#15 | |
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
From my offroading experience. We have the following happen. Front inside tire comes up= add rear sway bar. We never have the rear lift but I also have 28" of travel so this is almost imposible. So based on this, if the rear is coming up. Then adding more front sway control and or a stiffer spring may help. What about this. Slightly lower rear spring rate to improve ride quality and front sway to help control weight transfer. As of right now I already have some compression valving removed from the rear to help soften it up a bit. ![]() This is what I'm used to shock tuning. |
| The Following User Says Thank You to jdzumwalt For This Useful Post: | Surok (02-01-2013) |
#16 | |
#17 |
Motor Sports slut
The Unsettling rear happens in turn 8-9 and turn 12 and 13. The dash blinks letting me know the rear is getting wonky. I have all the nanies turned off. I saw this little light coming on as I transition in the turns. Looks to be one more hidden nanny buried in the ECU.
#18 |
Drives: Attitude
Does the nanny light up ONLY during trailbraking?
#19 |
Drives: AVO BRZ
Even with the nannies turned off the 'hidden' VSC will send ABS pulses to the outside rear wheel under lateral slip.
You can disable all nannies via this method from 086A: http://www.ft86club.com/forums/showp...8&postcount=15 Options to permanently disable it include pulling the ABS fuse from engine bay fuse box ... not a great one since it disables front ABS too. Or installing a physical override system like this: http://www.autofactory.jp/product/to...?mode=s&seq=14 PS. Great thread, I am a bit of a suspension noob, my KWs are coming soon and looking forward to dialling them in right.
#20 |
Motor Sports slut
I don't think it's really a trail braking issue. On the exit of turn 8 I'm usually at about 80-85 mph this is kinda of a off camber corner to turn 9. The light will blink at me just after the kink.
I then try to settle the car because turn 9 is like second gear for me. Just for a reference I'm not extremely fast. I'm clocking in at 2:10 at this track right now. But I am hoping to shave down some more seconds. I heard Crawford ran a 2:02 before they went turbo. |
#21 | |
I'm betting your gonna benefit messing with the front to fix the back. Get rid of the OE front sway bar 1st. Try a stano, or a 20 or 22mm front adjustable set soft. get back to us. These things take time, I may have missed it, what tires are you on? I dont think your rear rate is TOO soft, so I would go there last after everything else. You may get other advice and ideas from others. I think your finding the front end too soft, but reading it thru the rear. Can you lower compression valving in the rear,just a hair, and loosen up rebound a bit? Make small, singular adjustment, TAKE NOTES, and revisit. keep us posted, thanks |
#22 | |
Motor Sports slut
My hope is that by doing this, will help the car from nose diving, and should keep the rear more planted during braking. Second, the Stiffer spring's should help keep the rear more planted during left to right transitions.( If I need more I will add a sway bar to the front.) The Strut tower Bar should just improve the overall feel helping maintain control through reduced chasis flex. I dont want to go to stiff because I think the chassis will wear out quicker if everything is super stiff especially If I dont have a cage. I will add Go pro's to my suspension components to help tune. Food for thought. Gregg |
#23 | |
They also ran a 1:59 the one session the car was run with the turbo, although I don't believe it's indicative of the car's true potential, as it was the first time on track after it was boosted. http://www.speedventures.com/results...id=-2146754468 I don't know what tires they ran on those days. Dan Gardner ran a 2:02 that weekend on I believe BFG R1. How bad was your trail braking issue? I've been fighting that issue as well to a degree... |
#24 |
Motor Sports slut
Just got back from a 280 mile drive. I had to meet a contractor out in El centro. This drive is great I had quite a few 90 mph to 30 mile corners come up. I spent a good amount of time really analyzing whats happening to the car. The rear just feels light in the braking zones. On the street this really isn't much of a problem I dont brake that late and I drive a lot more conservative on the road.
On the track when looking for that last possible inch before turn in. Is when the car gets the most unsettled. I will order springs keep you guys posted on my thoughts with this. Last edited by jdzumwalt; 12-07-2012 at 02:17 AM. |
#25 |
Have we talked about your alignment?
- drew |
#26 |
Motor Sports slut
no talk of alignment yet. I'm a slight toe out. I think .12 degrees out on the front with zero on the rear.
#28 |
Motor Sports slut
Camber is 1.5 for the front 1.7 rear
| Basic tech info: spring rates, rear suspension, motion ratios, and you. | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 77 | 07-08-2022 03:56 PM |
| DIY - Flip Key Fob conversion with pics | draggin_az | DIY (Do-It-Yourself) Guides | 178 | 05-10-2020 05:34 PM |
| dislike your plain Toyota key? check my custom flip | tibsy92 | AUSTRALIA | 38 | 02-22-2014 10:24 PM |
| Driving with slippers/flip-flops/sandals/heels | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 06-28-2013 09:48 AM |
| Ordering process. | Davetherave | CANADA | 5 | 08-10-2012 04:46 PM |
