Old 10-13-2012, 02:43 PM   #15
Gen
Drives: Scion FR-S
Originally Posted by Turbowned View Post
It probably needs to be re-set, I think it's a fairly simple procedure from what the technicians tell me.
Then again I might just be thinking of the procedure to re-set the auto-up/auto-down feature.
Yes, this is normal behavior and by design. It's not a problem. If the windows notice any funny business, they'll do this.
Turn the car to accessory (so you can roll up/down the windows but not to where the engine is on)
Roll the window down as far as it will go. Roll the window up and hold the button for several seconds. Release the button and then hold it up for one second. Release the button one more time and hold it up for one second.
Voila, your window works again.
FYI, this is documented in the manual.
Gen is offline   Reply With Quote
The Following 2 Users Say Thank You to Gen For This Useful Post:
CaptainSlow (01-22-2013), Turbowned (10-13-2012)
Old 10-13-2012, 03:01 PM   #16
einzlr
Drives: several
lol so this was all a storm in the water glass
einzlr is offline   Reply With Quote
Old 10-13-2012, 03:16 PM   #17
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I had a similar issue this morning, the car had frost all over and opened the pass. door to put my baggages on the seat then drove off. After about 30 minutes I tried to roll down the passenger side windows...didn't work. I tried playing with the lock button but no, nothing.
Then I leaned over and used the button on the actual passenger door and it went down and up, and everything was reseted.
I guess it's just a quirk, I have yet to own a perfect car This won't be much of an issue when the temperature is permanently under zero, fluctuation around the freezing temperature is bad for everything mechanical sitting outside. I hardly see this as an "issue", ice fucks everything, and water can seep anywhere!
Rayme is offline   Reply With Quote
Old 10-13-2012, 03:18 PM   #18
Gen
Drives: Scion FR-S
Easy way to tell if this is the issue is that the light on the window switch will blink when it needs to be reset.
Old 10-13-2012, 03:58 PM   #19
DookDookDGM
BR-Zizzle
DookDookDGM's Avatar
Drives: 2013 BR-Z, 1985 AE86, 1986 AE86
Send a message via AIM to DookDookDGM
thank god for a garage and a winter beater.
A little addiction goes a long way...
2013 Dark Grey Metallic Subaru BRZ
1986 Toyota Corolla GT-SR5
1985 Toyota Corolla SR5
DookDookDGM is offline   Reply With Quote
Old 01-22-2013, 11:08 AM   #20
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
The problem started for me -6 to -12 degrees celcius (21 F, 10F) and the reset works. But the real problem now is the window rattling. Does anyone have this problem?
SPEEDGOD is offline   Reply With Quote
Old 01-22-2013, 01:14 PM   #21
NOHOME
Drives: RAVEN
As mentioned, it was designed to do this. It is a fail safe of some sort. The fix is easy enough if a bit annoying if it becomes a regular thing.
The danger is if you do not realize that it is down and it rains; wet interior.
There is a permanent fix at the expense of your "Door Ajar" light no longer working.
Myself, I am guilty of not spending enough time reading the manual. In the case of this car, it really is required if you want to make sense of the endless lights that demand your attention. The good news is that if you do read the manual, there is some funny stuff in there to keep you amused!
While you are in there, have a read on how to set the radio to FRS mode since I bet it is on TC mode! (Seems to be the default setting)
NOHOME is offline   Reply With Quote
Old 01-22-2013, 01:19 PM   #22
CaptainSlow
CaptainSlow's Avatar
Bingo. RTFM
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 01-22-2013, 01:43 PM   #23
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Originally Posted by einzlr View Post
oh man will the issues with this car never end? I had been planning on getting one after the engine issues got sorted, but now thread after thread is cropping up with all manner of quality issues and I'm starting to get seriously disappointed. So much for Japanese reliability...
Then don't get this car, get a Kia Soul, that's a reliable car
chenshuo is offline   Reply With Quote
Old 01-22-2013, 02:55 PM   #24
NOHOME
Drives: RAVEN
Wait a year or two. The car does have a lot of early release issues, but nothing serious. The alternative is to keep a sense of humour and become well acquainted with the Toyobaru service department over the same time-frame.
If I were in your shoes, I would wait for the second gear synchro issues to go away before pulling the trigger. This is the leading candidate for both the most annoying and potentially expensive (after warranty) issue that I can see.
The car really does drive as well as advertized.
Windows Squeaking Froylavin Issues | Warranty | Recalls / TSB 164 02-24-2018 02:41 PM
Ice + windows... brzninja BRZ First-Gen (2012+) — General Topics 23 10-09-2012 10:29 PM
Pockmarks on windows? Dang Lad Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 20 09-27-2012 04:52 PM
Tinted Windows koolhawk CANADA 20 06-19-2012 08:27 PM
Coverage of Subaru BRZ Debut at Re-Mix Night at Tokyo Night Club and Music Video mockngbrd BRZ First-Gen (2012+) — General Topics 36 01-04-2012 07:15 PM
