#15 |
AutoX-10/10ths every run
I'll be running the 4/4 RCEs with 20/16 Whiteline sways in the near future. For reference I'm running 1st gen Michelin Pilot Sports 225/45R17 on the stock wheels.
#16 |
375lb front spring and a 430lb rear spring come with the gc setup, should be fine for street/track/DD.
I plan a set of stiffer front coils for dedicated track use, but may go with a set of 430 fronts 1st and see where we are. GC sells coils at $59 each, so it was a easy choice to shop with them... a 22/16 sway combo will be interesting with that setup. Last edited by gmookher; 12-10-2012 at 08:42 PM. |
#17 |
Site Moderator
Drives: Stuff
Damn this is like the Honda world all over again, some people running heavy front, some heavy rear setups ..
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#18 |
Overthinking it
Drives: BRZ in CS
I've been messing around with suspension calcs and measurements. Obviously, there are a lot of opinions and factors with respect to spring rates.
Based on http://farnorthracing.com/autocross_secrets.html The ideal spring frequency should be right around 2.2Hz front and 2.5Hz rear (I know, it's not that simple). Based on the following Weights (est'd) LF+RF = 0.55x2645 = 1455 lb LR+RR = 0.45x2645 = 1190 lb Motion Ratios (approx.) F 1.0 R 0.75 The "ideal" spring rates would be 375 lb/in F 646 lb/in R The front rate is close to what people are running. The "ideal" rear rate is much higher than people seem to be running. Again, there are a few assumptions here, I'll dig through this a little more over the weekend to double check and develop a little further. |
#19 |
Drives: 2013 FR-S Asphalt
An perfect case of numbers lying...
I've run front engine/rear drive cars for years. It's what I know, it's what I prefer. I also own an FR-S, had one of the very first ones. I read this stuff and wonder how some people get to where they are getting. I'd not run a stiffer rear spring that front. I do run more front sway bar, I would NOT run more rear swaybar. I have reasons for all of this, I've tested my car various ways. Others have driven it both at autocrosses and on the street and very much liked it. I am a parts vendor. I can't give away all the stuff it cost me a lot of time and money to learn. Some of it isn't news to some folks, but the reasoning behind what I do is what I can't let get out on a forum. If you guys would like to discuss, I'd be happy to in person. However, I do need to ask that if you call me to talk about this stuff, you give me a fair shake at your business. After all, I've got a pretty good track record over the years, which is more than I can say for some of the sources of information listed above. I'd like to think proven results trumps hypotheticals. |
| The Following 5 Users Say Thank You to Sam Strano For This Useful Post: | Aznsky (12-08-2012), gmookher (12-10-2012), GTB/ZR-1 (12-07-2012), Scooby South (12-08-2012), sparks (01-14-2013) |
#20 | |
And it's not a BMW which has a crazy motion ratio in the rear either.If anyone finds themselves in Western PA, you are welcome to stop buy and take a ride in my car. You'll find that having stiffer front springs and bar than rear doesn't make for a understeering pig, even on Blizzak LM60 winter tires. Balance is about the same, but the car does move around laterally a lot more and if you transition more than 3 times it gets really lively on the snows due to the huge tread squirm. Slap the Hankooks on it, and it pretty much does whatever I want, whenever I want. |
#21 |
Drives: '13 BRZ in WRB--let's mod!!!
Agree w/ Sam. That kind of rear spring rate will render the car almost undriveable...
#22 | |
![]() I'm not sold either on the stiffer rear, need to try it though but it's now to cold to test.
#23 | |
I've noticed I like looser setups than most, but I also acknowledge that a slightly pushy setup is far more consistent with very little sacrifice in absolute potential. We'll be testing combinations of 9/10/11k front springs, as well as 11/12/13k rear springs this weekend on track. Another thing to keep in mind is that you cater primarily to an AutoX market, while we cater to a track market. The setups are vastly different. |
#24 |
They shouldn't be vastly different. I run the same stuff both places. There is footage of me running the FR-S and my old Camaro @ BeaveRun (not PittRace) here in PA where folks can see how they work.
Both things require balance. Both require placing the car. Lap times at a track are largely influenced by power, at an autocross it's a more basis suspension question. Corners tend to be the same radius or larger on a track, and there are fewer of them. In fact typically I find cars loosen up as speeds climb, meaning I want typically a setup that isn't stiffer in the rear, but the same or softer even at times than autox. Personal preference is true. But I don't want an imbalanced car either place, and the car weighs what it weighs. Basically, folks tend to be more careful on a track, which makes the car move around less (not being driven as aggressively as there is stuff to hit), which tightens it up. So some choose to stiffen things up. I'm typically not one of them. I don't mind a little roll in a car. It's not bad at all as long as the tire's contact patch isn't screwed over it, and great damping is what makes the car respond and turn in, not high spring rates. So I tend to not go nuts on springs, let the suspension work and use the dampers to tie it down. I also I like to use some more front bar (but not as much on this car as some others) to help with roll but not at the cost of ride/impact harshness. It takes a lot of spring to counter a little more swaybar. |
#25 |
I sort of agree and I sort of disagree.
Aero is generally not a factor at AutoX except in the crazy $$$$$ classes, as the aero needs to be pretty extreme to have an appreciable effect at AutoX speeds. The fastest track cars tend to be the ones that rotate well at low speed, and understeer at high speed, whereas AutoX rewards cars that respond quickly to input and make fast small direction changes. Although experiences vary, and admittedly my AutoX experience is minimal, stock/STR/RTR cars tend to have ultra fast transitional speed, but push in sweeper type corners (unable to power out without push), whereas a track setup on an AutoX course would transition much slower in a slalom, but make up time in sweepers and boxes. As you stated, cars tend to rotate more at speed, and this car is no exception. However, it's not as drastic as most cars in the past; the front gives out before the rear even at 100mph in a steady state turn at terminal on both the FRS and BRZ, both with stock suspensions. To me, the two setups are mutually exclusive without at least SOME changes. |
#26 |
Sounds like Sam & I like similar setups. Also, my autox & road course setups are very similar, just a little bit of fine-tuning. The car should be comfortable & instill confidence in general; and it should act similarly in both environments with like settings, IMHO...
#27 |
I wish there were a way to do an apples to apples comparison. The tracks in socal tend to bring out understeer in cars, so a lot of setups here are slightly biased toward oversteer.
It probably doesn't help that I prefer a looser car. |
#28 |
I prefer my cars like Switzerland... Lol
| Basic tech info: spring rates, rear suspension, motion ratios, and you. | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 77 | 07-08-2022 03:56 PM |
| Finance Rates on the FR-S? | mickey177 | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 05-10-2012 02:18 AM |
| Rates are out !!! | FR | CANADA | 24 | 05-04-2012 05:15 AM |
| Finance Rates | Enemies | CANADA | 16 | 05-02-2012 08:01 PM |
| Weird GT 86 factory spring rates in GT5? | Spec-Al | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 36 | 03-27-2012 03:30 PM |
