Old 10-08-2023, 12:09 PM   #15
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Originally Posted by AussieBRZ View Post
We
If car is ecutek tuned I'd say tuner has activated flat foot shift feature, whan you clutch kick it won't let the rpm increase of current rpm.
Fix will be to disable flat foot shift feature in tune or at least disable it on one or more of the map me des if you want to clutch kick to get wheel spin
FFS is engaged if throttle is over 85 percent and you press clutch
Flickering oil light is a worry it means oil pressure is dropping below about 3 psi.
It's just a simple pressure switch it doesn't go through ECU. So if that's real and pressure switch is not broken you oil pressure is dangerously low
I'd assume your running an oil cooler and at least 5w30 or 10 w40 oil and you oil temps are less than about 120C max if not I'd check that out asap before you need a new motor
I have no idea if the car was ever tuned, was just a thought. All i've done to the car was an angle kit & coilovers because I just wanted a k.i.s.s. car and to not have to worry about stuff.
I've started it up since that track day and no oil light. I'm going to be dropping the pan adding a baffle, oil cooler & changing to 10 40 & getting back out there. Worst comes to worst I've gotta put a new motor in it I guess.
I was hot lapping the thing for quite a while & tandeming with my buddy @ a private day so we just had the track to our selves.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 10-08-2023, 12:30 PM   #16
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by nickmerronesucks View Post
yes any more you think?
Just removed fuses I think I had a brain fart typing and forgot a word Lol
As in more than one.
Old 10-08-2023, 04:05 PM   #17
nickmerronesucks
Ned flanders
ah man, I'm too old for forums anymore.
Just fuse. Lol sorry guys
797Performance.com
Old 10-10-2023, 06:34 PM   #18
nickmerronesucks
Ned flanders
Okay
Update
got the car back together, will be wrapping up oil cooler install tom..
BUT if i clutch in go WOT. IT def has some sort of launch control or FFS.
Any way to determine what the car is tuned on without having a tuner so i can buy the appropriate tuner?
797Performance.com
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
Design Proposal for a New VW Corrado from the Imaginary World of "What If?" vh_supra26 Other Vehicles & General Automotive Discussions 2 02-13-2010 06:26 PM
