| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
#15 | |
Drives: 2005 Toyota Camry
My Quickjack 5000LT (bought in 2019) worked well for a variety of vehicles. without extension ramps, it worked for my S13, S14, and a friends BRZ with extension ramps, it worked well for my Subaru Legacy, Lexus ES, Volvo V60 CC, a couple of Honda Odysseys, and a Tesla Model 3. for extra height I use the larger blocks. for something close to a truck I'd rather use the larger 7000 series lifts. the basic 5000 unit is good for smaller 2 door or 4 door cars with short wheelbase. |
#16 | |
Famous Potatoes
Drives: '15 ultramarine
#17 |
same as what I have then, I have the regular one with SLX extension frames.
not ideal for a truck, I agree, but I can also lift my car up and do a tire rotation, oil change, and anything else within an hour. YMMV. and obviously you need to be able to push around a 100lb frame on the floor. |
#18 |
Persona Non Grata
Drives: '15 BRZ (WRB)
I found that a foot long 1x8 laid flat across the front of the ramp provided enuf lift to work with the ramps.
Slow is smooth, and smooth is fast
#19 |
Drives: Crapcan
The problem I see with the Bendpak is it's limited use. How do you service the transmission fluids with all that stuff in the way? With the quickjack you can at least still get to everything. It may not be the easiest with only front/back access but you could drop the transmission still. Absolutely not possible with the Bendpak.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | soundman98 (01-03-2023), Wally86 (01-04-2023) |
#20 | ||
you're not moving that thing once it is put down in the garage. at least with the Quickjack I can easily lift it to be stored vertically on the hanger hooks that is included with the kit via Costco. sure there might be easier or cheaper setups, but I really have not found anything else that can be as flexible for a variety of cars, stock or modified. |
#21 | |
The Dictater
Drives: '13 Red Scion FRS
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
| The Following User Says Thank You to Spuds For This Useful Post: | finch1750 (01-04-2023) |
#22 | |
if you use any lift point more inward then you lose access to the drivetrain. Quickjack is useful for doing 4 wheel rotation, any moderate suspension work involving all 4 wheels, any front engine work, or even just storing the car in an off-the-ground state for an extended period of time. |
#23 | |
The Dictater
#24 | |
Drives: 2018 BRZ
That's my thinking as well. I also doubt Quickjacks are really that much less of a hassle (than jack and stands) - seeing uncut videos of people lifting their cars there's still a bunch of fiddling with positioning - raise the jacks, check alignment, raise some more, check again, etc. (and do that on all 4 corners at once, so walk around the car a bunch of times). The biggest benefit would be if you need to raise and lower the car a bunch of times without driving it (maybe for suspension work where you want to torque down bolts with the suspension loaded?), but otherwise I just can't get myself to consider the splurge on Quickjacks over jacks and stands. |
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | Spuds (01-04-2023) |
#25 | |
Drives: 2017 BRZ
I use mine for annual maintenance and alignment where the car is up and down a lot. Way too much setup work for the winter tire swap and even just for an oil change. They're heavy and I have little access one side of the car making it really difficult to position, though i do usually move the car over a bit first which helps. I got mine when I decided to start doing my own alignments and corner balancing. That's a minimum of once a year, maybe more.
| The Following 2 Users Say Thank You to cjd For This Useful Post: | Ohio Enthusiast (01-04-2023), Spuds (01-04-2023) |
#26 |
Drives: 2018 BRZ
#27 | |
Be Kind
Drives: 2020 86
Other than that annoyance, I've loved mine any time I need to get under the car. For me, it makes oil changes fun. I can get on the creeper and check the rest of the car from front to back too.
| The Following 4 Users Say Thank You to Wally86 For This Useful Post: | Kaotic Lazagna (01-04-2023), Ohio Enthusiast (01-04-2023), Spuds (01-04-2023), Ultramaroon (01-04-2023) |
#28 | |
The Dictater
| What is my BRZ Worth? | RWDWeekend | BRZ First-Gen (2012+) — General Topics | 23 | 01-26-2021 08:18 PM |
| STI lip kit worth anything? | EzyBrzy | BRZ First-Gen (2012+) — General Topics | 17 | 10-07-2015 07:32 PM |
| It is worth it to get BRZ? | nutstae | BRZ First-Gen (2012+) — General Topics | 58 | 06-17-2014 12:50 AM |
| Is it worth it? | Greaser | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 08-10-2012 10:15 AM |
| is this worth doing | denverizzles | Engine, Exhaust, Transmission | 7 | 08-03-2012 11:35 AM |
