Old 10-22-2011, 07:47 PM   #15
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by cynic View Post
Hi all!
For me light weight is much more important than power ('tho light weight with power is the best). As soon as I purchase my car it is going on a diet. Here is the list so far but if people can suggest anything else it would be appreciated.
Remove rear seats and seat belts
Remove carpet
1 piece racing seat for the driver
Braille lithium battery
Remove spare wheel
Drain windscreen washer bottle
Remove sound system
Long term:
Investigate single exit exhaust,ie remove one side of the "y". (I'm not sure if dual exit exhaust has a performance benefit or if it is just cosmetic).
2 piece front rotors if not already fitted.
With the exception of the exhaust all these items have been removed from my existing car.
Carbon fibre bonnet/hood is not happening as it is not legal here.
Anything I have missed?
Regards,
C
This topic has already been discussed extensively. Please search next time.
http://www.ft86club.com/forums/showthread.php?t=1404
tranzformer is offline   Reply With Quote
Old 10-22-2011, 08:50 PM   #16
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Ahhh that is incorrect. There are 2 mufflers; one on each side of the "y"
That would be true for a lot of cars, but the FT86 has a transversely mounted single muffler at the very rear of the car (like the newer Impreza). You can see it in this spy shot. For reference here is a photo of a stock 2008 STI catback
My existing car weighs 1070 kilos with me in the car. It is unsteerable with the engine not running. That is, the power steering is required to drive the car.
Of course it's unsteerable when you're not moving, even cars with factory manual steering would be. You need to get the car rolling first, otherwise you're basically trying to drag the tires across the pavement.
old greg is offline   Reply With Quote
Old 10-22-2011, 09:27 PM   #17
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Old 10-22-2011, 10:45 PM   #18
NikostC
JDM Enthusiast
NikostC's Avatar
Drives: Scion tC
Hi all!
Remove carpet
Remove spare wheel
Remove sound system
Long term:
Regards,
C
I still do not understand why people want to molest their brand new cars will such bullshit as "weight loss" because first of all, this car is going to be light stock. Making it 90lbs lighter with taking all that stuff out is not worth your time especially removing rear seats and carpet. the rear seats on most cars do not weigh more than 35-40 lbs and the carpet weights like 2 lbs max. Cutting the rear seatbelts will make your car illegal to hold more than 2 people the spare might weight 15-20lbs with the jack and good luck if your tire goes flat.
Bottom line its not going to be worth it to buy a new car and drive around with only 1 or 2 seats no carpet no stereo nothing pretty much but an engine.... if you really want "light weight" you should look at a motorcycle or spend your time elsewhere like installing suspension or brake mods.
NikostC is offline   Reply With Quote
Old 10-22-2011, 10:59 PM   #19
cynic
Drives: n/a
You are suggesting that your view is the only one everybody should have.
There are many 2 seater vehicles on the road. Just have a look at the number of MX-5. This is my project. You are not obliged to like it.
If you have read my original post you would have read that my existing car has been on most of this diet.
Regards
C
cynic is offline   Reply With Quote
Old 10-22-2011, 11:27 PM   #20
RRnold
2 wheel member
RRnold's Avatar
I think the best one was Drain windscreen washer bottle
cynic, if you want to lighten the car, I highly suggest the threads that have been posted already. It has been beaten to a pulp already.
How about removing the power steering, a/c, abs motor, going with a single fan, smaller aluminum radiator, remove the sound deadening material, center console and plastic panels.
Old 10-22-2011, 11:32 PM   #21
NikostC
JDM Enthusiast
NikostC's Avatar
Drives: Scion tC
Regards
C
I know people have different views but not many people like a new car from the lot with nothing inside and having the chassis exposed. It is more generally accepted however, to buy an old project car like the AE86 that is cheaper for purely tracking purposes. The type that might not even be street legal. Its all or nothing, if your not tracking your car more than once or twice a week its again not worth it. If you are and are not the fast and the furious, then take the same stuff out of your car that you said along with the door panels if you want.
Old 10-22-2011, 11:36 PM   #22
NikostC
JDM Enthusiast
NikostC's Avatar
Drives: Scion tC
LMFAO i didn't even notice that one
Old 10-23-2011, 01:05 AM   #23
cynic
Drives: n/a
once again you are offering a personal view. True, I do not track once or twice a week. I hill climb about 6 times a year, motokhana 4 times a year and track about 10 times a year. For me the weight reduction is worth while.
Thank you. This has been suggested already.
Yeah, I had a look at that thread and it was ott for me. My apologies if I did not search adequately.
Cheers,
C
Old 10-23-2011, 01:09 AM   #24
cynic
Drives: n/a
Thank you for posting that link. The exhaust has been taken off the list.
Old 10-23-2011, 01:10 AM   #25
Dark
Elite Padawan
Dark's Avatar
I'm trippin looking at those.
Dark is offline   Reply With Quote
Old 10-23-2011, 01:22 AM   #26
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Oh, you should still replace the exhaust. Aftermarket headers/catback ought to be ~10-15 kilos lighter than stock. All I meant to say was that between aftermarket exhausts the second exit doesn't really add much weight, so there isn't the usual weight benefit that people associate with switching to a single exit exhaust (when compared to an aftermarket dual exit exhaust).
Old 10-23-2011, 01:26 AM   #27
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
Usually, the single exit cost less.
CyberFormula is offline   Reply With Quote
Old 10-23-2011, 02:18 AM   #28
fatoni
weight reduction is nice but if you are going to get that crazy with it you probably should just start off with a lighter car. you are just paying for things you are going to throw away. just buy a 7 or elise or miata. if that isnt practical a gutted ft probably isnt either but instead of dropping 25k on an ft just buy an old miata to gut and a nice civic to dd
FT86 weight speculation anyone? Ground N Pound Scion FR-S / Toyota 86 GT86 General Forum 54 09-07-2013 09:14 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission 7 06-27-2011 06:49 PM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 11:43 PM
FT-86 weight distribution? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 15 04-04-2011 11:58 AM
Toyota FT-86 weight -- take your guesses JDMinc Scion FR-S / Toyota 86 GT86 General Forum 51 03-24-2010 07:57 PM
