#15 |
The mid muffler.
The break was midway above this. Heat could definitely be a factor. |
#16 |
The Dictater
Drives: '13 Red Scion FRS
Is it also possible that the muffler could have bounced or been bumped into the drive shaft?
Haven't seen harmonics mentioned so I'll throw it out there as a possible contributing factor. If you are racing around off road it's possible you hit some weird frequency between the front and rear bouncing around at different rates and moving around relative to each other. If it's a track, that might be repeated each lap. More likely heat or muffler related though.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
| The Following 3 Users Say Thank You to Spuds For This Useful Post: |
#17 | |
not playing cards
| The Following 6 Users Say Thank You to Ultramaroon For This Useful Post: | bcj (01-04-2023), blsfrs (01-02-2023), grumpysnapper (01-02-2023), NoHaveMSG (01-02-2023), soundman98 (01-02-2023), Tcoat (01-03-2023) |
#18 |
AutoX-10/10ths every run
There's evidence of a polish mark on the muffler (cover?) and the weld looks like it's missing some material?
#19 |
| The Following 6 Users Say Thank You to grumpysnapper For This Useful Post: | bcj (01-04-2023), blsfrs (01-02-2023), churchx (01-03-2023), NoHaveMSG (01-04-2023), Ultramaroon (01-02-2023), x808drifter (01-09-2023) |
#20 | |
| The Following User Says Thank You to grumpysnapper For This Useful Post: | Spuds (01-02-2023) |
#21 |
| The Following 2 Users Say Thank You to grumpysnapper For This Useful Post: | whataboutbob (01-02-2023), x808drifter (01-09-2023) |
#22 |
Drives: 2013 frs base
I was looking at the same thing. My DDS AL shaft broke exactly in the middle due to exceeding its critical speed.
| The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
#23 |
not playing cards
Ah, that was yours! Now I remember. You were on a dyno and felt no warning.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (01-02-2023) |
#24 |
Since you already have the machined end parts have you considered buying a CF driveshaft blank and bonding up a new one?
| The Following User Says Thank You to Grady For This Useful Post: | x808drifter (01-09-2023) |
#25 |
Drives: Crapcan
I don't trust anything DSS makes after your failure. That was a huge oversight by a company that has "drive shaft" in their name.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#26 | |
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | Ultramaroon (01-03-2023), x808drifter (01-09-2023) |
#27 |
Drives: 2014 GT86
Wasn't stock 2-piece made such, so that to allow it to buckle in case of frontal crash impact, so that engine can be pushed under passenger compartment?
It's drawbacks .. i guess slight (but probably not that immense) play in extra joints, slightly more expensive .. and a bit heavier .. hmm .. i wonder if it's not worth to leave it as is, if it's designed/engineered for extra safety .. |
| The Following User Says Thank You to churchx For This Useful Post: | blsfrs (01-03-2023) |
#28 |
not playing cards
Yes. Also with all other properties being the same, shorter driveshaft will be able to spin faster without failing. I'm not a fan of any of these single-piece driveshafts. The only upside is a few kilos trimmed. Not worth it.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
| Driveshaft Shop 1-Piece Carbon Fiber Driveshaft | Jordan Silveira | Transmission and Driveline | 4 | 04-07-2022 02:25 PM |
| SOLD Please Remove. (Dallas, TX) Driveshaft Shop Carbon Fiber 6MT Driveshaft | Brzzee | Transmission and Driveline | 1 | 09-14-2018 09:22 AM |
| Driveshaft Shop Carbon Fiber Driveshaft (MT) $650 [SOLD] | acj47 | Transmission and Driveline | 2 | 10-25-2017 05:07 PM |
