#15 |
Drives: 2013 Subaru BRZ
I actually did the swap last Friday evening. I ran a local autocross event on a smaller lot and the difference was noticeable. The car felt a little closer to the way it used to feel though getting tail happy was still a minor issue, it wasn't something unmanageable like it mostly was with the 4.30. I am going to try to run Mid-Ohio at the beginning of July so I'll know for sure then.
| The Following User Says Thank You to RT-BRZ For This Useful Post: | smackrel (06-06-2025) |
#16 |
Drives: 2020 BRZ
#17 |
Drives: '22 BRZ
I bought a diff out of a ~2014 IS250 RWD and installed my OS Giken LSD into it, pretty simple swap!
#18 |
Rust bucket enthusiast
I second the 3.73. it's called the m85, I have sold a couple on here- you need to remove the axle stubs, and most of them could do with a new breather (easy to find and cheap)
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#19 | |
Drives: '22 BRZ
Oh, interesting. Mine was Y32 I believe and had no stub axles to pull. I definitely second the tip on the breather, mine was clogged and smashed.
#20 |
Drives: 18 Brz (Sold) / 22 BRZ
Calcs
Deleted
Forum not letting me upload the calculations |
#21 |
Used 3.7 direct swap with a good diff seemed almost impossible to find, just switched the ring and pinion in mine to 3.7, still no traction until 70
| The Following User Says Thank You to B T For This Useful Post: | DocWalt (08-14-2025) |
| GR86/BRZ Diff Mounts | Jianlun | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 16 | 06-17-2022 01:25 PM |
| Which is better? Reaplcing rear diff bushings? or installing rear diff brace? | Frs30 | Engine, Exhaust, Transmission | 22 | 04-13-2020 11:23 AM |
| Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? | mistople | Engine, Exhaust, Transmission | 10 | 09-21-2018 07:01 PM |
| Diff Mount Inserts install - Diff won't lower??? | ChRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-17-2017 01:07 AM |
| Swap AT Diff with MT Diff | sydious | Engine, Exhaust, Transmission | 2 | 03-17-2016 03:59 PM |
