#15 | |
Drives: '06 AM V8V Coupe
Hopefully someone makes it in aluminum sometime, as that would be a lot more affordable. |
| The Following User Says Thank You to serialk11r For This Useful Post: | brzzy (05-30-2016) |
#16 |
Señor Member
I thought it worked the other way since the drive shaft is spinning 4.1 times faster that the wheels therefore reduction in the rotational inertia is 4.1 times more effective?
1974 TA22 Celica
2013 86 GT |
#17 | |
I guess I should've written "the effective moment of inertia decrease is still pretty small compared to that of a reduction of mass at the wheels" |
#18 |
Señor Member
Ahhh, sorry i did misunderstand you. And i absolutely agree with what you are saying. The shaft would have to be ~ 4.5" diameter to make the same difference as lighter wheels. Which is why a light weight flywheel is such a good upgrade, but that has been covered in other threads.
1974 TA22 Celica
2013 86 GT |
#19 | |
#20 | |
Drives: 2013 FR-S Ultramarine
Nathan |
| The Following 2 Users Say Thank You to SubieNate For This Useful Post: | funwheeldrive (05-29-2015), SirBrass (04-10-2014) |
#21 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
I wish they made this for the AT guys and gals.
| The Following 3 Users Say Thank You to Spartan65 For This Useful Post: |
#22 |
Tech Master / Car Geek
Drives: 2013 AT Hot Lava FR-S
Yes, this is needed for an AT fit.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys Borla: UEL Header Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT -= OFT - Stage 2 UEL E85 - fine tuned by me. =- |
| The Following User Says Thank You to ShadowSeraph For This Useful Post: | Spartan65 (09-27-2012) |
#23 | |
#24 |
At least in the cycling world, aluminum frames are the absolute worst when it comes to vibration. Because they require thicker wall tubing and larger diameter tubing to reach the same strength (Aluminum is lower strength than steel obviously, but it is also much less dense so there's still potential weight savings over *most* steels.) they rattle you to death on rough roads.
Steel has a nice "hum" about it and a certain springyness. Carbon is like riding on a cloud, it damps everything out and also has a bit of spring. Nathan |
| The Following 2 Users Say Thank You to SubieNate For This Useful Post: | kiichiro (03-01-2014), MmmHamSandwich (09-28-2014) |
#26 | |
Drives: 2013 Subaru SWP BRZ Limited 6AT
Is the shaft different for AT & MT?
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#27 |
Cool mod BTW. Maybe I'll work up to doing this, but I don't know if I can justify the cost for it TBH.
#28 | |
According to RSD yes it is, probably in length and spline configuration.
| The Following User Says Thank You to Spartan65 For This Useful Post: | zoomzoomers (09-27-2012) |
| PST Carbonfiber Drive Shaft In Stock and Ready To Go!! | RallySport Direct | Transmission and Driveline | 27 | 11-18-2012 02:39 PM |
| Carbon Fiber Hoods. | Asterisked Accolade | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 09-25-2012 05:44 PM |
| HELP...Drive Shaft/Rear Tire Shutter | UM FRS | Issues | Warranty | Recalls / TSB | 11 | 09-05-2012 12:14 PM |
| Does FRS come with Carbon drive shaft? | STi88 | Engine, Exhaust, Transmission | 30 | 07-30-2012 02:40 PM |
