#15 | ||
Drives: Nevermorange FRS
It's very likely the problem is in the chain/timing. It could be possible it's crankshaft position sensor which is pretty easy to remove and check. It turns out when 1 bank is off by 1 tooth, it still starts and idles just fine and even run pretty much OK (but with less power). Start here at post #259: https://www.ft86club.com/forums/show...132443&page=19 I don't know how SSM works but if you can load different stock maps, then you CAN reset the initial learning values if you flash in a map from a different year, then back. I discovered that I could RESET my initial learning values when diagnosing my issues. I have a 2013 car and once I flashed to a 2016 stock tune file, then back to my 2013 file, it reset the values. Something I could verify with Techstream. This is a vastly superior option than buying a new ECU!!
SCCA T4 - FRS
| The Following 4 Users Say Thank You to rice_classic For This Useful Post: |
#16 | |
not playing cards
I thought of your experience as well. I don't understand the zero values you saw in the table after the reflash but hell, if it works, it works!
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | soundman98 (02-01-2023), x808drifter (02-03-2023) |
| To everyone else who has rebuilt an engine | demasrv | Engine, Exhaust, Transmission | 18 | 02-03-2022 12:34 AM |
| FR-S engine rebuilt and knocking | DJjoey0812 | Issues | Warranty | Recalls / TSB | 2 | 01-16-2020 07:46 PM |
| Good Performance shops to get a engine rebuilt | reckless_brz | Southern California | 47 | 01-19-2016 01:25 AM |
| Major accident/Engine failure after repeated P0351/P0017/P0019 | DB86 | Issues | Warranty | Recalls / TSB | 48 | 09-16-2014 04:05 PM |
| Testing a Rebuilt Engine | Exage | Other Vehicles & General Automotive Discussions | 0 | 04-29-2011 10:42 PM |
