Old 09-13-2012, 10:06 PM   #15
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
The FA20 tends to run a little on the hot side with regards to oil temperatures. I would highly suggest an oil cooler before running an enduro.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 09-13-2012, 10:09 PM   #16
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We have experience in 24hr endurance races. I don't see why the FR-S / BRZ would not make it with the right modifications for such a race.
Asking any bone stock car to last a 24hr "race" is a hard task. Feel free to PM if you need assistance. What series are you going to run it in?
-JB
FT-86 SpeedFactory is offline   Reply With Quote
Old 09-13-2012, 10:17 PM   #17
ayau
Drives: Some rust bucket
Didn't the gazoo 86 just finish a 24 enduro? Granted the car was modified to suit the race.
Old 09-13-2012, 10:18 PM   #18
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
The secret to any enduro (4 hours or 25 hours) is keeping things cool. An oil cooler is a no-brainer, a big one if going force induction. I would also consider a cooler for the transmission and a large rear diff housing with aluminum cooling fins.
I would also remove the stock tank and install a quick-fill fuel cell. I would also consider pre-programmed maps to switches on the dash that can be triggered for the sake of changing a/f to lower temps/save fuel/increase power.
Big brake kit without a doubt and brake ducts. I would reinforce the suspension, frame and would remove the axles and wheel bearings, remove all the grease and replace it with greases for racing applications.
Since the day I bought this car I've been thinking about doing the 25 hour @ Thunderhill in it, if I had another 100k sitting around but the theoretical exercise is quite fun.
I would probably use the 986 Refrigerant cool shirt system as well to keep the driver cool too. A cool driver is a happy driver.
I think the engine, transmission and rear diff can handle a 24 hour enduro just with appropriate modifications regarding tuning and cooling and fluids.
Old 09-14-2012, 12:10 AM   #19
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by _F-R-S_ View Post
I imagine severe engine failue due to overheating..... this car gets hott only 10 minutes of easy cruising. cant imagine 24 hour hard pushing.
actually the car has an ignition and fueling sequence that heats up the motor faster, the quicker a motor reaches optimal running temps, the less wear and tear....
right after spark is made, the DI spurts a little bit more fuel in the combustion chamber to heat things up a bit, thats why our engines heat up so quickly, there is a write up on the forums but im too lazy to look for it....
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 09-14-2012, 12:16 AM   #20
Crawford
Crawford's Avatar
Drives: 2013 Subaru BRZ
I raced ours at California Speedway which is a very high speed track and had no heating issues at all in the twenty minuet sessions.
Team Crawford
Crawford is offline   Reply With Quote
Old 09-14-2012, 12:34 AM   #21
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
I've participated in 4 hour enduro's with spec MX5 Miata's in Japan, both as a driver and as pit crew for several years. They were basically prepped, but otherwise stock. They held up fairly well, all things considered, but more than once we nearly didn't make the final few minutes due to total brake failures/rotor explosions/other random issues. And that was over 4 hours. A 24 hour enduro requires an even different mindset.
How you plan to drive it will have a huge impact. There's several ways to "enhance" the longevity of various components by simply not beating on it as hard as it's possible to. Use the brakes, but don't beat on them. Use the highest gear possible while still making good time through the corners. A lot of different ways to approach it with the idea of making it to the end of the 24 hours intact instead of trying to do the fastest lap possible, every possible lap.
And if you do it, realize that your car is going to feel about 2 years older, literally, due to the amount of concentrated abuse it will endure.
AVOturboworld is offline   Reply With Quote
Old 09-14-2012, 11:02 AM   #22
Wes B.
Automotive Enthusiast
Wes B.'s Avatar
-JB
As of right now, I don't know which series I'm going to run it in. Any ideas?
Thanks for the info. I'll probably have to invest in most of those modifications before attempting an endurance race.
I understand. Thanks for the info.
Wes B. is offline   Reply With Quote
Old 09-14-2012, 11:09 AM   #23
Grateful Dave
2nd 86 member
Grateful Dave's Avatar
Drives: 2013 Asphalt AT FR-S
I drove my FRS in 100+ degrees weather for over 3 hours driving 75+ mph and no problem. The temp gauge never went up.
Grateful Dave is offline   Reply With Quote
Old 09-14-2012, 11:18 AM   #24
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Team Crawford
Any chance you were logging oil temperature?
20 minutes is a far cry from an enduro, but I don't think it's relevant since my gut tells me that the original poster is just dreaming out loud.
SCCA and NASA both run enduros, and even an occasional 12/24 hour race for amateurs. I don't know anything about NASA classing, but the car strikes me as an SSB car for SCCA. Once you modify it, it will be hopelessly outclassed in some faster catch-all. It's not eligible for improved touring for another 6 years.
I suppose you could show up at a Lemons or Chump race just for fun, but you will be given about 1000 penalty laps, so it will be strictly for fun.
If you are thinking Sebring or Daytona (AMLS/Grand Am), those are pro races and I suggest you get ready to write a check for $100,000+ to actually play there.
Scott
celica73 is offline   Reply With Quote
Old 09-14-2012, 11:22 AM   #25
celica73
Not relevant to the conversation. Unless you were in 3rd gear the entire time.
Old 09-14-2012, 11:26 AM   #26
#87
I usually post drunk
#87's Avatar
You can't run stock brakes at minimum
#87 is offline   Reply With Quote
Old 09-14-2012, 11:37 AM   #27
Wes B.
Wes B.'s Avatar
Scott
As of right now, I am kind of dreaming out loud. I have participated in a number of 20 and 30 minute amateur events, and I would love to try an endurance race. I'm just curious if this car is up to the task...
Thanks for the info. on the classifications.
Old 09-14-2012, 12:06 PM   #28
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Scott
hmmm, I'd love to do lemons next year.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
24 hour, race
frs endurance race frs FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 06-26-2012 09:53 PM
Subaru Engine reliability? FRSCoupe Scion FR-S / Toyota 86 GT86 General Forum 24 06-07-2012 04:11 AM
Toyota GT86 at 24 hour race Nürburgring LegendaryGT86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 05-21-2012 12:46 PM
Audi Reliability (and slew of other questions) Buggy51 Other Vehicles & General Automotive Discussions 8 11-10-2011 10:10 AM
FT-86 G sport for 24hr endurance race at the ring Matador Scion FR-S / Toyota 86 GT86 General Forum 3 10-19-2010 11:18 PM
