Old 10-09-2012, 11:12 AM   #15
empower-auto
Kouki-Monster
empower-auto's Avatar
The condition was a 0-until I need to start braking (around 90 mph) on a straight stretch of road. I saw the road about to run out so I was on the brakes first step was light and they did almost nothing. Second was hard braking. No lock-up / ABS .. it felt really greasy. I had to engine brake hard like I said to grease off the speed.
Car has 5k miles and has otherwise performed well.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-09-2012, 12:05 PM   #16
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by liquidsky44 View Post
Which brake fluid did you guys use?
We swapped in the Motul 5.1 for now.
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-09-2012, 12:23 PM   #17
CSG David
CSG David's Avatar
Originally Posted by empower-auto View Post
Well, I found out luckily without any loss that the brakes on the FR-S are no good at highspeeds. At ~130kph and higher they feel non-existent if you need to stop the car and anyone who doesn't engine brake hard is in trouble.
Pads felt greased! Haha. So - what's the first couple steps that will improve this particular sort of braking?
For increased heat capacity, upgrade brake pads and brake fluid.
Old 10-09-2012, 01:17 PM   #18
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Originally Posted by FT-86 SpeedFactory View Post
Brakes are so easily and cheaply upgraded. A good pad choice and fluid change alone will make a night and day difference.
You can go even above that and do rotors and lines, remove backing plates for extra cooling. So many options on the stock system to get improvement.
Start with pads and fluid. We noticed a huge increase there. We recently added our stage 2 package to our car for this weekends time trial.
But on the cap it say use a dot3 brake fluid only.
liquidsky44 is offline   Reply With Quote
Old 10-09-2012, 01:27 PM   #19
cnk
Drives: '13 DGM BRZ Limited
Motul 5.1 is certified for DOT 3, 4, and 5.1 systems.
cnk is offline   Reply With Quote
Old 10-09-2012, 01:53 PM   #20
empower-auto
Kouki-Monster
how does 5.1 act in severe cold?
Rich Anderson
EMPOWER AUTO
Old 10-09-2012, 02:54 PM   #21
FT-86 SpeedFactory
Like most fluid. -40F is the point in which to worry about it. Honestly if it is -40 outside, I'd be staying inside. :happy0180:
Old 10-09-2012, 03:41 PM   #22
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
If it's -40, just use the snow drifts to slow down.
TheRipler is offline   Reply With Quote
Old 10-09-2012, 04:38 PM   #23
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
At least it wasn't like this:
[ame="http://www.youtube.com/watch?v=9UkXvXsFO50"]How to ALMOST crash your Subaru in style!! - YouTube[/ame]
But anyway, if you're going to be braking hard like that, you need better performance brake pads which are properly bedded in, better brake fluid (DOT 5.1), and better tires.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 10-09-2012, 05:51 PM   #24
empower-auto
Kouki-Monster
It'll happen, and I'll be driving
Rich Anderson
EMPOWER AUTO
Old 10-09-2012, 05:59 PM   #25
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
haha me too
Old 10-09-2012, 06:21 PM   #26
SkullWorks
Drives: SSM LT MT BRZ
The OP seems to have the exact opposite issue of the rest of the sporting world, his brakes were BELOW their minimum operating temp if you are to believe his scenario played out as described...
I for one have had ZERO issues off track with this car and even on track this weekend i had no problems with repeated stops from 100 mph with or without engine braking, I could engage ABS anytime I would have liked and I had a fresh set of Hankook Ventus RS-3's mounted in 225 flavor just for this weekend....
blame canada
SkullWorks is offline   Reply With Quote
Old 10-10-2012, 09:20 AM   #27
mike2100
mike2100's Avatar
Drives: 23 BRZ
I don't see the point in "upgrading" brake fluid for street use. Same with lines and rotors. The OP was driving on the street, people. He doesn't need upgraded heat capacity, just more friction.The stock pads are a little silly. I changed them to Hawk HPS for street use - much better. Good bite, good modulation, don't need any time to warm up. Beware of vendor posts encouraging you to "upgrade" systems that don't need upgrading.
mike2100 is offline   Reply With Quote
Old 10-11-2012, 08:00 PM   #28
sierra
Drives: Skoda Yeti DSG diesel 4x4
Maybe the problem is in the master cylinder?
sierra is offline   Reply With Quote
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 12:37 AM
Casey Stoner high speed cornering at 1000fps tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 6 08-01-2011 04:20 PM
