Old 12-07-2012, 12:30 AM   #15
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Originally Posted by austell View Post
Im just gonna run them safe at 200. Im just going for added bass with more sq performance, not really just loud bust year ears out bass.
My recommendation: ALWAYS get an amp that is maxing out your subwoofer. All amps have tuning capabilities, and you don't want what happened to me. In my old Nissan Titan I put in a Alpine Type E 10" which is rated at 750W. Well, since I wasn't looking for anything crazy I put in a 600w cheap amp. Then, to my chagrin, I literally COULDN'T hear the subwoofer. As it turns out when you decide to go with an amp that is less powerful, that means that the amp cannot charge the magnet as well, which gives you less ability to move air/create soundwaves/hear bass. My recommendation is to find an amp that matches the max ratings for both speakers because, if you do that, you can always adjust the bass down, but if you go cheap/weak you can't turn the bass up! Just my .02
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 12-07-2012, 12:41 AM   #16
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
300 wont make them too much louder but it will give you head room to upgrade later. to run at peak efficiency which means better SQ you could turn the gains way down and it would. give yourself 250watts or even 200 if you wanted.
FreshFRS is offline   Reply With Quote
Old 12-07-2012, 12:47 AM   #17
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
for that sub you should only need a solid 350watts at 4 ohms to put the sub in optimal power. 750watts is peak you never wanna run that much power through it all the time. more than likely your cheap amp was rated 600 watts at 1 ohm. At four ohms you might have only been getting 100-150.
Old 12-07-2012, 12:59 AM   #18
austell
Drives: Firestorm FR-S
Originally Posted by mashal View Post
Alpine pdx's .. Small + stackable + stable + quiet = win
I-Tapatalk
Im looking to pay around 200 or less? Is there any that run at that price
So any recomendations on what to get?
So any recomendations on what to get? Im not going to spend over 250 and preferabally around 200 or below
austell is offline   Reply With Quote
Old 12-07-2012, 01:08 AM   #19
austell
Im looking at the Alpine PDX-F4 but Im not liking the price.
Old 12-07-2012, 01:15 AM   #20
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
the M6 is probably your best bet. but the F4 is good too. The one thing to not cheap out on is your amp.
Old 12-07-2012, 01:18 AM   #21
austell
I dont know how hard it is to do, but It seems to me it would be much harder to run a mono amp than a 2 or 4 channel? Also the price is just too high for me.
Ok. How does the Pioneer GM-D8604 Look? Its a brand new amp, and can run 300 watts RMS x 2 bridged at 4 ohms.
http://www.crutchfield.com/p_130GMD8...04.html?tp=115
Old 12-07-2012, 01:32 AM   #22
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
I prefer a dedicated sub channel or a mono amp personally, here is a basic wiring diagram of how to wire your subs to a mono amp. http://m.seimg.net/product/img/subwo...4_ohm_mono.jpg
That amp would work however.
Old 12-07-2012, 02:35 AM   #23
6-Shift
Señor Member
6-Shift's Avatar
Yeah you're probably right...if I end up moving that subwoofer to the FR-S I'm going to get a correct amplifier and a better box, the truck box it's in right now isn't optimal Audio stuff like this confuses me, especially after my experience with my first amp (sony xplod 600w amp btw, piece of crap). I feel like a 250 watt amplifier (according to specs the top RMS is 250) wouldn't even move the sub enough to hear it. Anyway, in response to OP you should check around your local audio shops, sometimes they'll be able to get good brands for cheaper than online.
Old 12-07-2012, 02:48 AM   #24
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
I'm going to run a PDX-V9 Running a Stereo Integrity MB MKIV Shallow 12" needs 350watts RMS and is one of the nicest sounding SQ subs i've seen. Combined with a Hertz Mille Passive/Active 3 Piece Component System (active woofers/ passively crossed over mid and tweet) it should be a kick-ass sound system. Pioneer DEX-P99RS source unit.
for your sub a PDX-M6 would be great. very efficient with the gains turned almost to zero it would pump.
