Old 07-28-2022, 03:51 PM   #15
strat61caster
strat61caster's Avatar
I got new high pressure fuel lines, iirc they were pretty cheap (<$200) vs. the time to take to disassemble and replace them if they turned out to not be re-usable. But of course if this is preventing you from getting around town as long as you're careful go ahead and send it, be on the lookout for leaks before you fire up the engine for the first time.
And make sure your ECU is fully bolted down before running the engine, not doing that I thought I had fucked up one of the seals and was getting a misfire. Nope, bad ground.
ineedyourdiddly
brandonblt2 (07-28-2022)
Old 07-28-2022, 04:19 PM   #16
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Originally Posted by blsfrs View Post
I reused my hp lines. (100k miles). I put a dab of pipe dope on the threads for reassembly. Maybe not completely necessary but, what the hey. No problems after 2000 miles.
Ah ok I ended up buying new lines. I'm at 185k and don't want to risk a fire or a leak forcing me to take everything apart again. But that's a good idea to add some thread sealer.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
The Following User Says Thank You to brandonblt2 For This Useful Post:
blsfrs (07-29-2022)
Old 07-28-2022, 04:38 PM   #17
strat61caster
fwiw factory process is to install dry, if you've got fresh lines I wouldn't add anything to them other then making sure the parts are all clean.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
blsfrs (07-29-2022), brandonblt2 (07-29-2022)
Cleaning direct injectors after E85 use SPCorBUST Engine, Exhaust, Transmission 14 01-15-2022 12:36 PM
SOLD Direct injectors bhmax Engine, Exhaust, Bolt-Ons 3 12-21-2020 04:02 PM
OTC Direct Fuel Injector Seal Installation Tool EWY Engine, Exhaust, Bolt-Ons 6 08-26-2017 10:05 PM
Direct Fuel Injectors Silverspeed Engine, Exhaust, Bolt-Ons 0 10-20-2016 08:04 PM
Additional sealing for direct injectors? Dmitri Engine, Exhaust, Transmission 6 05-16-2014 03:40 PM
