Old 09-24-2012, 12:56 PM   #15
ALbadboy
ALbadboy's Avatar
Drives: 2013 Subaru BRZ Limited (WRB MT)
Premium non-ethanol ONLY!!! It makes a huge difference.
I have a place here that sells 89 no ethanol... Or I can get 93 with... I hate it.
ALbadboy is offline   Reply With Quote
Old 09-24-2012, 01:06 PM   #16
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
I think my car had 87 from the dealership. After my first fuel up, it seemed to wake up the engine a lot. I'm not sure if the reason for poor initial performance was a break-in issue or 87 octane, but it's had nothing but 93 since then and runs great.
Also, after switching to Shell gasoline, the bird chirping under the hood is all but gone, which was a nice surprise.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 09-24-2012, 01:13 PM   #17
RYU
RYU's Avatar
Drives: really slow...
Using 87 will not destroy your motor or cause it to knock. The manufacturers suggest 91 because it is tuned to the advertised hp/tq/mpg numbers at that octane rating. The factory knock sensors and O2 sensors will tune down your timing and other factors to run on 87. You may not achieve the full 199.9hp on the FA20 but it will not damage your car.
In other words, lower octane will decrease performance but not be detrimental. Would I run it for the long term? No.
RYU is offline   Reply With Quote
Old 09-24-2012, 01:33 PM   #18
avp1
Drives: Traded BRZ for Supra
If you do not want problems with your engine down the road, do not put anything other than 93 gas in this car. It will probably survives for a year other two on lower octane fuel. But if you plan to keep it longer, follow user's manual, which states 93 only. And pass on any gas with ethanol content over 10%, it is not compatible with FA20 engine either. Welcome to the world of real sport cars, where you need to do something special just to be able to use them daily.
avp1 is offline   Reply With Quote
Old 09-24-2012, 01:37 PM   #19
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Cars that have this sensor actually say in the manuals and some advertisements that one can change octanes, this car does not mention any sensor and advises no less than 91.
Old 09-24-2012, 01:40 PM   #20
empower-auto
Kouki-Monster
empower-auto's Avatar
This car already under-performs on 91 octane fuel. Anything less is seriously risky. With 94 E10 it seems to run fairly well.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 09-24-2012, 01:42 PM   #21
Craig
Craig's Avatar
Drives: Asphalt FRS
Stay away from ethanol, that cherp is rather annoying. Its not too hard in jersey to find 93 w/o ethanol thankfully.
Craig is offline   Reply With Quote
Old 09-24-2012, 01:51 PM   #22
Turbowned
Turbowned's Avatar
Just don't. The engine will pull timing in order to run on it if your only option were to run regular fuel, but you should never do it unless it is a last resort.
Old 09-24-2012, 01:53 PM   #23
RYU
RYU's Avatar
Then I guess all of us here in CA are in trouble with our 91 octane gas
I know what you mean. Lexus is one that advertises using different octanes. Though, just because they don't advertise it it doesn't mean it won't work. Take some time to read up on Long Term Fuel Trims and Short Term Fuel Trims. It might help folks draw their own conclusions.
Again, would I do it? No. If it was half the price as 91 I might because i'm not at redline on my commute to work and will not benefit from the added octane as much.
Old 09-24-2012, 02:43 PM   #24
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Slightly off topic... What is the highest octane fuel you can benefit from on a stock tune?
Old 09-24-2012, 04:21 PM   #25
DarkSunrise
DarkSunrise's Avatar
I'd be surprised if a high compression engine such as the FA20 didn't have a knock sensor. So the risk of damage to the engine from detonation is probably slim.
Still, it's obviously not good for the engine in the long-run and you'll get worse gas mileage with the lower octane fuel.
Old 09-24-2012, 04:28 PM   #26
avp1
Yes you are.
Old 09-24-2012, 04:41 PM   #27
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I feel like i get worse mpg just using fuel with 10% ethanol in it :|
Tt3Sheppard is offline   Reply With Quote
Old 09-24-2012, 04:49 PM   #28
CrazyWookiee
You do. I kept track of how much I got out of each tank. Shell 91 Ethanol free gives me between 7-10% better mileage than 94 10% Ethanol. But 94 definitely feels snappier and I get better throttle response.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Gas Premium or regular? Dragon86 Scion FR-S / Toyota 86 GT86 General Forum 315 06-20-2017 10:14 PM
FRS arrival for regular customers question NWIguy Scion FR-S / Toyota 86 GT86 General Forum 20 05-05-2012 08:54 AM
Anyone have a pic of the regular seats? DuMa Scion FR-S / Toyota 86 GT86 General Forum 38 12-14-2011 12:29 AM
So is it a hatch or regular trunk? xantonin Scion FR-S / Toyota 86 GT86 General Forum 5 12-09-2011 07:26 PM
Consequences to Adding Regular Gas? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 34 12-06-2011 12:52 AM
