#15 |
Kuruma Otaku
Serialk11r:
Old 4AGZE in the supercharged MR2 used an electromagnetic clutch to de-couple the blower at idle or low load or something...
Because titanium. |
#16 |
hashiryu
Drives: Mk4 Supra
That it does. However, they used a roots type blower.
#17 |
Kuruma Otaku
Could work with a Lysholm style, too.
Because titanium. |
#18 |
Drives: '06 AM V8V Coupe
Wouldn't that require a bypass valve? In that case they can just open the bypass, the extra air goes back out, no energy spent.
#19 | |
hashiryu
Drives: Mk4 Supra
No doubt. Don't dispute that at all. In fact, I wonder why Rotrex hasn't tried to implement that. Have they?
The way the clutch works is that there is a coil and a plate. plate attached to the screw of the charger, coil in the pulley. When manifold vaccum drops below a programmed threshold amount, coil is energized, plate mated to pulley and surpercharger is engaged. Otherwise it doesn't blow. That's basically all there is to it. |
#20 | |
Site Moderator
Drives: ichi 86 Project
'09 post I made
#21 | |
Drives: 2010 Evo X MR-T
the FT i've always thought of as a 2+2 coupe version of the miata. and likewise, it would do better with a SC and its responsiveness, its low end tq, its flat tq curve. and also likewise, it need not have huge power to be fast. and looking forward, the NC miata SC made 253 hp. the FT has D4-S that the miata doesnt have. also that kit only uses a 4th gen eaton unit. a TVS 6th gen eaton would again be better. so a 300 hp FT with a flat tq curve? that's not unrealistic... sign me up!!! Last edited by madfast; 08-31-2011 at 03:28 AM. |
#22 | |
#23 | |
Kuruma Otaku
http://mr2.com/TEXT/SuperChargerInfo.html
Because titanium. |
#24 |
Drives: Lexus IS-F
The only problem with tvs/roots I can see is intercooling. Seems like a PITA to do it, where as with centrifugal, just whack in a air-water intercooler inline and away you go.
#25 | |
both roots and lysholm have bypass valves for part throttle and idle/cruise...
![]() Quote:
[u2b]9wpatO9rcQg[/u2b] Last edited by madfast; 08-31-2011 at 03:31 AM. |
#26 |
Drives: Lexus IS-F
looks like a good little set up there madfast. Is that production engine or aftermarket kit?
#27 |
Hot Dog
Drives: quicker than arghx7
^^That's the GM LSJ engine, which uses an Eaton M62 and a W/A IC.
Supercharging is still my preferred choice of FI solely due to their proportional torque output vs. the Go pedal....aka the drivability is closest to naturally aspirated. TVS and twin-screw [various brands] are the most efficient currently available, however good ole Roots are better than nothing. Forgotten it is most definitely not. For the numbers queens, supercharging is still king; find me a passenger-car piston engine that makes more power than an NHRA Top Fuel dragster. I'm totally fine with the FR-S being N/A, however if TRD wants to make a Warranteed supercharger kit I just might be interested.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#28 | |
professional smartass
Drives: 16 speed mountain bike...
Though, I can see why a supercharger would be ideal for the drag strip. The instant throttle response would decimate a vehicle suffering turbo lag off the line.
| Roofline: Form over function. | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-24-2011 01:27 AM |
| more pics form Geneva 2010 | Abflug | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 14 | 03-27-2010 09:03 PM |
