Old 05-25-2025, 12:08 AM   #15
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Bought mine during Covid with 13K miles. Im at 70K miles and since last year, autocrossing.
Old 05-30-2025, 03:48 AM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Both of my BRZ’s are car shaped.
My 13’ I bought in early 16’. It is now a track rat. Biggest issues I have had is keeping front hubs in it. Otherwise it has been solid except for my spare engine kicking a rocker arm and throwing a rod. OG engine has like 100k on it and runs great.
My 15’ I bought with a spun rod bearing and a JRSC and has been a bit of a basket case due to the previous owner(s). It should be sorted shortly.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (05-30-2025), blsfrs (06-01-2025)
Old 06-02-2025, 11:41 PM   #17
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
Bought my ‘13, brand new, only 43,000 kms approximately now. Mainly a weekend toy car, still great fun with bolt on mods. Car is “complete”, for now and in good condition. No plans on upgrading anytime soon.
Dirty Harry is offline   Reply With Quote
The Following User Says Thank You to Dirty Harry For This Useful Post:
blsfrs (06-03-2025)
Old 08-11-2025, 10:21 PM   #18
twistednoble
twistednoble's Avatar
Drives: 2015 BRZ Limited
Bought my 15 in 21 with 18k, up to 122k miles as it's parked in the hotel lot now. Dailied year round with some of the load spread across a couple bikes when it's not freezing.
Body generally in good shape aside from a couple hail divots and the touched up rock chips on the front. Engine in good shape with general maintenance, and fresh 0-20 every 5k. Been on E85 since 38k only switching back to gas a couple times on road trips where it was unavalible. Only non-maintenance services was a TOB at 90k and I threw a new exedy clutch (original lives on the shelf as it's still got another 90k in it) at it so I don't have to drop it again for another 100k.
33 mpg on gas, 25 on e85 with 215 tires, 23 on e85 with 225s.
twistednoble is offline   Reply With Quote
Old 08-12-2025, 01:25 AM   #19
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Bought my '16 in '16 with 6 miles on it. As soon as the factory warranty was up, I added the Cosworth supercharger to it, plus poly bushings, oil cooler, SouthBend Stage 2 clutch and JDM lighting. Took a job traveling for 3 years and hardly drove it. Quit my job and found that the ported injectors were clogging, and the fog lights and DRL on the front had cracked at some point and let water in. Replaced the injectors, added Diode Dynamics yellow fog lights, polished up the headlights and replaced the fuel filter. It runs great and gives me no problems. Many times I will take the long way home just to keep driving it. Only issues are minor rock chips on the nose, clear coat is pealing on the rear wing which was caused by the Subaru car cover I used to have wicking moisture onto the paint, and the driver's seat has split on the sides from sliding in and out all these years. Has about 300 HP and still gets 31mpg if I'm easy on it. Recently switched to 5w-30 oil which I should have done long ago.
sly is offline   Reply With Quote
Old 08-12-2025, 01:26 PM   #20
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
Bought mine new in 2020, it has currently just over 6800km on it. Its so close to being in perfect shape that its not funny. I've literally washed it more than filled it with gas
its just a fun car to take out when its nice and we don't need more room(passengers, dogs, kayaks etc)
Mods in sig. I do drive it hard, but no abuse. Quality fluids etc
Edit, also a Perrin intake pipe and my own custom work on the airbox and inlet snorkel. I also remove whatever I can to drop weight, such as those horrible steel injector covers. I made a small aluminum bracket for the PCM.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 12-29-2025, 10:14 PM   #21
QBRZ
Drives: 2017 BRZ
Hey Everyone. First post. Been lurking awhile.
Bought the BRZ for my Wife in September of 2017. 2017 BRZ Premium, AT. Wife can't drive a manual, but was adamant about a BRZ over the 86. Started the search in early 2017, and finally cornered an AT version at a local dealer. If it were an 86, the search would have been easier.
Picked it up brand new with 41 miles on it. So it was either test driven a lot or a dealer swap. We do not know, didn't ask. It's been a great commuter for the Wife. I was rarely driven the first year of ownership. Wife started to daily it end of 2018. 2020 pandemic hit and it was driven sparsely until 2022. Currently sitting around 49k miles. It's on its 2nd battery and 2nd set of tires. All stock. It's got some bumps and bruises along the way. The worst is a crack on the front bumper cover from hitting a piece of sheet rock on the freeway. Impressed with the stock windshield. Lots of rock chips over the years, still wearing original glass. Front of the roof is oxidizing a bit. Otherwise, it has held up well. 8 years in, we are thinking about replacing it this year.
New in 2017
[IMG][/IMG]
2024
[IMG][/IMG]
QBRZ is offline   Reply With Quote
The Following User Says Thank You to QBRZ For This Useful Post:
blsfrs (12-30-2025)
Old 01-03-2026, 02:26 AM   #22
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
My 2013 is still in superb shape inside and out. I almost have 28k miles on it, which isn't much given my daily commute is only 4 miles to work. I should take some new photos of it. Here's my old thread: https://www.ft86club.com/forums/showthread.php?t=43402
shiumai is offline   Reply With Quote
Story on my old supercharged BRZ (dealer currently still has it for sale) KSpider BRZ First-Gen (2012+) — General Topics 26 02-24-2015 06:47 PM
Subaru isn't currently planning a BRZ STi or other performance models vh_supra26 BRZ First-Gen (2012+) — General Topics 28 04-26-2014 05:18 AM
►► The Ultimate WHITELINE Thread! ◄◄ EVERY Currently Available BRZ/FR-S Part FOR LESS CygnusPerformance.com Brakes, Suspension, Chassis 33 08-01-2013 07:30 PM
Brz Limited Avalable (currently wait listed, but soon. This is not an add.) Floggin Tires Great Lakes 2 09-25-2012 02:13 AM
