Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-21-2023, 02:01 AM | #15 | |
Drives: Toyota 86
03-21-2023, 11:25 AM | #16 |
Drives: Crapcan
Yeah I know. I had always heard packaging being tight as a rumor. Cost above all is probably the primary.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | norcalpb (03-21-2023) |
03-22-2023, 09:30 AM | #17 |
It can and probably is a bit of both. Each of these things does not exist in isolation from the other.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | foshjowler (03-22-2023), NoHaveMSG (03-22-2023) |
03-22-2023, 09:35 AM | #18 |
They certainly weren't going to design an all new suspension architecture for the BRZ/86...the existing Subaru design was the only way (tweaked obviously for the specific car).
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | NoHaveMSG (03-22-2023) |
03-22-2023, 11:37 AM | #19 |
You mean they aren't hand built to individual specifications by master craftsmen?
The Following User Says Thank You to Tcoat For This Useful Post: | Racecomp Engineering (03-22-2023) |
03-22-2023, 03:18 PM | #20 |
Drives: 2013 GT86 fully standard
I did the upgrade some people mention in the thread. 2019 low mileage dampers and whiteline lowering springs, and camber bolts up front. It made the car more compliant over harsh bumps, even though it was lowered. Balance on track is way more neutral than the oversteer bonanza that was the original set-up. I still fry my tyre walls, but at least slightly less so. The alignment made and balance change was great, could attack much harder into the corners, and it feels more agile aswell.
Would ideally want less camber at the rear, but i dont have any adjustability there, at least not for now.
2013 GT86, fully standard daily and occasional track day car
03-31-2023, 12:32 AM | #21 | |
2013 Series 10 FRS #553
07-24-2023, 09:43 PM | #22 |
Drives: 2013 FR-S 6 spd in Halo
I am going to revive this thread with a question. I am about to replace my rear upper controls since I found a torn boot on the drivers side upper ball joint. Are the two inner bolts on the UCA adjustable for alignment?
They don't look to be, but then I found this in the factory manual: c) Inspect and adjust the toe-in and camber. (1) Inspect the toe-in and camber. Inspect the toe-in and camber. If the values are not within the specified ranges, adjust the installation bolt holding the rear suspension member to the vehicle body, or the bolt holding the upper control arm and rear suspension arm so that the values fall within the specified ranges The question really boils down to: After getting an alignment in the spring, do I have to shell out another $140 for an alignment after I replace the UCA's? Thanks, Go Fast, Take Chances |
07-24-2023, 10:22 PM | #23 | |
extra what?
2. Even when reassembling the same parts, they won't go together exactly the same way. Yes, always verify/adjust alignment after making any changes to related components.
07-26-2023, 07:50 PM | #24 |
OK. So obviously, that's not what I REALLY wanted to hear, but am I missing something, or is the only adjustment in the rear (with factory parts) the toe?
07-26-2023, 09:20 PM | #25 |
Drives: 2018 BRZ
Yes, there is no rear camber adjustment without going aftermarket.
The service manual instructs using crash bolts ("service bolt") for front camber adjustment. Front caster and rear camber are non adjustable and the manual states "inspect the suspension parts for damage and wear" without recourse for adjustments. |
Tags |
negative camber |
Similar Threads | ||||
Question About Negative Camber: More Negative Camber == More Grip at Corner? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 03-10-2019 02:08 PM |
t86rs rear suspension. stock but 2.6 degree neg camber??? | Crunk81us | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 10-18-2016 04:55 PM |
Spc control arms and negative rear camber question | pbirmingham1988 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 08-20-2016 01:57 PM |
Rear negative camber and adjustable arm | Chase1996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-07-2016 12:36 AM |
Advice on negative rear camber | Thongpocket | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 09-27-2013 10:38 PM |
