Old 07-14-2022, 03:13 PM   #15
Tread, no threads in tires, it's not a blanket.
Well there actually are but if you get to them then the tread wear is sort of a moot point.
Old 07-14-2022, 04:13 PM   #16
strat61caster
strat61caster's Avatar
Those are cords.
They stopped using weavers to make tires last century old man
ineedyourdiddly
Old 08-29-2022, 11:14 AM   #17
andys_garage
Drives: 2022 GR86 Premium Track bRed
Originally Posted by Gearhead1 View Post
I’m not a tire expert and I may not fully understand Guth’s explanation. Has anyone else seen this kind of wear (I call them missing strips of rubber, Guth called them “lines on the tread”)? If so, what was the cause and what was the fix? Any suggestions for me?
i *am* a tire expert - I would call this a 'flow crack' - when the belts shrink inward during curing, the uncured rubber flows in to fill the space, which sometimes causes rubber from the surface to pull down towards the belt edge. It's probably not very deep, just keep an eye on it.
andys_garage is offline   Reply With Quote
Old 08-29-2022, 02:54 PM   #18
jflogerzi
jflogerzi's Avatar
For those are running 660's what PSI do use hot?
2013 Series 10 FRS #553
Old 08-29-2022, 03:02 PM   #19
Pat
Pat's Avatar
Drives: 2023 BRZ
37 - 38
Old 08-29-2022, 03:18 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I ran 34-37.
Old 08-31-2022, 03:07 PM   #21
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
On 245/40r17 on a 17x9 wheel, with -3f/-2.2r camber and 0 toe, I run them ~31 hot. This might be *slightly* low but I've got decently even wear across the tire although I can tell I'm wearing the outside more than the inside so I'm still not running enough camber but I've also got noticeably increased inner tire wear on my street tires so I'm not in a rush to go adding more, this seems like a decent middle ground since I'm not going to be getting a whole lot more out of either tire even with more optimized settings.
Lynxis is offline   Reply With Quote
Old 09-01-2022, 09:22 AM   #22
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
255/40r17 on 17x9, -4 camber in front, for autocross purposes I ran 29 in front, 28 in rear.
Temp probe showed even temps inside/outside/middle in the front. Rear was same outside/middle, little warmer on the inside.
Breezio is offline   Reply With Quote
Old 09-09-2022, 08:59 AM   #23
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
As someone still fairly new to the world of performance driving and running non-stock tire widths I noticed a trend in the last couple of posts:
The wider the section width the lower the air pressure in the tire, even on wider wheels. Is this do there being less chance of the tire rolling over on the sideway because of the extra width, the additional negative camber being used, stiffer sidewalls on the wider tires, or a combination of factors?
I'll leaning heavily towards the 660's next season in 225 and trying to learn as much as possible to make any test-and-tune event be more productive.
Desertnate is offline   Reply With Quote
Old 09-09-2022, 10:37 AM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you are new and trying to learn as much as possible, don't run the RT660's. Like other super 200 tires, they are only good for a couple good laps before they drop off considerably unless it is cloudy and cold. If you insist on a 200TW tire, the V730 or RS4 are way better options as they will perform far more consistently over an entire session.
Old 09-09-2022, 12:57 PM   #25
Desertnate
Spelling Impaired
Thanks.
I used "new" as a relative term. I've got four AutoX seasons under my belt, but that's not much compared to a lot of folks here. Everything in the street classes in a couple different cars. I still fully admit to having plenty to learn. My real lack of knowledge is in running mods like 200TW tires.
I did manage to run a couple events in my previous car on a set of RS-4's for a couple of autox events and really liked them vs running on summer tires. They were my first introduction to a 200TW tire vs a summer tire I'd run before (PSS and PS4's). I was looking to step up in platform as well and initially thought about the RS-4's or RT615's, but the call of the 660's was strong since I'll the autox'ing them and won't really do any track days.
I may re-evaluate my plans.
Old 09-09-2022, 01:04 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks.
AutoX'ing them should be fine since the run is so short, I probably shouldn't have just assumed you meant track work.
Old 09-13-2022, 03:28 AM   #27
Lynxis
Lynxis's Avatar
My experience is that the 660s can take a bit more heat than other tires in it's class. I'm primarily HPDE/lapping and just do autocross when something local is going on but at the very least, they hold up to lapping in comfortably warm weather (28c/82f) without significant fall off.
My impression in autocross on hot days (33c/91f) is that I can feel more grip in later runs as I get more heat into the tires, although perhaps my experience should be taken with a grain of salt given that I was the second slowest twin out of about a dozen at regionals this year, the only slower car was a complete novice while I've done track and autocross casually for the last ~6 or 7 years.
Old 09-13-2022, 09:29 AM   #28
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I'll chime in with my pressures on 225/45/17 660's. 31 front, 26, rear. Car also has a 19mm Perrin FSB on stiff, Sachs dampers, and that's about it.
As far as pressures, the general way I get to a certain pressure setup is to lower the front as low as possible to hit the triangles on the sidewalls. For this tire, that ended up being 31.
The rear is then tweeked to match the balance you want. With only -1.1 degrees of camber up front, 31 is the magic sauce there, but the rears need to be kept lower down at 26. I'm basically right on the triangles there and the car is general is going to push before the rear kicks out hard. I've set them to 28PSI with my co-driver and he immediately notices a difference and asks to lower them 2PSI... even when I didn't tell him I set the to 28.
I'd suspect with more camber up front, I could lower the front into the 28PSI range and the rears probably a bit lower too.
As far as the tire in general after 170+ runs the year, I'm not totally impressed. Price-wise, they're a good value. The wear well, but will heat cycle out near around 125 runs with more than half tread left. After about 150 runs, they really start losing grip. I've had RE-71R's and the drop off is about the same with those.
I had the A052 Yoks last year even on a ~1 degree low camber setup and they wore fine for me. Noticeably more grip and a better balance. I really like these more than the 660's, but they're $230/tire vs $165 in my size. For autox only purposes - if you're doing track too, the 660 is likely the ticket there.
cmiovino is offline   Reply With Quote
Looking for a set of OEM BRZ DRL Strips s0sl0w Cosmetic Modification (Interior/Exterior/Lighting) 7 04-13-2015 09:18 PM
What headlights to pair with LED strips? l0aded Cosmetic Modification (Interior/Exterior/Lighting) 4 06-24-2014 04:37 PM
Rubber Strips on the top of the car zackcp04 Scion FR-S / Toyota 86 GT86 General Forum 3 05-31-2014 10:44 PM
RGB LED strips help BadLuckZN6 Cosmetic Modification (Interior/Exterior/Lighting) 1 01-21-2014 01:21 PM
Fender Strips, Thoughts? Style FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 29 06-10-2013 09:54 PM
