Old 03-13-2013, 06:38 PM   #15
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Originally Posted by imravenit View Post
Im not sure if its just my car but lately ive been noticing a weird shift of the tires from left to right as if the chassis was separated from the suspension/wheels for a second.. it feels like a bad toe or worn out tires etc.. But all of these are good.. Car drives straight steering wheel is straight.. Tires are new.. Car is brand neq.. Only 1,500 miles ..and this is while driving the car straight fwy speed.. Its pretty scary and Inconsistent.. ive been trying to rule out if its the pavement but it is not.. Im worried it mightt be a loose joint? Or idk.. Anybody else?
I had it happen to me, but just one time. It was exactly as you described...it was a bit freaky actually. Hasn't happened since that one time, so I have no idea what it was. I do know it wasn't wind, and I don't think it was the road surface. Car probably only had a few thousand miles on it at the time. It felt like something squirrly with the chassis...
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 03-13-2013, 06:50 PM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
Surprised no one has mentioned tire pressures, would be my first check. Especially if temperatures have changed since you got the car.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-13-2013, 08:47 PM   #17
FirestormFRS
Wind is devilish with this car. Passing semi's on the interstate when you hit the blast from the front of their vehicle my car moves to the left every time. I vote wind
FirestormFRS is offline   Reply With Quote
Old 03-13-2013, 09:13 PM   #18
White64Goat
Lug nuts all tight?
Old 03-13-2013, 09:33 PM   #19
sierra
Drives: Skoda Yeti DSG diesel 4x4
I had this a few times with less than 1000km on the clock but not since. The only conclusion I can make is it was the tyres and now they've bedded in?
sierra is offline   Reply With Quote
Old 03-14-2013, 12:26 AM   #20
fistpoint
Drives: Supercharged Golf Cart
I also made note of how easily this car is blasted sideways by wind on my drive home from the dealership(particularly 18 wheelers). The funny part is that this is the heaviest vehicle I have ever owned and is within 20lbs of my old car I still drive after 10 years. Only the 2300lb 5th Gen Civic moved this much from my experience.
Maybe it's the panels underneath the car?
fistpoint is offline   Reply With Quote
Old 03-14-2013, 04:59 AM   #21
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Wind! Happens when I am driving on the H-3 here in Hawaii.
Deepseadiver is offline   Reply With Quote
Old 03-14-2013, 06:38 PM   #22
FirestormFRS
Rub it in why don't ya
Old 04-22-2014, 06:22 PM   #23
Nightwalker
Drives: Scion FR-S, 1999 Lincoln Navigator
I had this same issue basically exactly what you were talking about. I went to get new tires and I ended up getting the continental DSW tires thinking that it would fix the problem and it didnt. So basically after they were inspecting my rims and discovered that the lower ball joint was really loose so I took it to my dealer and they said it was covered under warranty and I only have 15,000 miles on my fr-s. I would get alot of vibration and wobble and it was especially scary on the highway but basically the lower ball joint is responsible for keeping the whole wheel on the car and if that breaks then bye bye tires and hello accident. I would have them check you lower ball joints to see if there is any play. You probably hit a pothole and it made it loose. Tires do play a huge role in helping the overall drive of your car because I mostly do highway driving as well. It basically looked like I was drunk driving hahaha. Hope this helps brah
Nightwalker is offline   Reply With Quote
Old 04-22-2014, 07:03 PM   #24
Burrcold
Drives: Subaru BRZ Limited
I've definitely been freaked out by the amount this car jostles around when it's windy or passing semi's (especially when you get crosswinds when on a multilane freeway). It's even worse when you have a softer compound winter tire, and the steering response gets lazy. That combo can lead to a white knuckle drive.
Old 04-23-2014, 04:20 PM   #25
sero901
sero901's Avatar
Drives: 2014 Scion FRS
There has been a few other people here say as well that they found their lower balljoint loose, all on new cars. For sure worth looking into.
sero901 is offline   Reply With Quote
Old 03-29-2015, 11:02 PM   #26
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Are you holding the steering wheel at a steady angle, and then the car suddenly turns in super quick, so quick that traction control kicks in?
Or is that you are going straight, and the car seems to follow the road and shift around?
If it's the first one, I'd say broken ball joint. But unless you hit anything you shouldn't have any problems with your ball joint
sittinSideways is offline   Reply With Quote
Found Loose wire...?? IDK what it is rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 34 06-10-2020 01:42 PM
Red stitching is coming loose. Chip Issues | Warranty | Recalls / TSB 7 11-01-2012 11:02 AM
Fuel Lid Tight or Loose? JiB Issues | Warranty | Recalls / TSB 18 09-20-2012 01:50 PM
Loose Floor Mats mact Issues | Warranty | Recalls / TSB 0 09-15-2012 12:53 AM
The ride of the falling leaves trueno86power Other Vehicles & General Automotive Discussions 0 10-20-2011 07:45 PM
