Old 08-24-2011, 08:13 PM   #15
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by Type[R]+ View Post
Most of the manufacturers seem to be working on them, what makes you think a flywheel and CVT are super expensive? It still seems a few years away, but Volvo seems to be ready with theirs.
Well the system controlling the flywheel transmission is pretty complicated so I don't think it'll be mainstream for at least some time, since there are probably a ton of reliability issues I'd imagine. Flybrid has had their thing working for several years already, but we have yet to see a single production car with it. A battery and motor make it very easy by comparison.
Old 08-24-2011, 09:24 PM   #16
n2oinferno
Praise Helix!
n2oinferno's Avatar
Drunk.... He has to be drunk!
That's not drunk. That's
Old 03-13-2012, 05:44 AM   #17
serialk11r
Revive!
So I noticed a few things that I pointed out in random thoughts, maybe they'd belong better here. First of all, Subaru seems to be on a roll with developing new engine tech: electric turbo, mild hybrid system, and they have this fancy schmancy D4-S stuff in their toolbox as well now.
Second, the FA20 has horrid low end torque. If they want to make a higher revving FA20 for a BRZ for example, the low end torque would be even worse.
Third, Subaru is somewhat behind on CAFE standards and needs to boost their numbers. Since they're not Toyota size, they need all the EPA mpgs they can get from every single model, BRZ/WRX included.
So how about a mild hybrid BRZ STI? They can put some very aggressive intake cams on for fantastic high end power (say, 8500rpm rev limit, maybe like 240hp), and then a mild hybrid system to give silly low end torque (like, 250Nm at low speed, 150 from the engine 100 from the electric motor or something). If they're slightly clever and use ultracapacitors in conjunction with batteries, battery weight and more importantly COST can be dropped quite a bit as I believe the main reason for a large battery pack is so they can withstand more cycles of high rates of discharge and charging.
I looked into electric motors and such, getting rid of the alternator and starter would be close to offsetting the electric motor's mass gain. Throwing away the lead acid battery for a small lithium pack + ultracapacitor bank good for 100kJ would have no net weight gain, so the only thing you have to add is motor controllers and converters to power the rest of the car at a lower voltage and to feed the ultracapacitor bank from the battery and vice versa. Overall under 50 pounds gained weight. Shedding weight from body panels could easily result in a lower curb weight.
Another benefit would be that once a high voltage electrical system is in place, you have a good infrastructure for electrifying accessories and pumps if desired, and adding say Subaru's upcoming electric supercharging/electric turbogenerator, or future waste heat recovery systems would be very easy.
Old 03-13-2012, 08:34 AM   #18
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
My CR-Z rocks! It's a good example of how a hybrid can have a good compromise between good MPG and a little bit of fun performance. It's not a sports car but is sporty. The driving modes help too and feedback help too which could be done in any car not just a hybrid.
Old 03-13-2012, 02:56 PM   #19
serialk11r
Yea seriously, the CRZ would've been a great car if they just used a K series motor or even just a tuned R18. Okay, maybe fix the bizarre front end styling too.
Old 03-13-2012, 03:11 PM   #20
Dimman
Kuruma Otaku
Dimman's Avatar
Or a turbo with the IMA for 187 bhp combined?
http://www.automobilemag.com/reviews...n/viewall.html
Because titanium.
Old 03-13-2012, 03:14 PM   #21
serialk11r
Turbo is more expensive than just sticking a k20 or even a ported r18 :p besides I don't like turbos the way they are currently.
Old 03-13-2012, 03:16 PM   #22
Allch Chcar
Drives: N/A
There's no way the K would have gotten even close to the same MPG. It would have just been a 3 door Civic Si. FYI, the Civic SI only gets 21/31 on the EPA cycle.
I believe the fact that they made it a two seat hybrid killed it more in the US. People are buying them, they are cool looking after all. But they're not selling as much as Honda hoped.
I have respect for the Lea engine series they used in the CRZ as a fuel efficient engine but it's not the best way to start a hybrid with a 10+ year old engine simply retooled for the new car. They went for the cheap approach and completely lost out in the USDM market. JDM they sold better so I guess it was a draw in the end.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 03-13-2012, 03:19 PM   #23
Dimman
Kuruma Otaku
Dimman's Avatar
But it's a hybrid turbo! Or are you proposing a hybrid K20? That would be a pretty cool hybrid CRZ.
Because titanium.
Old 03-13-2012, 03:19 PM   #24
serialk11r
I guess that's true, but 1.5 is just not enough displacement. They could be like GM and require super early shifts and all, and program the CVT to run the engine at no more than 2000 rpm lmao.
Old 03-13-2012, 03:30 PM   #25
Allch Chcar
Drives: N/A
The power is sufficient for the weight, and the CRZ has fairly short gearing. But even a Prius can maintain 80MPH. It just takes a bit to get there.
-Allch Chcar
Old 03-13-2012, 03:31 PM   #26
serialk11r
Sufficient for you, sufficient for me, not sufficient for the average American.
Old 03-13-2012, 04:55 PM   #27
madfast
Drives: 2010 Evo X MR-T
I would LOVE to see Toyota make a sporty Hybrid
Chassis: FR-S, possibly elongated if the engine sticks out way past the front wheels
Engine: how about a 3ZR-FE with Miller cycle? 3ZR-FSE?
Transmission: a version of the GS450h would do quite nicely
Make it a 2 seat coupe or roadster with folding hardtop. The battery pack can be Lithium ion that's mounted low, where the rear seats used to be. hp can be around 200ish, and for a HSD hybrid that would be very, very fast. last but not least, the most important thing toyota can do is program the HSD to be fun. im convinced the eCVT used in toyota's HSD can be fun if only they let it. heck the JDM CT200h comes with paddleshifters. there's no reason why they can't tweak the HSD to be a little less economical, for the sake of a little more fun.
madfast is offline   Reply With Quote
Old 03-13-2012, 05:13 PM   #28
serialk11r
The eCVT is unfortunately fully automatic, and very complicated to control Call me crazy, but the more stuff I get to control, the more fun I have, and having only a gas and brake pedal is a bit disappointing.
While a mild hybrid doesn't help EPA scores much, it can provide a sizeable real world benefit in fuel economy and allows 3 pedals and a stick
Anime Discussion Thread ERA Off-Topic Lounge [WARNING: NO POLITICS] 2698 02-14-2024 11:55 PM
Track/Racing Discussion Allch Chcar Tracking / Autocross / HPDE / Drifting 9 05-26-2012 04:39 PM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
Started a discussion on reddit/r/auto rideh Scion FR-S / Toyota 86 GT86 General Forum 0 12-29-2010 10:51 PM
FT-86=Hybrid?!? Please say it ain't so... BoostJunkie Scion FR-S / Toyota 86 GT86 General Forum 60 08-31-2010 09:38 PM
