Old 12-18-2025, 04:33 AM   #15
BishamontenZC6
Drives: '14 BRZ Limited
They visually look OK, I cannot see any tear. There's also no play in the ball joint. Still they are the only part of the front suspension that haven't been renewed and are 160'000km.
According to your experience, would it be possible that the subframes got a little bit loose with time even though they have never been touched ?
BishamontenZC6 is offline   Reply With Quote
Old 12-21-2025, 10:06 AM   #16
Racecomp Engineering
That seems unlikely. Is the noise loud? When does it occur? (potholes, all the time, etc)
- Andrew
Old 12-22-2025, 10:07 AM   #17
BishamontenZC6
It's not loud and clear as a loose end link clunk would be, it's more like a muffled thump. You can hear it without music while driving but it's not obnoxious. It sounds a lot like this noise, posted a few years ago on the forum :
It only occurs at low speed (below 40km/h), when small bumps hit one side or general uneven pavement, particularly when those makes the car bounce from left to right quickly. It doesn't occur on speed bumps or at higher speed, when braking nor highway and spirited driving. Only city driving at low speed.
For peace of mind I checked again that the endlinks are tight today, they are ok. Also checked the top mount to struts nuts and they are tight. That's definitely weird.
Old 12-23-2025, 07:15 AM   #18
bdtbdtbdt
Drives: 2015 Scion FRS
It looks like maybe the very bottom of your shock is hitting the a-arm
bdtbdtbdt is offline   Reply With Quote
Old 12-26-2025, 06:25 PM   #19
BishamontenZC6
5 years with this car and it’s been nothing but pleasure, but that noise problem is really ruining it for me now. I don’t know what to do anymore, and unfortunately have no serious suspension specialist I could give the car to for check up in my surrounding. I’ve had my share of other quirks and problems with the car before but they all had logical and rewarding solutions, this one is just ridiculous and doesn’t make sense. It shouldn’t be anything too complex but the impossibility to solve it makes me want to drive the car straight into a lake and forget about it…
I found another video that shows more how it sounds inside the car when it happens (same road condition as the video, but lower speed in my case) :
Old 12-28-2025, 11:31 PM   #20
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
5 years with this car and it’s been nothing but pleasure, but that noise problem is really ruining it for me now. makes me want to drive the car straight into a lake and forget about it…
I think you need to take a break if you're feeling this way about a noise after modifying your car. If it's a quirk that has no visible impact or detriment to the car, embrace that your car has something unique and continue to love it. It's still a cheap Japanese car, no need to take it to this level
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 01-05-2026, 09:32 AM   #21
BishamontenZC6
You're right that a break is needed, it's what I eventually did .
The thing is that this exact noise is not a quirk. I can live with crickets, DI or vacuum pump thumps as they are known quirks on that platform and I totally embraced them.
That suspension noise is not one of them. I've never had it on my first GT86, neither on my current BRZ that I had been driving for almost 2 years with it's current setup without any suspension noise before last month. If it had been there from the moment I installed the coilovers I would agree with everything you said, but it's not the case.
On top of that, I've been daily driving sports and modified cars for the last 25 years, 86's platforms for 8 years and my current one for 5 years, so it's not exactly that I'm lacking XP in that field.
It's true that so far there is no obvious sign that it might have an effect on the handling nor safety of the car, but as long as it's not proven it's difficult to take it for granted and I'm not great at gambling when it comes to safety. For me, unusual noise means something isn't right, cheap platform or not.
Nevertheless, I had some time during the holidays so I went all over it again and did the following for front and rear :
  • Checked the endlinks again and made sure they are tight - OK
  • Checked that all the nuts and bolts are tight to spec - OK
  • Checked that the top nuts are tight - OK
  • Checked that all ball joints are OK with no play - OK
  • Checked that every bushings are OK - OK
What's has been replaced :
  • Front endlinks (Aftermarket)
  • Front sway bar bushings (OEM)
  • Rear endlinks (OEM)
  • Rear sway bar bushings, mount and bolts (OEM)
I also disconnected the endlinks at the front to figure out if noise was still occuring with the sway bar disconnected : it did. I can therefore definitely state that endlinks are not the culprit and will finally leave them in peace from now on.
Based on that, I really don't know. The only idea I'm having left is that those noises would be caused by the near 0°c we are having where I live since a few weeks. They started to appear mostly after I replaced the front sway bar bushings (OEM), which is also when it started to get colder. So maybe the new sway bar bushings (probably firmer than the 160k old ones), with very cold temperature generate more noise with the coilovers, that could themselves be clunkier in the cold. Problem is there's no way to know for good until temperatures go back up. I don't know what the chassis specialist around here think about this.
WRX rear sway bar: good front sway bar combo? LerpK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-11-2016 07:02 PM
Drift alignment. rear toe problem and front sway bar rubbing trdric Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-03-2015 02:21 AM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 02:20 PM
Does anyone have Perrin endlinks mated to an aftermarket front sway bar? loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-22-2015 11:24 AM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 01:38 PM
