Old 11-11-2012, 10:21 AM   #15
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Just went to the dealer and they shut the chime off as well
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 04-04-2014, 02:09 AM   #16
BRZpower
can they make it so that the airbag light does not come on with aftermarket seats?
BRZpower is offline   Reply With Quote
Old 04-04-2014, 07:54 AM   #17
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
You can buy the cable for $15 on eBay, and run the TechStream software on a Windows XP machine (or VMWare). The option to disable the seat sensor is there. I did it myself when I installed heated seats. It also disables the airbag light from coming on.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 04-05-2014, 09:38 AM   #18
BRZpower
So its just $15? Or do i gotta buy the software also? will this keep the airbags on or does it just get rid of the light? and what if the car is ecutek tuned, can this still be done?
Old 04-05-2014, 10:26 PM   #19
OURO3OROS
Drives: 2013 Asphalt FR-S
Could it been done with the Openflash Tablet?
OURO3OROS is offline   Reply With Quote
Old 04-19-2014, 12:34 AM   #20
AtlasMick
Drives: FR-S 2013 Asphalt
Does doing all this still allow the airbag to deploy if you crash?
I doubt insurance would cover medical for a passenger if you modified the car for the airbag to not deploy.
AtlasMick is offline   Reply With Quote
Old 02-12-2015, 10:50 PM   #21
willnigguhwassuh
IG: will__is__nguyen
willnigguhwassuh's Avatar
Drives: 2013 Asphalt FRS
did they charge anything?
willnigguhwassuh is offline   Reply With Quote
Old 02-12-2015, 10:51 PM   #22
willnigguhwassuh
Originally Posted by zooki View Post
I just had my dealer turn off the chime. They can access it through their computer. I still have the seat belt light come on in the dash, but no noise.
did they charge u?
Old 02-14-2015, 01:55 AM   #23
willnigguhwassuh
nvm got it done today no charge
Old 02-14-2015, 02:23 AM   #24
westendRIOT
Drives:
Techstream is the same software the dealerships use to do this mod upon request. I figure it's safe for the airbag setup.
That said, it's wickedly powerful software that could brick your car if misused
Another thread with screenshots:
http://www.ft86club.com/forums/showthread.php?t=14629
westendRIOT is offline   Reply With Quote
Old 02-18-2015, 02:55 AM   #25
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
theres always just buckling and trick the sensor
http://www.ebay.com/itm/like/1613663...lpid=82&chn=ps
mrlewistan is offline   Reply With Quote
Old 02-18-2015, 04:36 AM   #26
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
You can turn off the seatbelt ding/chime with a smartphone app called Carista and an OBDII bluetooth adapter. (You should be running one of these adapters anyway to monitor vitals like oil temp, read/reset codes, etc.)
Carista is "free" and reads codes, does some monitoring, but if you want to change factory settings like those seat chimes, Daytime Running Light on/off, one-press unlock all doors, etc, you have to pay $10 in the app to unlock it all.
After that get the Torque app to monitor vitals and all kinds of cool stuff.
killboy is offline   Reply With Quote
Old 05-06-2015, 01:18 PM   #27
BadPanda
Drives: 2013 Limited BRZ
It's up to $19.99 on Android but I can confirm it works.
Bad Panda Motorsports
SCCA STX Build Thread
Driver Blog
Racecomp Engineering - Kartboy
Fast -n- Fluffy
BadPanda is offline   Reply With Quote
Old 05-22-2015, 10:39 AM   #28
karimz
Drives: 2014 Scion FR-S Monogram
I was about to purchase the Carista app but found instructions to do it using a terminal app like hyper terminal or putty (I used putty). I got the instructions on a prius forum but I can confirm that it worked for my 2014 FR-S. I did this last night actually. You need an ELM327 to USB cable (had one laying around but they can be found on ebay fairly cheap). The instructions on the other forum said to set the baud rate to 115200 but I could only get it working at 38400. Try different baud rates if you see gibberish when you type.
Enter the following commands:
AT SH 7c0 (hit 'Send')
Returns: OK
21a7 (hit 'Send')
Returns: 61 AC C0 (meaning beep enabled)
3ba700 (hit 'Send')
21a7 (hit 'Send')
Returns: 61 AC 00 (meaning beep disabled)
That's it! The driver's side seat belt warning won't beep anymore (I haven't tested the passenger side, but I imagine there's a separate command for that). I believe the settings cycle so if you wanted to re-enable it, I imagine you'd just have to re-enter the same commands again, but don't quote me on that as I haven't tested it. You could probably follow these instructions on an android device if you have a bluetooth OBD2 adapter and a terminal app. I have an iPhone and couldn't find an app that would let me send commands.
karimz is offline   Reply With Quote
What's the weight on the passenger seat sensor? Iphone sets off airbag/seatbelt chime NeedsmoreCowbell Scion FR-S / Toyota 86 GT86 General Forum 67 03-28-2013 12:21 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
Red Seat Belt - where to get? MarkMash Cosmetic Modification (Interior/Exterior/Lighting) 11 06-24-2012 11:55 AM
Subaru seat belt chime chitownwrx BRZ First-Gen (2012+) — General Topics 20 05-04-2012 02:35 PM
You wish you were this seat-belt! YukiHachiRoku Off-Topic Lounge [WARNING: NO POLITICS] 13 05-03-2012 07:43 PM
