Old 05-03-2023, 05:41 PM   #15
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
The sidewall is not designed to support the weight of the car without the accompanying volume of pressurised air.
Understood and it makes perfect sense. I've just never had it happen to any tires before. And I've had plenty of situations with lower pressure in a tire in the past. But then again, this is also my first experience with UHP A/S tires, so I'm sure that plays a big factor. Smaller sidewalls than I'm used to as well.
Dzmitry is offline   Reply With Quote
Old 05-10-2023, 11:32 AM   #16
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Yep. Only run-flats can do that and even for only a short period of time.
You can watch tires separate in a similar fashion in just about any race series when the car gets a flat. It's pretty educational to watch.
The tire goes flat, and if the car is a long distance from the pits, you can watch the sidewall split and the tire carcass start flapping around on the wheel. In the really bad cases, the carcass will come apart too and start destroying the body work and suspension bits of the car as it rolls along.
This case isn't quite that catastrophic, but the same idea applies.
Desertnate is offline   Reply With Quote
The Following User Says Thank You to Desertnate For This Useful Post:
Dzmitry (05-15-2023)
Front tire damage in skidpad. andyk5 Tracking / Autocross / HPDE / Drifting 15 09-19-2022 04:07 AM
tire damage question? Thet Scion FR-S / Toyota 86 GT86 General Forum 12 03-26-2015 03:07 PM
Nail in the sidewall ApoNono Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 02-15-2013 07:54 PM
Damage to built up area of sidewall/stock tire. Zadkiel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 09-25-2012 09:03 PM
Tire Sidewall Question applekash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-26-2012 08:42 PM
