Old 11-08-2011, 05:19 PM   #15
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Originally Posted by arghx7 View Post
It's relevant for the life of all components connected to the exhaust system. In aftermarket performance tuning you're not so concerned about catalytic converter life or cat lightoff though.
You're right, and the reason I ignored it in my reply you got spot-on.
You seem like you know what you're talking about. Do you do calibration?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 11-08-2011, 06:23 PM   #16
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
Originally Posted by Ryephile View Post
My advice would be to throw away the EGT gauge and get a good set of datalogging for RPM, Ignition, IAT, MAF/MAP, WBO2, fuel rail pressure, injector duration, throttle angle, and cam phasing.
I have that... It's called HP tuners. I also have a gauge that switches between alot of those as well. I don't use EGT gauges for tuning I was just asking a question about cylinder temps since the EGTs are a reflection of how efficient an engine, to include a turbo, is doing 'work'. I guess I was just a little confused with your response is all... You second one cleared it up though, thanks
This is true only if by "leaner" you mean that the engine-out AFR is leaner than lambda=1, meaning leaner than 14.7:1 on pure gasoline.
Yea depending on the tuner for my current car, you will see as much as .86 lambda at WOT according to the wideband in the exhaust manifold.
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 11-08-2011, 06:29 PM   #17
arghx7
Drives: car
.86 lambda (about 12.6:1 AFR on 100% gasoline), if that is a mostly accurate value, is significantly leaner than what you would expect on most comparable port injected engines. On a completely stock calibration for a typical boosted port injected engine it would probably be closer to .70 lambda, or 10.3:1 on 100% gasoline. On a performance tune it would be closer to .78 lambda, or 11.5:1 on 100% gasoline.
arghx7 is offline   Reply With Quote
Old 11-08-2011, 06:38 PM   #18
ryridesmotox
Yep, the beauty of a direct injection motor. But I also run on ethanol from time to time and that is run much richer. My 100% gasoline tune is not at .86 lambda, I am about the gasoline tune to be my daily driver econo tune.
Old 11-08-2011, 06:46 PM   #19
Ryephile
Hot Dog
Ryephile's Avatar
I found a nice article differentiating Cylinder Head Temps versus Exhaust Gas Temps:
http://www.jpitech.com/press_releases/Bush_Article.pdf
Yes, it's related to small aircraft engines, but it's still relevant.
Regarding ryridesmotox's AFR's at WOT; 0.86 Lambda sounds reasonable with your LNF [DI] engine as long as you're not excessively knocking.
Old 11-08-2011, 06:53 PM   #20
ryridesmotox
Yea it dialed it pretty good... I haven't had mine on the logs in a while to see but I'll hook it up and see what she's doing... It usually holds at around .87-.88 at wot. On the 91 octane I have here in commi-fornia is lame.
Exhaust system: dual or single KiingDavid Engine, Exhaust, Transmission 162 05-04-2012 02:33 AM
Toyota, Subaru and... Carbon Fiber! virobloc Scion FR-S / Toyota 86 GT86 General Forum 10 10-17-2010 12:46 AM
WTF takin' Toyota this long? ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 30 06-30-2010 08:56 PM
2012 is too long of a wait latino469 Scion FR-S / Toyota 86 GT86 General Forum 87 03-31-2010 11:57 AM
2011 Chevrolet Corvette Z06 Carbon slots in right below ZR1 vh_supra26 Other Vehicles & General Automotive Discussions 2 03-14-2010 10:09 PM
