Old 04-14-2023, 04:22 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Drake_93 View Post
I know a line bore can be done, I haven't personally looked into it but I know it's needed if you go for stronger than OEM case hardware.
My main concerns were trying to figure out what else may be needed to keep it together on the higher end.
Generally, I know IAG has short blocks, but for 4800 for just a short block it's out of my price range for right now... (student loans and only just starting my career) I know with what parts I already have, and what I'd need to buy to rebuild this engine I'd be well below that. There's a local race shop that can do the machine work, for less than $500 (block, bore and hone, then clean the heads).
I might look at just bore and honing the block, putting in better internals and just refreshing the heads... and then redo them later on. For now, I just want an engine that can comfortably push 350-400, and maybe have a map I can run ~450hp for my last 2 runs. Our autocross courses usually see 70+mph at 1-1.5mi long.
Even stock, it is not uncommon for the cases to be out. NA, I was planning on line boring if I was to build.
Old 04-14-2023, 05:06 PM   #16
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
pick up a 3.7 or 3.9 FD that is what I'm doing. You are going to need a lot to hold that power
Breadman is offline   Reply With Quote
Old 04-16-2023, 06:21 PM   #17
Drake_93
Drives: 10-Series Turbo FR-S #2483
I've heard of this but it's beyond what I know currently...
Is this something you can check on your own or does it require advanced machinery?
Is there an amount that is tolerable if you're still running the engine to only 7400-7500RPM? I know physically more power/RPM will make it considerably worse, but I'm on a factory block now that's been running ~350wheel for 2 years ~40k mi ( at that power level)
Drake_93 is offline   Reply With Quote
Few questions regarding a MY17 build texastwurkt3am Engine, Exhaust, Transmission 26 01-09-2018 07:47 PM
HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions Corradooo Engine, Exhaust, Transmission 2 11-25-2017 08:16 PM
SIMPLE! Beginner Build Questions NicoFRS Engine, Exhaust, Transmission 28 09-22-2017 06:33 PM
soundman's audio build and questions soundman98 Electronics | Audio | NAV | Infotainment 0 01-20-2014 09:59 PM
400hp build and other turbo questions. Ludacrits Forced Induction 22 10-26-2013 10:01 AM
