Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 06-01-2023, 05:02 PM   #15
Teseo
Drives: frs
My FA20 spun a bearing on 5w-30 during an autox, 117k miles, the last 40k miles were on 5w-20, first 75k we’re on 0w-20, sticking with 0W-20 for the second build. ymmv
Thats odd... I thought 5w-30 give better protection because it retain better oil presure
Old 06-02-2023, 10:27 AM   #16
Tokay444
Run 0w40 Mobil1 FS year round and forget about worrying about oil.
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
dsc_pat (06-06-2023), new2subaru (06-22-2023)
Old 06-02-2023, 10:29 AM   #17
Tokay444
Without a shadow of a doubt, I can say the reason the bearing spun had nothing to do with the oil's viscosity numbers.
The Following 6 Users Say Thank You to Tokay444 For This Useful Post:
dsc_pat (06-06-2023), Dzmitry (06-07-2023), H380 (06-02-2023), Jdmjunkie (06-02-2023), vindiesel (06-02-2023), ZDan (06-02-2023)
Old 06-02-2023, 05:42 PM   #18
strat61caster
strat61caster's Avatar
ineedyourdiddly
Old 06-04-2023, 09:52 PM   #19
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by cmiovino View Post
If it's just one a month, 0w-20 is fine. Just about everyone here running gen 2's runs 0w-20, including top-dog national level drivers. They push their cars hard.
I'd say part of that is actual national level drivers aren't worried about their warranty and don't care about dropping the pan to check for excess RTV.
Those guys operate at a different $$$$ level than us middle-class plebs for the most part.
Originally Posted by VoltsFRS2013 View Post
5W20 isnt that far off your OEM weight, and it's already in the manual in gray area fine print that you can run that weight anyways lol. That being said, I'd be changing your oil after every event if you're doing some hard hard driving.
Depends on which book you look at. It just says "USE 0W-20 Synthetic" Page 42 of the 2023 BRZ Getting Started Guide:
ENGINE OIL
Use 0W-20 synthetic, with one of the following specifications:
• API classification SN with the words “RESOURCE CONSERVING”, SN PLUS with the
words “RESOURCE CONSERVING”, or SP with the words “RESOURCE CONSERVING”.
• ILSAC GF-5 or GF-6A, which can be identified with the ILSAC certification mark
(Starburst mark).
https://techinfo.subaru.com/stis/doc...2306A_STIS.pdf
Page 382 of the 2023 Owners Manual says:
0W-20 synthetic oil is the required oil for optimum engine performance and protection. Conventional oil may be used if synthetic oil is unavailable.*: If 0W-20 synthetic oil is not avail-able, 5W-30 conventional oil maybe used if you need to add oil. However, you should change to 0W-20 synthetic oil at the next oil change
So they are saying use 5W-30 in a pinch, not they are suggesting running it full time.
https://ownersman.com/manuals/2023-S...-owners-manual
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
soundman98 (06-04-2023)
Old 06-04-2023, 09:57 PM   #20
soundman98
ProCrastinationConsultant
soundman98's Avatar
but it's really only for warranty coverage.
we could all run 75w gear oil if we so desired, nothing is physically stopping us...
Old 06-04-2023, 10:18 PM   #21
OkieSnuffBox
Well it's also the spec they designed for which they designed the engine.
So run some 75w-140w probably have great oil pressure.
Old 06-05-2023, 10:34 AM   #22
removedonut
Drives: 2022 Toyota GR86 Premium 6MT
0W20, 5W20, and 5W30 are all accepted oil weights (to run full-time, not just in a pinch) in the australian and japanese owner’s manuals. They have the same engines. The TMNA insistence on 0W20 is almost assuredly just for fuel economy reasons.
removedonut is offline   Reply With Quote
The Following 5 Users Say Thank You to removedonut For This Useful Post:
Bonburner (06-16-2023), H380 (06-05-2023), Jdmjunkie (06-05-2023), MrSkubi (06-07-2023), ruturaj001 (06-06-2023)
Old 06-14-2023, 08:10 PM   #23
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Just run 0w20 and change it more often, it’s not hard to do. My 16 BRZ is a commuter and I change every 5k, even though Blackstone said to go more. No track for me, if I was, I would just make sure I was not too far into my OCI (2000-3000) and then change it after the event.
Ernest72 is offline   Reply With Quote
Old 06-22-2023, 03:05 AM   #24
ruturaj001
Drives: BRZ 2023
I am doing it, 5W30 for summer when I am doing track and autocratic, will switch to 0W20 in winter.
ruturaj001 is offline   Reply With Quote
Old 06-22-2023, 02:51 PM   #25
Ernest72
Someone needs to measure oil pressure on the same long sweeping turn on the track with both oil weights. I wonder if the thicker oil will actually lead to better oil pressure. Logic says it should but I wonder.
Old 06-22-2023, 03:24 PM   #26
strat61caster
Already been done on FA20.
https://www.ft86club.com/forums/showthread.php?t=91820
ineedyourdiddly
Ernest72 (07-02-2023)
Old 06-26-2023, 01:17 PM   #27
RaceAddict
Drives: '23 BRZ, '16 4RUNNER
100% agree with that!
Like anything else you may read/watch on the internets, feel free to take anything I'm saying with a grain of salt, do your own research etc... but it seems to me that 0W20 being recommended as a one-size-fits-all solution is entirely down to EPA mandates and automakers striving to hit fuel economy numbers.
Here's an article from 2012, which I believe is a year after the 0W20 mandate came into play:
https://www.consumerreports.org/cro/...cars/index.htm
I'd suggest it has nothing to do with "tighter manufacturing tolerances" and everything to do with legislation.
And remember, the EPA doesn't care how long your engine lasts.
Ordered GR86: March 17th, 2022
-453 days later-
Jumped ship, ordered BRZ: June 13, 2023
Picked up BRZ: June 19th, 2023
RaceAddict is offline   Reply With Quote
The Following User Says Thank You to RaceAddict For This Useful Post:
Tokay444 (06-26-2023)
Old 07-02-2023, 05:30 PM   #28
Ernest72
Looks like 5w30 is a good idea for hot weather tracking. I am street only so sticking with 0w20, plus I have two very good oil analysis going with 5k changes.
The Following User Says Thank You to Ernest72 For This Useful Post:
strat61caster (07-05-2023)
All season vs Summer Tires Mrt1990 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 90 11-13-2020 01:50 AM
AutoX season is upon us! (2018) SoloIIscoob NY / NJ / CT / PA 22 04-27-2018 09:47 PM
Summer or All season? Flame9020 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-04-2017 09:00 PM
Oil weights for summer Whats that smell? Arizona 24 05-06-2016 01:14 PM
Summer preformance VS All season performance ScionFamily Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-06-2013 08:11 PM
