Old 11-30-2024, 09:45 AM   #15
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I really like the design of JDL’s FP/OP combo. I run the nameless one piece FP/OP and it’s a PITA to install.
I have the 2.5" catted Nameless OP/FP with the resonator. I ground off a piece of the engine block for better clearance. I can see where the 3' version would be a real PITA to get in.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (11-30-2024), Spuds (12-01-2024)
Old 11-30-2024, 12:07 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I have the 3”. I find the easiest way to get it in is to jack the passenger side of the car pretty high up so you have room to twist it around to work it into place.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
blsfrs (12-01-2024)
Old 11-30-2024, 05:59 PM   #17
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I have that exhaust setup you are considering. I kept OP and front pipe as modular pieces. I figured if I need to switch FP out I can leave the aftermarket OP in which makes life easier.
JDL 4-2-1
Locally built 2.5" OP and 2.5" ultra quiet spec FP
CSG touring
CSG just did a revision to their touring exhaust. I'll be getting once shortly actually to replace the current one. Setup overall is perfect IMO, seats down you get enough exhaust noise.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
blsfrs (12-01-2024), Spuds (12-01-2024)
Old 12-01-2024, 08:33 AM   #18
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Thanks all for the input. I wound up ordering the front pipe separately and am planning to pick up a used OP for the same reason RToyo86 mentioned, plus it's easier to sell down the line if I need to.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
The Following 3 Users Say Thank You to Spuds For This Useful Post:
blsfrs (12-01-2024), DarkPira7e (12-02-2024), RToyo86 (12-01-2024)
Old 12-01-2024, 08:46 AM   #19
Spuds
The Dictater
Spuds's Avatar
JDL 4-2-1
CSG touring
Yeah I saw your sound clip video/post and was thinking "hmmm, maybe that one..." when looking at catbacks. What did they revise? Why are you replacing the one you have?
The Following User Says Thank You to Spuds For This Useful Post:
blsfrs (12-01-2024)
Old 12-01-2024, 11:06 AM   #20
RToyo86
RToyo86's Avatar
Not entirely sure on the specifics but they worked with MXP to fix the baffle failures that can occure. I have a mild baffle failure that I can hear when the muffler gets hot. A bit of buzzing around 2-3k rpm.
The Following User Says Thank You to RToyo86 For This Useful Post:
Spuds (12-01-2024)
Individual Racing Parts (IRP) V3 Short Shifter Rattle Thread Shadow_ Tracking / Autocross / HPDE / Drifting 50 08-15-2023 10:56 AM
WTB: Exhaust Parts 3" Catback & Overpipe / Frontpipe combo Dillydallen Want-To-Buy Requests 1 04-12-2018 10:28 AM
New RACING short shifter from Individual Racing Parts Tor Engine, Exhaust, Transmission 161 12-20-2017 08:07 AM
Individual 3M Clear Bra parts DoomsdayJesus Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 08-09-2013 11:34 AM
The individual age poll tranzformer Scion FR-S / Toyota 86 GT86 General Forum 41 01-05-2012 03:01 AM
