Old 11-21-2012, 11:42 AM   #15
whaap
whaap's Avatar
Originally Posted by TheGuyWithTheFireStorm View Post
Do you think it might be that you got used to the clutch after driving it so often?
Yes. After I made the above post I considered that. In the beginning I thought the light spring tension on the gas pedal made it more difficult than usual to co-ordinate my launches but your suggetion holds a lot of merit.
whaap is offline   Reply With Quote
Old 11-21-2012, 11:57 AM   #16
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
The combo of DBW, Denso DBW voltage settings, soft/high clutch engagement, and non mechanical clutch all lead to that "vague" feeling you describe.. Throttle controllers may help a bit but id say a custom tune + clutch pedal adjustment would minimize most of the wierdness.
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 11-21-2012, 12:27 PM   #17
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
By nature, despite the response, there is a very small amount of movement before the controller actually moves the throttle plate at idle.
I've observed this during logging with the EcuTek software.
CircuitJerk is offline   Reply With Quote
Old 11-21-2012, 01:04 PM   #18
pr086
Drives: fast
Wait, we don't have an actual clutch in this car? What do you mean?
pr086 is offline   Reply With Quote
Old 11-21-2012, 01:19 PM   #19
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I think he meant hydraulic instead of cable.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 11-21-2012, 01:31 PM   #20
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Probably non-mechanical throttle linkage (ie. Throttle by wire).
Demandred7 is offline   Reply With Quote
Old 11-21-2012, 08:36 PM   #21
Norkoastal
Norkoastal's Avatar
Thanks for clarifying that.. Hope the clutch adjustment helps..
CO>CA Cartel
Old 11-21-2012, 08:41 PM   #22
akyp
Drives: 2012 86
Am I the only one who finds the throttle way too sensitive for normal driving? From a standstill I sometimes spin the wheels inadvertently, especially when taking a turn.
akyp is online now   Reply With Quote
Old 11-21-2012, 09:31 PM   #23
fistpoint
Drives: Supercharged Golf Cart
So todays new cars are stepping backwards? Awesome.
fistpoint is offline   Reply With Quote
Old 11-21-2012, 09:45 PM   #24
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Adding the Perrin Crank Pulley helped that out quite a bit for me (though I may have also gotten used to it a bit too). I noticed an immediate difference after I put it on, the engine feeling like it can rev up quicker. I am sure any of the crank pulley's out there would likely give the same thing.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 11-21-2012, 10:55 PM   #25
whaap
whaap's Avatar
I don't think it's a matter of the throttle being too sensitive but I do contribute a lot of the problem to several things. One, the throttle spring is so light that it's hard to tell if you're pressing on the gas pedal or not . Two, the car is so quiet, which I prefer. Three, my hearing is bad enough that it adds to the problem of not knowing whether I've pressed on the gas pedal or not.
If you're any thing like me you've driven a lot of manual transmissions in your life. What I've had to intentionally do these last several weeks is get out of my comfortable old habits and go back to basics in driving and work at it instead of doing it "marginally o.k. I've noticed a marked improvement. In fact I just got back from my evening drive and since I've made a concentrated effort I'm much happier with my performance. I'm thinking I just allowed myself to get a little too relaxed and sloppy.
The Following 2 Users Say Thank You to whaap For This Useful Post:
Bristecom (11-25-2012), racecaresuaceb (11-22-2012)
Old 11-21-2012, 11:06 PM   #26
akuhei
akuhei's Avatar
I noticed these things you pointed out as well. And sometimes, I do get a little relaxed and sloppy. However, when focused/paying more attention, and in lighter shoes (back and forth to work I drive in military boots..x.x), after the pulley was installed, I did notice an improved response from the pedal after adding a pulley. Not just a feel thing, but watching the tach as well. I've taken it off and put it back on a couple times now with the same results, removing some of the sluggishness in the response. Maybe it is just me or maybe the pulley actually does some good. I tend to lean toward the later because a few of my friends riding around with me have also mentioned that they noticed a difference.
Akuhei's Blog
"Inconceivable"
Old 11-22-2012, 02:16 AM   #27
racecaresuaceb
racecaresuaceb's Avatar
Drives: 2013 Subaru BRZ LTD
That clutch take-up point is extremely irritating at times especially in a quick response situation where your muscle memory remembers a particular clutch takeup point and nothing happens in this till the last few mm.
I am giving myself time to adjust but someday I might just go ahead and change the take-up point.
@akyp: Do you think the reason you find the throttle too sensitive because you end up giving too much revs due to the odd clutch take-up point.
racecaresuaceb is offline   Reply With Quote
Old 11-22-2012, 02:42 AM   #28
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Just picked my car up last night and it seems like when i press the gas pedal it doesn't increase the revs right away. Like theres a little bit of travel in the pedal, then i start getting revs. This combined with the high clutch engagement is making starts kind of difficult snd ive been driving manual for years. It doesn't seem like i have percise enough control of the revs when starting from a stop. Does it stay like this or get better? I know there is a period where the ecu is learning, im at about 70 miles now.
You know about the don't go over 4000 RPM till you get past 1000 miles right? Just in case you missed it in the manual.
oldpueblo is offline   Reply With Quote
First 1k miles, 5 small things I hope improve in time regal Scion FR-S / Toyota 86 GT86 General Forum 6 10-03-2012 11:15 AM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
What to replace first to improve audio? garsh0p Electronics | Audio | NAV | Infotainment 1 06-21-2012 06:05 PM
Tips, tricks, techniques to improve driving? Buggy51 Off-Topic Lounge [WARNING: NO POLITICS] 15 08-01-2011 04:17 PM
