OEM pads for the front if you are anywhere near an Intermediate skill level. A complete first-day novice should be fine, but depending on how fast you progress with the learning, you will need to stay cautious, indeed.
I switched to Ferodo DS2500 pads soon after my two sessions were up, and they held up very well for the next 6 sessions which followed through the next day. I'm still on stock rear pads, and they seem to be doing okay for now.
Just in case you're curious, I ordered the Ferodo DS2500's from Chris @MAPerformance for a special FT86Club price.
Next step for me is to go for Carbotech XP10's all around along with tires upgraded to Dunlop's Star Spec ZI/II's. Will post a review on those pads and tires later in the future...
Hope my feedback helps some folks.
Sorry for the thread jack, OP...
Texas BRZ is offline   Reply With Quote
Old 12-11-2012, 11:02 AM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The only reason I don't add noise, is because the noise is eliminateable (is that a word?) on EVERY pad, given proper bedding... but proper bedding isn't always possible.
I've managed to bed the most aggressive pads known to man on the s2k (undersized brakes), while I'm unable to properly bed a mild enduro pad with the BBK on the BRZ. In this case, the brakes are simply "too good" for the amount of kinetic energy that the BRZ can build up and needs to dissipate while slowind down.
Even "hybrid" street pads like the Project Mu HC+800 and Hawk HP+ will screech like a dying pig if they're improperly bedded...
Essex does have a nice burnishing room.. I wonder how much it'd cost to have them bed a set of C300's against new rotors, then just switch rotors and pads like the old days when I wasn't lazy.
Hmm I'd probably just buy new rotor hats too, I know I'm too lazy to bother switching the hats over.
To a point I agree on the noise, mine showed an even layer across the rotor and still scream like a banshee, but later they didn't show as even. :shrug: Mine were smoking like mad during bed in too but I never got them to catch on fire.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2012, 11:14 AM   #21
I may have to take that back; I've never used an enduro compound quite like the C300. Apparantly they're known for making noise, even when fully bedded... the only way I can get them to not make noise, even on track, is when I'm threshold braking. Under trail braking, they still screech...
Even the Carbotech RP2 (another enduro compound) doesn't do that...
Old 12-11-2012, 11:15 AM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I like this thread Can everyone update to a standard form BTW? First let's figure out the standard form.. maybe pcasso and Mike's? I modified it some, changed the scale.. discuss...
Brake Pad Manufacturer (F/R):
Caliper (F/R):
Compound (F/R):
Tires:
Feedback:
Feedback...
Scores:
Dusting (1=low-10=high):
Cold bite (1=low-10=high):
Hot bite (1=low-10=high):
Modulation (1=low-10=high):
Noise (1=quiet-10=extremely loud):
Pad Lifespan (1=short-10=long): (estimate/actual)
Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? (Y/N)
Thoughts? I can modify the first post once we figure out the standard format.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2012, 11:18 AM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They only make noise for me at low speed or under light pedal pressure (smooth/slower application/release and gentle braking to move weight around).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Draco-REX (03-20-2013)
Old 12-11-2012, 11:19 AM   #24
What tires are you on? I'd say that they make noise for me up to about 70% braking. We're currently on 225 RS3.
Old 12-11-2012, 11:22 AM   #25
Caliper (F/R):
Compound (F/R):
Tires:
Feedback:
Feedback...
Scores:
Dusting (1=high-10=low):
Noise (1=extremely loud-10=quiet):
Brake ducts: (Y/N)
Made a few edits, 1 being "bad" and 10 being "good" in all cases. Thoughts?
I can edit my older posts to fit the new template.
Old 12-11-2012, 11:23 AM   #26
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
235/40/17 AD08.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2012, 11:25 AM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm fine with that. I reversed noise initially just because noise of 1 seems logically that it would mean quiet but I'm good with either personally.
If no one else posts up today about it we'll go with your latest version.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2012, 11:31 AM   #28
Hmmm perhaps we just need to do more laps on the C300. I've never gotten them to fade, but I've also never driven more than 4 hot laps back to back; we've really only been testing and dialing in the car, rather than trying to run for times at the moment.
On the other hand, while they work just fine on the street in terms of stopping, the noise is... atrocious. Deafeningly loud at street stop speeds. Street pads are on the way :p
Anime Discussion Thread ERA Off-Topic Lounge [WARNING: NO POLITICS] 2698 02-14-2024 11:55 PM
Gundam Universe - General All Discussion Thread poormans_LFA Off-Topic Lounge [WARNING: NO POLITICS] 273 03-23-2014 11:45 PM
S2000 vs BRZ at the track: track oriented discussion CSG Mike Tracking / Autocross / HPDE / Drifting 33 01-13-2013 06:54 PM
Track/Racing Discussion Allch Chcar Tracking / Autocross / HPDE / Drifting 9 05-26-2012 04:39 PM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
