Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 05-03-2022, 02:17 PM   #15
X25
Sr. Spiritual Advisor
X25's Avatar
Drives: 2023 BRZ Premium
** Canceled the RPF1s, and will likely be getting the ARC-8s. Thanks for the feedback : ))
Originally Posted by Racecomp Engineering View Post
The OEM pads are garbage and feel like smushing sourdough bread (extra butter) onto the rotors. I'm exaggerating, but I wouldn't worry about the factory pads. OEM design parameters are not too much of a concern here.
Coilover manufacturers do a lot of things for a lot of different reasons. Sometimes those reasons are performance related.
For what it's worth, the 450/550 with the karcepts front bar at the softest setting will be more front biased than a 550/550 set up with OEM swaybar. Then up from there as you make the bar stiffer. And that's not necessarily a bad thing!
Also this...the 17x9 +35 RPF1s don't have great BBK clearance and can be limiting.
- Andrew
I relied on CSG for the pad choice, and Karcepts for the spring rate balance. My favorite pads are Raybestos ST43/47, but they're out of stock. I'd likely try those next when it's time to replace the pads, if the stocks get replenished. There are also new sintered pads from EBC (SR11, etc.), which promise to be non-corrosive on the wheels, and have even more life than Raybestos pads while retaining good bite. Here's a related thread:
https://www.corvetteforum.com/forums...-compared.html
Regarding spring rates, as far as what I understand from my long (and awesome!!) discussion with Karcepts, the new cars push more with square spring setup compared to first gen cars.
Spring rate is also much more important than a sway bar when there's heavy compression, like turn-in. My local tracks are all full of sharp turns. Anyway, looking forward to playing with it all once I receive the car and all these parts..
Originally Posted by Stonehorsw View Post
My response was not regarding the quality of the pads, 1st thing I have done was to replace those (along with RBF600). And I assumed that it was a square setup. When, I removed the OEM pads, noticed that those were staggered, with Front bias on the apparent friction.
In other thread I mentioned that, and I am going to update my brake balance calculations based on this info (not perfect, but give some direction)
Running square setup, you’re going to move the brake bias to rear axle.
The fact that compounds are biased more for front bite even from factory is a good sign that they worked on track braking performance, even with those soft compounds. In the end of the day, EBDC, part of ABS, will make sure the brake pressure applied front/rear are proportioned as perfect as possible.
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4
'21 Tesla Y Long Range AWD
'19 Corvette Z06 Z07 (Track Build Thread)
X25 is offline   Reply With Quote
Old 05-03-2022, 06:00 PM   #16
s30series
Drives: 2015 BRZ Series.Blue
Stock brakes. You only need pads and fluid. Experts on this forum agree.
s30series is offline   Reply With Quote
Old 05-04-2022, 01:33 AM   #17
X25
X25's Avatar
You might be right, but in this day of age, I just don't wanna deal with slider brakes with a terrible taper on pads, etc. The AP 299 mm kit erases 20 lbs from front, and will let me quickly replace pads; cool.
Has anyone installed 6 point and race seats in these cars, yet?
Old 05-04-2022, 01:40 AM   #18
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Oh god he's back....
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
NoHaveMSG (05-04-2022), OkieSnuffBox (05-09-2022), RToyo86 (05-04-2022)
Old 05-04-2022, 11:42 AM   #19
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Actually most experts on here agree that The Big Drum Brake Kit is the way to go ...
https://www.carid.com/acdelco/drum-b...SABEgL4h_D_BwE
CincyJohn is offline   Reply With Quote
The Following User Says Thank You to CincyJohn For This Useful Post:
X25 (05-05-2022)
Old 05-07-2022, 07:10 PM   #20
ozafar
Drives: 2015 Scion FRS Release Series 1.0
Both are correct. If you want your car to do a few track days a year, dedicated track pads like xp24s and G4 335 fluid will be perfectly fine.
But if you’re doing one like once a month, it makes more sense to have better heat dissipation… so a bbk would be in your interest
ozafar is offline   Reply With Quote
Old 05-10-2022, 11:11 PM   #21
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Brake master cylinder support?
Midnightsky is offline   Reply With Quote
Old 05-11-2022, 04:44 AM   #22
X25
X25's Avatar
Do we know if this is an issue in second gen cars? The new car is stiffer (which might also mean stiffer firewall), and also BBK would probably be easier on the master cylinder since you probably don't need to slam it as hard as you would with the slider OEM brakes.
Anyway, just thinking out loud.. : )
The Following User Says Thank You to X25 For This Useful Post:
Midnightsky (05-11-2022)
Old 05-18-2022, 05:34 PM   #23
Not with Hoosiers!
Racecomp Engineering (05-19-2022), RToyo86 (05-18-2022)
Old 05-18-2022, 09:12 PM   #24
X25
X25's Avatar
Mike, do you think 299mm kit will be enough for the Hoosiers? You guys still haven't shipped, so I guess we could still upgrade if 325mm kit would be a better fit : )
Old 05-18-2022, 11:41 PM   #25
andys_garage
Drives: 2022 GR86 Premium Track bRed
You mentioned raybestos being out of stock:
I was able to get a set of ST-43 from LPI Racing, but basically he said he called porterfield and they managed to find the materials they needed to make the ST-43 rear on the shelf by chance. Apparently raybestos is moving a bunch of manufacturing stateside due to the shipping problems we have all come to know and love and their manufacturing has been down for a while
andys_garage is offline   Reply With Quote
Old 05-19-2022, 01:26 AM   #26
X25
X25's Avatar
As far as I know, it's the other way around, and they moved their manufacturing to Mexico, which started causing all this even before the supply shortages started. I use ST47s for my C7 Z06 as well, and have been having issues sourcing them last summer, too
Old 05-19-2022, 02:57 AM   #27
Really depends on the ultimate weight of your car, and to a degree, the tracks you run.
Balance wise, the 299 is better; if you want a larger kit, I'd point you to something else. If you want AP, the 9660; if you want Brembo, the BM4.
No ETA on the 9660 either, as Essex is very, very late on all of their updated Sprint kits due to supply chain issues.
Old 05-19-2022, 02:58 AM   #28
It's entirely possible that they just took a larger pad and machined it down to the shape of your smaller pad.
Takumi788's More Track than Street FRS - Now NASA TT Focused Takumi788 Member's Car Journals 473 03-19-2023 10:37 PM
What mods needed to turbo a FR-S TSaanity Forced Induction 64 09-10-2020 03:36 AM
looking for twins-focused shops - track prep/maintenance burzze New England 9 06-20-2020 12:51 PM
MeisterR ClubRace Coilovers: Affordable Track Focused Suspension MeisterR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-02-2017 06:22 PM
No longer needed, mods please delete wheelsun Software Tuning 0 08-11-2016 03:17 AM
