Old 03-22-2023, 12:25 PM   #15
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by wheelhaus View Post
I have heard mention of the harness upgrade, but haven't done a deep dive into it yet. Repeated P0351 misfires, ultimately cyl 1 coil pack failures, have happened like clockwork every 2-2.5 years.
The 2015 coils are vastly superior. However they aren't compatible with the plugs on the 2013/14 harness so to update the coil packs, one must also update the harness. This assumes a simple adapter from a 2015 coil to 2013 harness does not exist (it didn't when I updated mine). 3 Racing seasons, not a single failed coil.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
wheelhaus (03-22-2023)
Old 03-22-2023, 07:02 PM   #16
Lantanafrs2
Drives: 2013 frs red
I recently installed a 2015 motor into a 2011 forester and spliced in the later coils to the original harness. Not too involved.
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
wheelhaus (03-23-2023)
Old 03-23-2023, 06:56 PM   #17
wheelhaus
wheelhaus's Avatar
I was curious about this, but not sure how sensitive the ignition system is in the BRZ under high temp/high load with spliced ignition wiring. Arguably a situation few Foresters will ever see.
There are adapters now (which I can't find anything negative about). The company that makes the adapters also sells pre-terminated pigtails. This option is really tempting; wire splicing is something I'm plenty comfortable with.
https://www.icefabrication.com/produ...grade-to-2015/
https://iwireusa.com/products/ignition-coil-plug-e
Regarding the harness itself, I'm finding some confusion with PNs. The TSB states the 2013 and 2014 use different update harness PNs, but the harness PNs for the 2015 and 2016 model years are both 24020AG080, same as the 2014 in the TSB. Is it not compatible with the 2013?
https://static.nhtsa.gov/odi/tsbs/20...31587-9999.pdf
wheelhaus is offline   Reply With Quote
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
Lantanafrs2 (03-23-2023), T-Steve (03-23-2023)
Fuel injector Service? HeadBanger CANADA 7 02-03-2016 10:52 PM
Best way to tackle the torque dip Kuri Engine, Exhaust, Transmission 37 02-27-2014 07:52 AM
