#15 |
Famous Potatoes
Drives: '15 ultramarine
I've had braided lines on several cars and never had a problem. You have to buy the good ones.
| The Following User Says Thank You to Sapphireho For This Useful Post: | Spuds (09-10-2023) |
#16 | |
The Dictater
Drives: '13 Red Scion FRS
![]() Pads, fluid, rotors, lines, lube? Did I miss anything?
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
#17 |
Drives: 2022 BRZ
Ferodo DS2500 perform well for street/autox, but they dust like mad. Real pain in the butt in that category.
| The Following User Says Thank You to Wangspeed For This Useful Post: | Spuds (09-10-2023) |
#18 | |
ProCrastinationConsultant
makes sense, as i've had previous cars where i didn't replace the sliders/boots, just added grease, and weeks later they'd seize up...
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | autoracer86 (09-10-2023), Spuds (09-10-2023) |
#19 | |
Drives: Toyota GT86
https://www.ft86club.com/forums/showthread.php?t=134192 here is what I ordered from my local toyota dealer SU00300576 Slide Pin Bush X4 088783010 Rubber-G 100G X1 Service manual if you need it. Will also back up that toyota says to change them https://gt86stuff.onrender.com/t3Por..._rm_index.html
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
| The Following 3 Users Say Thank You to autoracer86 For This Useful Post: |
#20 | |
Drives: 2013 frs base
#21 | |
Drives: Toyota GT86
| The Following User Says Thank You to autoracer86 For This Useful Post: | blsfrs (09-10-2023) |
#22 |
The Dictater
Thanks for the responses all.
On the pad front I think I'm going to stick with the ds2500 (is that a pun?). On the state of the current brakes, the rotors aren't too worn, down 0.2 mm from standard all around, but they do have grooves forming. The pads are at about 4-5mm from a visual inspection, which is 25-30% of original thickness. So the brakes don't absolutely need to be changed right this moment, I could just do fluid (which the car needs badly). Still going to change them. Going with new rotors for now, I'll still look into getting the originals resurfaced. 'Final' list: -RBF600 - 1L -DS2500 front and rear -OEM rotors front and rear -OEM brake lines front and rear -Brake system lube - whatever parts store has I guess. I swear I had some... -Slide pin sleeves - so weird Note: Slide pin boots look good to me without disassembly, if I do find a bad one during the job, the Toyota dealership can usually get stuff next day if they don't have it on hand.
Also: "Build Thread" Last edited by Spuds; 09-11-2023 at 02:37 AM. |
| The Following User Says Thank You to Spuds For This Useful Post: | autoracer86 (09-11-2023) |
#23 |
Drives: Toyota GT86
Castrol srf race would last much longer than rbf600. Also those slide pin bushings or whatever you want to call them require a certain type of grease. At least that is what I saw online lol. I haven’t had any issue with the grease I got from Toyota so I would recommend that over something random you find at the auto parts store
| The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | ruturaj001 (09-12-2023), Spuds (09-12-2023) |
#24 | |
Ferodo DS2500 are a good "aggressive" street/canyon/autox pad that feels pretty good, dusts a lot, and can take a little heat. I still wouldn't track them on 200tw tires. There are slightly cheaper, slightly more street oriented pads that would probably do the trick, but if you're set on the Ferodos that's okay. Motul 600 is fine and inexpensive. There are other options here too...Motul will get the job done but tends to need to be replaced a little more frequently. I also would not use stainless steel lines without frequent inspections. I use OEM lines. Definitely make sure everything moves nice and smoothly, no stiction etc...so good call on the lube and slide pins. - Andrew |
#25 | |
#26 | |
The way some brands SS lines are secured in the wheel well is...well...not as secure as OEM. Other people have had different types of failures. There are many different brands of SS lines out there, it's one of those parts that just gets pumped out because they're easy to make or adapt from other fitments. Mostly the benefit is small if any and the potential for failure is way higher. OEM lines are plenty stiff. - Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#27 |
Drives: Crapcan
SS lines are a braided SS sleeve over a plastic hose. You have to be careful you don't kink them, the sleeve can also chafe the hose. I've always heard inspect regularly.
#28 | |
Famous Potatoes
And yes, they are bling. |
| Spring shopping list | Ignore Your Doctor | Want-To-Buy Requests | 0 | 04-07-2019 11:56 AM |
| FRS Engine Upgrade Shopping List | PapaJ | Engine, Exhaust, Transmission | 19 | 02-07-2019 10:35 PM |
| Christmas shopping list | Ignore Your Doctor | Want-To-Buy Requests | 1 | 01-01-2019 09:11 PM |
| Forged internals - shopping list help | ChrisD | Engine, Exhaust, Transmission | 22 | 07-19-2015 10:12 PM |
| Shopping List : building a faster car! | Philly | CANADA | 8 | 06-28-2012 07:58 PM |
