Old 09-18-2023, 11:14 PM   #15
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
Really enjoy the videos that you make! I’ve watched some of your older ones too. Like about the MCS coilovers.
Wangspeed is offline   Reply With Quote
The Following User Says Thank You to Wangspeed For This Useful Post:
justinco (09-19-2023)
Old 09-19-2023, 09:16 PM   #16
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by autoracer86 View Post
Been watching a lot of your video's lately and just wanted to say thanks! They are very helpful and high quality. Keep it up
Glad they are helpful, that's my goal, thanks!
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
autoracer86 (09-20-2023)
Old 09-27-2023, 02:44 PM   #17
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Did some more oil pressure testing while back at Chuckwalla this past weekend. That video is below, along with some hot laps on the fast tires. Despite the sad baffle results, this car rips, sub 2 is possible with OEM shocks and just a few camber mods
Kazama baffle testing results:
CVR CW hot lap, 2:00.81
CVR CCW hot lap, 2:00.97
The Following 6 Users Say Thank You to justinco For This Useful Post:
autoracer86 (09-27-2023), CSG Mike (09-27-2023), cueball89 (09-27-2023), DocWalt (09-27-2023), Jianlun (09-27-2023), RedReplicant (09-27-2023)
Old 11-09-2023, 10:45 PM   #18
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Exclamation
Changed up the engine bay a little bit with some Perrin parts and did another 2 day track weekend with PCA at Spring Mountain Charleston Peak full track.
First time at Charleston Peak and it was probably the most difficult track I've ever had to learn. Several blind sections into esses and on/off camber turns making things very technical. Also, several 2nd gear turns which I hate...one of which I completely blew on this lap.
Fastest lap of 2:38.17
The Following 3 Users Say Thank You to justinco For This Useful Post:
Dzmitry (11-14-2023), RedReplicant (11-10-2023), villainous_frx (11-10-2023)
Old 12-13-2023, 11:03 PM   #19
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
New PB (CW) at the SoCal 86 Cup Chuckwalla rounds a couple weeks ago. CCW day was 2nd place in Unlimited class (went slower than previous visit though) and CW day was 1st place (new PB by few tenths). Getting really close to sub2 times at Chuckwalla now with just minimal upgrades (and fast tires :p ).
Didn't notice much difference testing 5W-40 weight oil, compared to 5W-30.
CCW lap of 2:01.146
CW lap of 2:00.688
RedReplicant (12-14-2023)
Old 12-14-2023, 01:13 AM   #20
grippgoat
Drives: 2023 BRZ, 2018 Golf R 6MT
Did you feel a difference with the Perrin strut tower bar? I know people say "modern cars are so stiff blah blah" but I _felt_ a difference when I added one on my Golf R, and its shock towers are way closer to the cowl than the BRZ. I have no idea if it made the car faster, but it made the front end feel more precise, and just more enjoyable to drive.
grippgoat is offline   Reply With Quote
Old 12-30-2023, 01:15 AM   #21
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Arrow
No, not really. I may go back to the Cusco strut bar with integrated master cylinder brace. Easier to fit/route things like the oil pressure sensor and oil accumulator. Plus, I'm getting it powder coated to better match the car/engine bay!
Also, new parts going in soon.
The Following 2 Users Say Thank You to justinco For This Useful Post:
DocWalt (12-31-2023), RedReplicant (12-30-2023)
Old 01-21-2024, 09:09 PM   #22
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Moroso accumulator installed along with a Canton 35-40psi pressure switch on an electric valve.
Back to Chuckwalla this weekend to test and see how it goes.
The Following 5 Users Say Thank You to justinco For This Useful Post:
blsfrs (01-22-2024), dowroa (01-21-2024), RedReplicant (01-22-2024), villainous_frx (01-23-2024), whataboutbob (01-22-2024)
Old 01-22-2024, 01:01 PM   #23
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I'll be curious to see how this set up works. A couple of years ago, I had the Canton valve on my car. After a couple of months, the pressure switch would burn out..
From what I've seen, the drop in pressure in right handers is momentary. By the time the switch reacts, the pressure is coming back up anyway. On my Gen 1, I run my Accusump as a "dampener" with out a Pressure switch.
The Following User Says Thank You to blsfrs For This Useful Post:
justinco (01-22-2024)
Old 01-24-2024, 09:22 PM   #24
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I may test it without the pressure switch as well. I think I can just swap the hot wire from the switch directly to the solenoid valve.
blsfrs (01-25-2024)
Old 01-29-2024, 06:46 PM   #25
smoltz
Drives: 01 911 Turbo, 03 G500
Great content!
Do you have any before/after data with lowering springs? Are you running them with factory shocks?
I figured that a sticky tire like A052 or RE71RS would really overdrive the factory shocks/springs but maybe that's not really the case. Trying to figure out a good setup for Time Trial. It's all point based though so to stay in class, adding Coilovers means adding weight or giving up A052/RE71RS for something like RT660.
smoltz is offline   Reply With Quote
Old 01-31-2024, 10:49 PM   #26
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by smoltz View Post
Great content!
The before/after data with the Eibach springs is that they don't make you go any faster on the track, if that's what you meant. They are slightly stiffer spring rate but it's barely noticeable.
The RE71RS for sure overdrives the OEM shocks, but it works for the most part.
dowroa (02-02-2024), smoltz (01-31-2024)
Old 02-19-2024, 02:38 PM   #27
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Forgot to post this, but here is the first round of testing with the Moroso oil accumulator:
The Following 4 Users Say Thank You to justinco For This Useful Post:
autoracer86 (02-19-2024), blsfrs (02-19-2024), RedReplicant (02-19-2024), smoltz (02-19-2024)
Old 02-19-2024, 09:09 PM   #28
blsfrs
blsfrs's Avatar
Great information. I may have missed it in the video but what was your air pressure precharge? Canton recommends 7psi. I'd like to see if a higher precharge would provide a quicker recovery of the oil pressure.
Anyone have any updates for their 2022 GR86? Icekraks AUSTRALIA 0 01-29-2023 08:15 PM
San Diego: 2022 GR86 OEM Premium GR86 Rims GRime86 Wheels and Tires 3 12-10-2022 04:52 PM
2022 GR86 or keep my modified 13' frs jiffyjhn GR86 General Topics (2nd Gen 2022+ Toyota 86) 75 02-19-2022 12:59 AM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-12-2022 11:44 PM
2022 GR86 MSRP 2k over the BRZ? mangler CANADA 5 12-06-2021 10:51 AM
